Path difference from time difference in Michelson-Morley
2 replies · 2K views
physiks
I'm a little confused about this.
I know how to derive the expression t≈lv2/c3 for the time difference between the arrival of the two beams due to the presence of an ether, with the Earth moving at speed v through the ether, and l the distance between the beam splitter and each mirror. This can be done so by working in the ether frame or the interferometer frame.
Now, ultimately I want to find the expected phase shift if the ether were to exist. To do so I need a path difference from this time difference. My book says it is given by ct, i.e s≈lv2c2. I understand this in the ether frame, as the light travels at speed c. But in the interferometer frame, it doesn't have this speed, and so I don't understand what's going on there. I'm very confused. From this path difference, it's easy to get the phase difference.
Thanks
Can't you assume the difference in reference frame speeds is small, so the difference in computed path differences is a second-order small quantity?
That would make sense!
