Calculating Work W: when pdV or Vdp?
  • Context: Undergrad
  • Thread starter Thread starter dries
    Work
The discussion centers on the appropriate use of the integrals W = ∫pdV and W = ∫Vdp for calculating work in thermodynamic processes. It is established that W = ∫pdV is used for closed systems where volume changes occur, such as in isentropic compression, while W = ∫Vdp applies to open systems with constant volume, like inflating a tire. The participants clarify that both equations can be utilized depending on the system's characteristics and the nature of the process, emphasizing the importance of defining system boundaries accurately.
  • Understanding of isentropic processes
  • Familiarity with thermodynamic system classifications (open vs. closed)
  • Knowledge of the first law of thermodynamics
  • Proficiency in calculus, specifically integration techniques
  • Study the application of the first law of thermodynamics in closed systems
  • Learn about isentropic processes and their equations
  • Research the differences between open and closed thermodynamic systems
  • Explore practical examples of work calculations in thermodynamic systems
Students and professionals in mechanical engineering, thermodynamics, and physics, particularly those involved in energy systems and fluid dynamics.
dries
If you have to calculate the amount of energy needed to perform a compression of the amount of energy is gained by expanding. Then I don't know when to use the integral
W = int pdV
and when
W = int Vdp
thanks in advance
Science news on Phys.org
If you compress something does the volume change?
the process is isentropical (so yes)
If the volume changes why are you contemplating Vdp?
using the isentropic equation
pV^k = constant = p1V1^k
you can write V in function of p so you get another integral
int (p1/p)^(1/k)*V1 dp
p1^(1/k)*V1 * int p^(-1/k) dp
An analog conversion is possible for the pdV, but i found both as methode to calculate the required energy. Now I wan't to know when i have to use which one
(thanks for the fast responses already)
PdV states the volume change at constant pressure.
So you use this for thermodynamic processes carried out at constant pressure eg the free expansion of a gas against the atmosphere, most chemical reactions, carried out in an open beaker.
VdP states the change in pressure at constant volume so you would use this when say inflating a bicycle tyre or gas cylinder, whose volume does not change.
P or V don't have to be constants as shown in previous formule of isentropic change, they can be dependent of each other. Imagine a compressor, both volume and pressure changes when the air is being compressed.
Are you telling me or asking me?
PdV is the reversible work done on a system by changing the volume.
VdP is the change in enthalpy for a process which is both reversible and adiabatic (or isentropic).
More info http://en.wikipedia.org/wiki/Isentropic_process#Isentropic_flow".
So, if your process occurs in a http://en.wikipedia.org/wiki/Thermodynamic_system#Closed_system" (where there is no mass flow in or out), you use PdV.
If the process occurs in an http://en.wikipedia.org/wiki/Thermodynamic_system#Open_system" (where there is mass flow coming in or out), you use vdP.
Thanks a loth for the valuable reply!
Good morning, jack action
I am worried about your statements.
Can we apply them to a real calculation, say the work done by the gas in expanding
100 litres of neon at 0o C and 10 bar (atmosphere) of pressure, expanded to 1 bar (atmosphere) of pressure
1) Via a reversible isothermal process
2) via a reversible adiabatic process
3) via a sudden (nonreversible) adiabatic process
Are the above systems open or closed?
I make the answers
1) 232 850 Joules
2) 91410 Joules
3) 54740 Joules
I think I'm right, but I'm open to discussion. My experience is based on engine processes.
For example, when you compress the air inside the cylinder with the valve closed, that is a closed system. In this case, the work input needed by the piston will be PdV (which is CvdT for an isentropic process as shown in my previous link).
But if you achieve the same compression with a turbine which has open ends with continuous airflow, that is an open system. In this case, the work input needed by the turbine will be VdP (which is CpdT for an isentropic process as shown in my previous link). In this case, you also need to take http://en.wikipedia.org/wiki/Stagnation_temperature" into account, since the fluid is in motion at the inlet and outlet.
Work required by an open system is then larger than work required by a closed system since Cp > Cv.
The OP did say the process was isentropic but was not more specific. You're talking about an isothermal process, which I would treat as an isentropic process with heat addition (or removal), which is described in my previous links for both closed and open systems.
As for determining if the free expansion of a gas against the atmosphere is an open or closed system, I haven't really thought of it, but I would risk an answer by saying it is a closed system. The system would be the entire atmosphere where no fluid comes in or out.
Hello, jack, the OP was not very clear but seemed to want to know when to use PdV and when to use VdP in calculating the work term in thermodynamic processes.
This was particularly muddled
I was trying to lead him towards a sensible understanding and statement before he seemed to start arguing the toss.
However the question, as I have posed it, is a reasonable one that troubles many and deserves an airing.
Actually I was talking about three different types of process (for good reasons) and put my results where my mouth is.
I will happily display the calculations ( they each only a few lines long) and discuss those reasons, but I wondered if you got the same values?
But if you achieve the same compression with a turbine which has open ends with continuous airflow, that is an open system. In this case, the work input needed by the turbine will be VdP (which is CpdT for an isentropic process as shown in my previous link). In this case, you also need to take stagnation temperature into account, since the fluid is in motion at the inlet and outlet.
One of the keys to getting thermodynamic calculations right is to correctly define the system boundaries.
Another is clearly to use the correct equations.
You are talking about the flow version of the first law or if you like a modified Bernoulli in you turbine.
I look forward to your reply
You will have to show your work and explain more as I don't understand what you are trying to prove or what worries you about my statements.
  • · Replies 16 ·
  • · Replies 20 ·
