Particles Within Atoms: Uncovering the Mystery of Forces and Vacuum
  • Context: High School
  • Thread starter Thread starter Space
    Atoms Particles
The discussion centers on the nature of atoms, emphasizing that while fundamental particles occupy an insignificant volume, the majority of an atom is filled with intense fields rather than empty space. The electromagnetic force holds atoms and molecules together, allowing for interactions that can be overcome, such as breaking a rock. The concept of 'size' for fundamental particles is complex, as they can be localized to very small volumes but do not have a definitive size. The notion of 'empty space' in atoms is challenged, suggesting that it is filled with delocalized particles and fields.
  • Understanding of fundamental forces, particularly electromagnetic and strong forces.
  • Familiarity with quantum mechanics concepts, including particle localization and delocalization.
  • Basic knowledge of atomic structure and the composition of matter.
  • Awareness of the limitations of classical measurements in quantum physics.
  • Explore the concept of delocalization in quantum mechanics.
  • Research the electromagnetic force and its role in atomic interactions.
  • Study the strong force and its significance in nuclear stability.
  • Investigate the implications of quantum tunneling and particle behavior at subatomic levels.
Physicists, students of quantum mechanics, and anyone interested in the fundamental nature of matter and atomic interactions.
Space
TL;DR
If, inside of an atom is mostly space, how do we have stuff made of atoms?
Transcript from "what the bleep do we know"
the particles take up
an insignificant amount of the--
of the volume of an atom or molecule, the fundamental particles.
The rest of it is vacuum.
Questions:
If, inside of an atom is mostly space, how do we have stuff, that is made of atoms?
Stuff like rock.. - If it is so rigged, how can a vacuum be there?
If there is vacuum, how come, I can't shake and hear stuff moving around?
OR
If the forces holding the atom are so strong, reason, we cannot shake and hear it, then, how come I can break a rock?
I wouldn't be watching "What The Bleep Do We Know".
Space said:
Summary:: If, inside of an atom is mostly space, how do we have stuff made of atoms?
None of the volume of an atom is vacuum. It is all filled with very intense fields.
It's unclear to me what you (and the source you used) mean.
There are different types of forces acting within an atom, and between atoms. The electromagnetic force is responsible for holding atoms and molecules together. This force is pretty strong, but not so strong that it can't be overcome by e.g. human hands, like breaking a rock or a stick.
Inside the nucleus of atoms, there is another type of force at work, the strong force. This is the force that holds the nucleus together, and this force can't be overcome by ordinary means.
For more info see: Fundamental Forces (HyperPhysics).
Your question is more nuanced than you may realize. It involves asking, "how big are fundamental particles?" And that's not an easy question to answer. When we detect a fundamental particle, we can always localize it (find it) within some small volume of space, and we can make that volume as small as we want and find the particle within it and not outside of it.
For example, a pixel on a camera sensor will detect a photon while the other pixels nearby do not. You won't have a partial detection on multiple pixels, it will always be detected by one and only one pixel. We can make our pixels as small as we like and we will still detect a photon at one and only one pixel. Now, real camera sensors have a minimum size to their pixels, but the idea applies to other detection methods as well.
So what we have is, in effect, that fundamental particles don't have a size. Or, rather, don't have a minimum size, in the sense that we can localize them to as small a volume of space as we like. But we also know that particles interact with each other at a distance, so then we have to ask, "do they have a maximum size?"
Unfortunately this isn't any easier to answer than the first question. What do we mean by "size"? For large, macroscopic objects this is easy to answer. I take out my ruler and I measure a cube and say that it's 3x3x3 inches, to within some measurement error. But that's only because we can't see all the details down at the subatomic level with our naked eye.
How would we even measure the size something like an electron? We can't use a ruler, so we have to be more creative. Well, electrons repel each other, so one way is to shoot electrons at each other and see how they bounce off of other electrons. On our everyday scale objects either hit each, or they miss completely. There doesn't seem to be an in-between. You don't see bowling balls miss the pins by half an inch yet still somehow bounce off of them. But it's different for electrons. Since the electromagnetic force is infinite in range, there is no distance that the electrons wouldn't repel each other. Surely this can't mean that electrons have infinite size, right?
Well, perhaps the EM force isn't the right one to look at. Surely there is some way to tell how big an electron or other fundamental particle is, right? Well, no. No matter what experiments we do, no matter which particular forces we focus on, there simply isn't a clear, unambiguous way to define or measure the size of a fundamental particle. They seem to be able to be as small as we can measure, they can interact across infinite distances, and they will do very, very strange things like tunnel through solid barriers, rotate around twice to get back to their starting orientation, and many other things that don't make any sense to us if we try to compare them to macroscopic objects.
So, how big are fundamental particles? We can't answer that at this time, and there may not even be an answer. One way to view things is to say that the particles are delocalized until they are detected. So if I put an electron in a box, I can say that the electron is somewhere in the box (assuming it hasn't quantum tunneled out), but I don't know where. It wouldn't be incorrect to say that the electron is delocalized and occupies the entire box until I do something to measure its position. The same is true for an atom. I know a hydrogen atom has a proton and an electron, but I can't say that either particle is in a certain position until I measure their positions. So both particles, and the atom itself, is delocalized.
Moving back to the original question, what is in the 'empty space' in atoms? We can't answer that except to say that the notion of 'empty' vs 'non-empty' space isn't clear-cut in this context. Personally I would say that the particles making up an atom are delocalized, meaning that they don't have a definite position. And since they don't have a definite position it would be reasonable to some to say that an atom doesn't have empty space. The space is filled with the delocalized particles that make up the atom. Or you could say it's filled with intense fields. OR you could say that the space is never empty, just filled with excited and un-excited regions of underlying fields (EM field, electron field, quark field, etc).
It's quite complicated.
A rock is composed of many different atoms and molecules with many different types of bonds. Some are tightly bound to each other, but others are only loosely bound together. It is these weak inter-atomic and inter-molecular forces that you overcome when you break apart a rock.
Here is an analogous question: If, inside of a galaxy is mostly space*, how do we have the universe, that is made of galaxies?
*For simplicity, I ignore dark matter.
Space said:
Transcript from "what the bleep do we know"…
Usually we wouldn’t allow a thread that starts with “What the bleep do we know?” - that movie is on our list of banned topics because iwe spend too much time trying to unconfuse people who have been confused by it.
In this case your question is reasonable enough so we’ve allowed the discussion, but you should know that there are way better sources out there. The movie is fun, but it’s more entertainment than real science and eventually you will have to unlearn just about everything you get from it.
The nucleus is sharply concentrated at the center, but the electron field is delocalized and fills the space within atoms and molecules. See the article
from my Theoretical Physics FAQ, or the very recent paper
Questions:
OR
Because particles interact strongly and have a long reach.
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 46 ·
  • · Replies 62 ·
11K
  • · Replies 28 ·
