Partitioning with Primes: Comparing P(n) and P'(n)
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
    Partition Primes
9 replies · 4K views
Loren Booda
If a partition P(n) gives the number of ways of writing the integer n as a sum of positive integers, comparatively how many ways does the partition P'(n) give for writing n as a sum of primes?
doesnt it varies from number to number for example the partition of the number 10 by the sums of prime numbers is 5+5,2+3+5,3+7,2+2+2+2+2 so P'(10)=4 (if mistaken do correct me) and the number of partitions of let's say 15 by its prime numbers sums is diifferent from those of 10.
loop quantum gravity,
Yes, I believe the number of "prime partitions," P'(n), increases with integer n, just not as rapidly as that of conventional partitions, P(n). (Do I understand you correctly?)
The number of ways that a number can be written as the sum of positive integers? I assume that you mean without ordering.
So we have:
N(0)=0
N(1)=1 (1)
N(2)=2 (1+1,2)
N(3)=3 (1+1+1,1+2,3)
N(4)=5 (1+1+1+1,1+1+2,1+3,2+2,4)
N(5)=7 (1+1+1+1+1,1+1+1+2,1+1+3,1+2+2,1+4,2+3,5)
N(6)=10(1+1+1+1+1+1,1+1+1+1+2,1+1+1+3,1+1+2+2,1+1+4
1+2+3,1+5,2+2+2,2+4,6)
P(0)=0
P(1)=0
P(2)=1 (2)
P(3)=1 (3)
P(4)=1 (2+2)
P(5)=2 (2+3,5)
P(6)=2 (2+2+2,3+3)
P(7)=3 (2+2+3,2+5,7)
P(8)=3 (2+2+2+2,2+3+3,3+5)
P(9)=4 (2+2+2+3,2+2+5,2+7,3+3+3)
Obviously P(n)<N(n) and
[tex]\lim_{n \rightarrow \infty} \frac{P(n)}{N(n)}=0[/tex]
Take a box of volume V, exactly filled by a large number of either (1.) blocks having progressively integer length, or (2.) blocks having progressively prime length and both (1. & 2.) of unit square cross-section. Is the initial exact packing more easily determined for one situation than the other?
You mean that you have a line segment, and you're partitioning it into intervals of decreasing size?
I don't understand the notion of 'initial exact packing' that you describe, but there are definitely more possibe arrangements for (1) than there are for (2) if V > 0.
Two sets of blocks each fit a given box exactly. All blocks have a square cross-section of unit area. The first set comprises blocks of sequential integer >0 length, the second set comprises blocks of sequential prime >1 length. Initially given either set unboxed, which boxing is more easily determinable?
Huh? I don't understand your question.
Are you trying to do this type of problem:
Given an integer N > 1 construct a set of primes [tex]{p_i}[/tex] with [tex]i \neq j \rightarrow p_i \neq p_j[/tex] and [tex]\sum p_i = N[/tex].
Sorry, NateTG, I perceived a pattern that apparently wasn't there.
