Particle Travels Between Two Walls
  • Thread starter Thread starter Warmacblu
    Particle
8 replies · 7K views · last reply
Warmacblu
Hi all, I am a long time reader but first time poster. I figure I would start posting my homework problems because I seem to have a bunch of them and I do not have the ability to see my professor on a daily basis. Thanks for any future help.
A particle travels horizontally between two parallel walls separated by 18.4 m. It moves
toward the opposing wall at a constant rate of 8.7 m/s. Also, it has an acceleration in the
direction parallel to the walls of 2.7 m/s^2.
Part 1 - What will be its speed when it hits the opposing wall?
Part 2 - At what angle with the wall will the particle strike?
I first tried the constant acceleration equations but then I re-read the question to see that the particle does not have a constant acceleration in the Y-direction.
Vf = Vi + at
After twenty minutes or so I tried this:
v^2 - u^2 = 2aS
where u = 8.7 and S = 18.4
v^2 = u^2 + 2aS
v = (u^2 + 2aS)^(1/2)
v = (8.7^2 + (2)(2.7)(18.4))^(1/2)
v = 13.23 m/s
I found this equation in my notes I took during class but wasn't sure if it was the right one to use or not.
I did not attempt part two.
Thanks for any help,
Ben
Lets call the horizontal direction the x-axis. The way I understand the problem is that you have a particle that starts at one wall with a velocity in the x-direction. It experiences an acceleration in the y-direction. Hint: Treat the x and y motions separately.
How long does it take to reach the opposite wall?
What will be the y-component of its velocity at that time? The x-component?
Thanks for the reply Doc Al.
(18.4 m) / (8.7 m/s) = 2.11 s
I am unsure about the components part but here is what I think:
x-component = 18.4
y-component = (2.11) x (2.7) = 5.697
hmm personally i would find out the angle by seeing how far it's gone in the x and y direction between the hits, also remember though that it's a constant acceleration, not constant velocity,so i would use this equation
x = ut + 0.5at²
then it's geometry
Edit:also where did you get that 2.7 from? 0.o, you've said earlier the acceleration was 2.3
Good.
x-component = 18.4
Careful! Only the y-component is accelerated.
Is the acceleration 2.7 or 2.3 m/s^2?
What determines the angle is its velocity when it hits, not where it hits the wall.
Doc Al said:
Good.
Whoops, right.
In that case, the x-component would be 8.7 m/s.
I typed the problem wrong, the actual acceleration is 2.7 m/s^2; I will fix the original post.
Just to be clear I believe the y-component is (2.11) x (2.7) = 5.697
Looks good.
I solved both parts last night, thanks for all the help.
