PDE Help - Eigenfunction of a LaPlacian
The discussion focuses on eigenfunctions of the Laplacian Δ within the cube [0, ∏]³ under Dirichlet boundary conditions. An example of an eigenfunction is provided, specifically u = sin(x) which satisfies the boundary conditions at x = 0 and x = π. The solution to the wave equation is expressed as u(t,x,y,z) = cos(√λt)v(x,y,z), confirming that the cosine function adheres to the boundary conditions. Participants seek clarification on how to approach the problem and identify suitable functions for the given conditions.
  • Understanding of eigenfunctions and the Laplacian operator
  • Familiarity with Dirichlet boundary conditions
  • Knowledge of the wave equation and heat equation
  • Basic skills in solving partial differential equations (PDEs)
  • Study the properties of eigenfunctions of the Laplacian in various geometries
  • Learn about the derivation and application of the wave equation
  • Explore the method of separation of variables for PDEs
  • Investigate the implications of boundary conditions on eigenfunction solutions
Mathematicians, physicists, and engineering students focusing on partial differential equations, particularly those studying wave and heat equations in bounded domains.
rexasaurus
1. A function "v" where v(x,y,z)≠0 is called an eigenfunction of the Laplacian Δ (on some region Ω - with specified homogenous BC) if v satisifies the BC ad also Δv=-λv on Ω for some number λ.
Part A: Give an example of an eigenfunction of Δ when Ω is the cube [0,∏]3 with Dirichlet BCs.
Part B: Show that, for any eigenfunction v, the function u(t,x,y,z)=cos(√λt)v(x,y,z) is the solution for the problem:
utt=ΔU on [0,T]XΩ with Ω=[0,∏]3
u=0 on ∂Ω for 0≤t≤T
{u(0,x,y,y)=v(x,y,z) for 0≤x,y,z≤∏}
{u(0,x,y,y)=0 for 0≤x,y,z≤∏}
2. We are studying heat equation, wave equation, eigenfunctions, d'Alamberts sol., ray-tracing, etc.
3. Okay... I am not sure how to approach a problem of this nature. I sketched the cube from [0,∏]. I am assuming that the answer is given in part B. I can see how the cosine function is always 0 at the BC's. Any help with this process would be appreciated.
Hint: Can you think of a function whose second derivative is minus a constant times itself and whose values at 0 and pi are zero?
Sin(K*u)?? Second derivative would be -K2sin(K*u)
I am not sure which variable should be inserted for "u" since u is a function of x,y,z.
Your independent variables are x,y, and z. In part A you are trying to match the boundary conditions. So u = sin(x) would take care of the x = 0 and x = π boundary conditions. What about the others?
  • · Replies 27 ·
