Path of light in material of continuously varying refractive index
The discussion focuses on finding the optimal path of light in a medium with a continuously varying refractive index. The time functional T[y] is defined to minimize the time taken for light to travel along a curve, leading to the formulation of an equation involving derivatives of y. Initial errors in the derivation were identified and corrected, allowing for the desired result to be achieved. An alternative perspective highlights that the index of refraction is proportional to a differential element of arc length, suggesting deeper implications for the relationship between light paths and refractive index. The conversation concludes with appreciation for the new insights gained from the discussion.
etotheipi
Suppose that the speed of light ##c(y)## varies continuously through a medium and is a function of the distance from the boundary ##y=0##. Use Fermat's principle to show that the path ##y(x)## of the light ray is given by
$$c(y)y'' + c'(y)(1+y'^{2})=0$$
N/A
I've been playing around with this for quite some time now this morning but can't get the last bit out. I defined the time functional to be $$T[y] = \int_{x_1}^{x_2} \frac{\sqrt{1+(y')^{2}}}{c(y)} dx$$ which follows from consideration of the time taken to cover an infinitesimal section of arc. I want to find the ##y(x)## that minimises ##T## so I let ##F(x,y,y') = \frac{\sqrt{1+(y')^{2}}}{c(y)}## and put the whole thing into the magic equation $$
\begin{align}
\frac{d}{dx}\left(\frac{\partial F}{\partial y'}\right) &= \frac{\partial F}{\partial y} \\ \frac{d}{dx} \left( \frac{1}{c(y)} \frac{y'}{\sqrt{1+(y')^{2}}} \right) &= \frac{\partial F}{\partial y} \\ \frac{1}{c(y)} \frac{y''\sqrt{1+(y')^{2}} - \frac{(y')^{2}}{\sqrt{1+(y')^2}}}{1+(y')^2} + \frac{c'(y)}{c(y)^{2}} \frac{(y')^{2}}{\sqrt{1+(y')^2}} &= - \sqrt{1+ (y')^2} \frac{c'(y)}{c(y)^{2}}
\end{align}
$$ This turns out to be equivalent to $$c(y) y'' + c'(y) (1+(y')^2) = \frac{c(y)(y')^2}{1+(y')^2} - c'(y)(1+(y')^2)$$So it's sort of what we want, except not really since I've got that annoying thing on the RHS! Any help would be appreciated!
Likes JD_PM
I figured it out, there were two errors in my working!
In equation (3), I ended the derivative chain too early and forgot to multiply the second term in the first fraction by ##y''##. The first fraction should actually read $$\frac{1}{c(y)} \frac{y''\sqrt{1+(y')^{2}} - \frac{(y')^{2}(y'')}{\sqrt{1+(y')^2}}}{1+(y')^2}$$ And secondly, the second fraction in equation (3) should be negated. With those corrections, the desired result is obtained after a bit of cancellation.
Phew...
With all due respect, I have a different take on your problem. Your optical Lagrangian is, $$
\mathcal L=\frac{\sqrt{(1+y'^2)}}{c(y)}$$ and thus$$
\frac{\partial{\mathcal L}}{\partial {y'}}=\frac{y'}{c(y)\sqrt{(1+y'^2)}}\\
\frac{d}{dx}(\frac{\partial{\mathcal L}}{\partial {y'}})=\frac{y''}{c(y)\sqrt{(1+y'^2)}} + y'\frac{d}{dx}(\frac{1}{c(y)\sqrt{(1+y'^2)}})\\
\frac{\partial{\mathcal L}}{\partial {y}}=-\frac{c'(y)\sqrt{(1+y'^2)}}{c(y)^2}$$ and we have.$$
\frac{y''}{c(y)\sqrt{(1+y'^2)}}+y'\frac{d}{dx}(\frac{1}{c(y)\sqrt{(1+y'^2)}})=-\frac{c'(y)\sqrt{(1+y'^2)}}{c(y)^2}\\
c(y)y''+c'(y)(1+y'^2)=-c(y)y'\sqrt{(1+y'^2)}\frac{d}{dx}(\frac{1}{c(y)\sqrt{(1+y'^2)}})$$For the l.h.s. to be zero, we must have,$$
\frac{d}{dx}(\frac{c}{c(y)\sqrt{(1+y'^2)}})=0$$where I have multiplied by c (speed of light in vacuum) and we see ##\frac{c}{c(y)\sqrt{(1+y'^2)}}## is a constant of motion. The ratio ##\frac{c}{c(y)}## is the index of refraction and we infer that the index of refraction is proportional to a differential element of arc length.
  • Love
Likes etotheipi
That's a really nice insight, I hadn't considered anything further than the given result!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
  • · Replies 18 ·
