PE 75 primitive Pythagorean triples
  • Thread starter Arman777
    Primitive
37 replies · 6K views · last reply
Arman777 said:
We can optimize now
OK. You know my first question: "where is your program spending its time?"
:angel:
Sadly I don't know
Code:
         277502 function calls in 110.125 seconds
   Ordered by: standard name
   ncalls  tottime  percall  cumtime  percall filename:lineno(function)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:103(release)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:143(__init__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:147(__enter__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:151(__exit__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:157(_get_module_lock)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:176(cb)
        2    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:211(_call_with_frames_removed)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:222(_verbose_message)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:232(_requires_builtin_wrapper)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:307(__init__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:311(__enter__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:318(__exit__)
        4    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:321(<genexpr>)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:369(__init__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:416(parent)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:424(has_location)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:433(spec_from_loader)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:504(_init_module_attrs)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:576(module_from_spec)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:58(__init__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:663(_load_unlocked)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:719(find_spec)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:740(create_module)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:748(exec_module)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:765(is_package)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:78(acquire)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:855(__enter__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:859(__exit__)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:882(_find_spec)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:948(_find_and_load_unlocked)
        1    0.000    0.000    0.000    0.000 <frozen importlib._bootstrap>:978(_find_and_load)
        1  109.993  109.993  110.125  110.125 P75.py:1(<module>)
    13388    0.078    0.000    0.078    0.000 P75.py:23(<setcomp>)
        3    0.000    0.000    0.000    0.000 {built-in method _imp.acquire_lock}
        1    0.000    0.000    0.000    0.000 {built-in method _imp.create_builtin}
        1    0.000    0.000    0.000    0.000 {built-in method _imp.exec_builtin}
        1    0.000    0.000    0.000    0.000 {built-in method _imp.is_builtin}
        3    0.000    0.000    0.000    0.000 {built-in method _imp.release_lock}
        2    0.000    0.000    0.000    0.000 {built-in method _thread.allocate_lock}
        2    0.000    0.000    0.000    0.000 {built-in method _thread.get_ident}
        1    0.000    0.000    0.000    0.000 {built-in method builtins.any}
        1    0.000    0.000  110.125  110.125 {built-in method builtins.exec}
        4    0.000    0.000    0.000    0.000 {built-in method builtins.getattr}
        4    0.000    0.000    0.000    0.000 {built-in method builtins.hasattr}
        1    0.000    0.000    0.000    0.000 {built-in method builtins.len}
        2    0.000    0.000    0.000    0.000 {built-in method builtins.print}
   250000    0.052    0.000    0.052    0.000 {built-in method math.gcd}
        2    0.000    0.000    0.000    0.000 {built-in method time.perf_counter}
    14044    0.002    0.000    0.002    0.000 {method 'add' of 'set' objects}
        1    0.000    0.000    0.000    0.000 {method 'disable' of '_lsprof.Profiler' objects}
        2    0.000    0.000    0.000    0.000 {method 'get' of 'dict' objects}
        1    0.000    0.000    0.000    0.000 {method 'remove' of 'set' objects}
        2    0.000    0.000    0.000    0.000 {method 'rpartition' of 'str' objects}
What is this represents ?
P75.py:1(<module>)---
I guess just running takes the time and using sets which contains large numbers.
Is there some other way than "set" to keep track of what lengths have been used and how often?
Well without using set I cannot do my operations. So my algorithm fails. So I don't think there's within the current algorithm structure. But I am thinking.
Nonsense.
What's wrong with a plain old array of 1 to maximum length?
Vanadium 50 said:
Nonsense.
I mean arrays don't support (|) or (&) operations. Of course, array's can be used. But I have to transform these operations into the loops and that's not so good.
I'll do the same thing but using extra loops to create operations.
I can do the same with set's and only using 2 simple operation symbol. I don't see how using arrays would change the run-time, without changing the algorithm itself. (Also I remember that sets are faster then when searching numbers in it. In my previous question about prime numbers I guess)
I think the problem is in the algorithm itself.
I can try to create a method where at some steps I can reset the num_set_0 so that the length of set does not exceed ten thousand
OK, you're the boss. Your code runs in an hour, mine in milliseconds. What do I have to teach you. Good luck!
I am not the boss. I just argued that just changing set to arrays would not make any difference without chaging the algorithm itself.
Because lists do not support -, &, | operations.
I created functions for these oprations and turn my code into the list version. At max_sum = 10 000, my code is 33 times faster then list version.
If there's a faster way then doing these logical operations on lists other then creating functions, maybe things could be different. But I don't know how to do that.
