Peak in single ODE within a system
  • Context: MHB
  • Thread starter Thread starter Carla1985
    Ode Peak System
The discussion revolves around a system of nonlinear ordinary differential equations (ODEs) defined by the equations for variables X, Y, and Z, with parameters k+, k-, α, and β. The user, Carla, observes that the time course of Z exhibits peaks depending on these parameters. A key insight is that a peak occurs when the condition αk+XY > βZ holds true. The conservation law D = X + Y + 2Z is established as a constant, which simplifies the analysis of the system.
  • Understanding of nonlinear ordinary differential equations (ODEs)
  • Familiarity with conservation laws in dynamical systems
  • Knowledge of parameter stability and conditions in mathematical modeling
  • Experience with numerical ODE solvers
  • Explore stability analysis of nonlinear ODEs
  • Investigate the use of numerical methods for solving nonlinear ODEs
  • Learn about parameter sensitivity analysis in dynamical systems
  • Study the implications of conservation laws on system behavior
Mathematicians, physicists, and engineers working with dynamical systems, particularly those interested in the behavior of nonlinear ODEs and their applications in modeling real-world phenomena.
Carla1985
Hi all, I have the system of nonlinear ODEs:
\begin{align}
\frac{dX}{dt}=&-k_+ A X+k_-Y \\
\frac{dY}{dt}=&\ k_+ A X-k_-Y-\alpha k_+ X Y +\beta Z \\
\frac{dZ}{dt}=&\ \alpha k_+ X Y -\beta Z
\end{align}
I also have a conservation law that says $D=X+Y+2Z$. Obviously it is not possible to find exact solutions to the system as it is nonlinear, but I noticed when running an ODE solver that the time course curve of $Z$ sometimes has a peak and then fall, dependent on the parameters. I was wondering if there is any way to be able to find a condition on whether I get a peak or not?
Regards
Carla
At a base level, you could say that a peak like that means there is an interval $(a,b)$ containing a point $c$ such that $\dfrac{dZ}{dt}>0 \; \forall \, t\in(a,c)$ and $\dfrac{dZ}{dt}<0 \; \forall \, t\in(c,b)$. So, based on your system of ODE's, you could compare $\alpha k_+ X Y -\beta Z$ with $0$. Put another way, when is $\alpha k_+ X Y > \beta Z?$
Do you have any constraints (other than your conservation law, which looks like it could reduce the order of the system by 1. I assume $D$ is a constant?) on the constants $\alpha, \beta, k_+,$ and $k_-?$
Does your "conservation law" mean that D= X+ Y+ 2Z is a constant? If so then, taking the derivative of both sides with respect to t, $\frac{dX}{dt}+ \frac{dX}{dt}+ 2\frac{dZ}{dt}= 0$. Using the derivative formulas given, it follows that $\alpha k_+XY- \beta Z= 0$ so you can replace the XY term by $\beta Z$ to get a linear system.
Hi,
Yes, sorry, I should have explained better, D is a constant value. The only other constraints are $\alpha, \beta, k_+, k_-\geq 0$. I will work through your suggestions. Thank you very much for the help.
Regards
Carla
Is $A$ a constant as well?
Yes $A$ is constant. The only variables are $X,Y$ and $Z$
  • · Replies 16 ·
