simulation135
- 3
Hi I am trying to determine the power usage of a progressive cavity pump in an oil well setting. I have some data to analyze, where I know the amount of viscous rod torque (ft lbs) per 1000 ft of rod length, I can use various rod lengths, and I know the RPM. Calculating the total Rod Torque I need to determine the power consumption of the motor turning the PC pump. I am using the formula
Power = (Torque X RPM)/3300
where power is in Horse Power
I then converted the HP into KW using a conversion of 1 HP per 0.746 KW, then multiplying by 3600 to get KW hours. Finally I multiplied by $0.07 per KW hour as is the going rate for electricity. However the answer I got was extremely large, I believe the problem lies with the formula I am using. Any help would be greatly appreciated.
