Pauli Spin Matrices - Lowering Operator - Eigenstates
The discussion focuses on the Pauli lowering operator, represented as ##\sigma_{-} = \sigma_{x} - i\sigma_{y}##, and its effect on the eigenstates of the Pauli spin matrix ##\sigma_{z}##. The participants confirm that applying ##\sigma_{-}## to the eigenstates of ##\sigma_{z}## results in new eigenstates, with the eigenvalue decreasing by one unit. The eigenstates of ##\sigma_{z}## are identified as ##\left( \begin{array}{ccc} 1 \\ 0 \end{array}\right)## and ##\left( \begin{array}{ccc} 0 \\ 1 \end{array}\right)##, leading to a clear understanding that the zero vector indicates a transition to a non-existent state, reinforcing the concept of eigenvalues in quantum mechanics.
  • Understanding of Pauli spin matrices
  • Familiarity with eigenstates and eigenvalues in quantum mechanics
  • Knowledge of linear algebra, specifically matrix operations
  • Basic concepts of quantum mechanics, particularly angular momentum operators
  • Study the properties of the Pauli matrices and their applications in quantum mechanics
  • Learn about the action of lowering and raising operators in quantum systems
  • Explore the implications of eigenvalue changes in quantum mechanics
  • Investigate the relationship between angular momentum operators and their eigenstates
Students and professionals in quantum mechanics, physicists studying angular momentum, and anyone interested in the mathematical foundations of quantum state transformations.
ChrisJ
This is not part of my coursework but a question from a past paper (that we don't have solutions to).
1. Homework Statement
Construct the matrix ##\sigma_{-} = \sigma_{x} - i\sigma_{y}## and show that the states resulting from ##\sigma_{-}## acting on the eigenstates of ##\sigma_{z} ## are also eigenstates of ##\sigma_{z} ## and comment on your result.
pauli spin matrices
I need more help with the commenting on the result and the actual physics rather than the maths here,
I constructed the matrix ##\sigma_{-} =
0 & 0 \\
2 & 0 \end{array}
\right)
and in previous bit of question found the eigenstates of ##\sigma_{z}## to be ##
1 \\
0 \end{array}\right) ## and ##
\left( \begin{array}{cc}
0 \\
1 \end{array}\right)## respectively.
So therefore ##\sigma_{-}
1 \\
=2
0 \\
and also ##\sigma_{-}
0 \\
1 \end{array}\right) =
0 \\
I am pretty sure the math is correct as I ran the math past a few people who agreed but I can't see how/why that that shows they are also eigenstates of ##\sigma_{z}##. I can maybe see it mathematically with the first result, as that is explicitly an eigenstate, but the zero matrix result, I am not sure how in words I can say that it is. And what it means physically. As I said this isn't part of any coursework, just a question from a past exam paper, any help/advice is much appreciated.
An eigenvector is defined to be a non-zero vector, so the statement that the resulting vector is an eigenstate of ##\sigma_z## as mentioned in the question shall only apply to cases when the resulting vector is non-zero.
As for the comment, I think it asks you about how ##\sigma_-## changes the eigenvector of ##\sigma_z##, for example how the eigenvalue changes.
Likes ChrisJ
Ah ok, that zero vector/matrix was throwing me. Ok so its just as simple as saying that it lowers the eigenvalue by one? A previous part of the question was to find the eigenvalue of ##\sigma_z## and was found to be 3 and 3.
ChrisJ said:
Ah ok, that zero matrix was throwing me. Ok so its just as simple as saying that it lowers the eigenvalue by one? A previous part of the question was to find the eigenvalue of ##\sigma_z## and was found to be 3 and 3.
At least that's the most notable property of ##\sigma_-##.
Likes ChrisJ
3 and 3?
vela said:
3 and 3?
Sorry, worded that wrong. Meant to say that I found the eigenvalues of the two eigenstates to be 3 and 3.
That's what I thought you meant, but you should have found them to be 1 and -1.
Likes ChrisJ
Not sure why I missed that, but that's clearly not true.
Likes ChrisJ
My bad! I did the previous bit of the question a couple weeks ago, sorry my fault. It seems the 3 and 3 I had in my head was not about that, it was to find the eigenvalues of ##\sigma^2=\sigma_x^2+\sigma_y^2+\sigma_z^2 ## Sorry for the confusion. I just remembered in my head that I found eigenvalues and they were 3, so when I went back to do the rest of the multiple part question, I had those 3's in my head.
But now that you pointed out the mix up. My original question about commenting on the result ##\sigma_{-}## acting on ##\sigma_z##? as when the lowering operator acts on ##\sigma_z## it results in an eigenstate of ##\sigma_z## but with an eigenvalue of 2, but its original eigenvalues were 1 and -1?
No, the constant 2 in ##\sigma_- |+\rangle = 2 |-\rangle## is not the eigenvalue - it should be obvious that this equation is not an eigenvalue equation. What ##\sigma_-## does is that it changes the eigenstate of ##\sigma_z## to another eigenstate whose eigenvalue is one unit smaller than that of the initial eigenstate. Lowering operator, for more general angular momentum operator, obeys the condition ##L_z L_- |n\rangle = (n-1)\hbar L_- |n\rangle## where ##|n\rangle## is an eigenstate of ##L_z##.
Likes ChrisJ
  • · Replies 28 ·
