Peak wavelength and Spectral Bandwidth
The discussion focuses on calculating the peak wavelength and spectral bandwidth of GaAs and silicon LEDs at liquid nitrogen temperature (77 K) and room temperature (300 K). The peak wavelengths are determined using the formula λg = 1.24/Eg, resulting in 0.867 μm for GaAs (Eg = 1.43 eV) and 1.088 μm for silicon (Eg = 1.14 eV). The spectral bandwidth is calculated using the equation (1.8kbT) / ħ, yielding values of 7.6*10-6 m at 300 K and 2.9*10-5 m at 77 K. The discussion concludes that GaAs is expected to be a better emitter due to its shorter peak wavelength, which correlates with higher energy emission.
  • Understanding of semiconductor physics, particularly band gap energy
  • Familiarity with LED operation principles
  • Knowledge of thermodynamic concepts, specifically temperature effects on energy
  • Basic grasp of quantum mechanics, including Planck's constant (ħ) and Boltzmann's constant (kb)
  • Research the impact of temperature on LED performance and emission characteristics
  • Explore the relationship between band gap energy and peak wavelength in different semiconductor materials
  • Learn about the spectral properties of LEDs and how to measure them
  • Investigate methods for enhancing LED brightness and efficiency
Electrical engineers, materials scientists, and anyone involved in LED technology and semiconductor research will benefit from this discussion.
says
Calculate the expected peak wavelength and spectral bandwidth (in units of wavelength) of the
emission for both a GaAs and silicon LED at liquid nitrogen temperature (77 K) and room temperature (300 K). Which of these cases would you expect to result in the best emitter and why?
λg = hc/Eg
λg: maximum wavelength
λg [μm] = 1.24/Eg
Spectral bandwidth = (1.8kbT) / ħ
λg: band gap represents minimum energy, or maximum wavelength for which an electron-hole pair can be excited
GaAs Eg: 1.43 eV
Si Eg: 1.14 eV
λg [μm] = 1.24/1.43 = 0.867 μm (maximum wavelength for GaAs)
λg [μm] = 1.24/1.14 = 1.088 μm (maximum wavelength for Si)
Spectral bandwidth = (1.8kb*300k) / ħ = 3.928*1013Hz
Expressing this in units of wavelength, I've used the relation between frequency and wavelength:
λ=c/f = c / 3.928*1013Hz
=7.6*10-6m
Spectral bandwidth = (1.8kb*77k) / ħ = 1.008*1013Hz = 2.9*10-5m/s
λ=c/f = c / 1.008*1013Hz
= 2.9*10-5m
So I think I've got the correct peak wavelength and spectral bandwidth, I'm not sure about the last question though or how I can quantify if one is a better emitter than the other. Any help would be much appreciated!
I would interpret "better emitter" as "brighter", meaning more total energy is emitted. You do have relevant information here.
What does the peak wavelength measure? Peak of what?
What does the spectral bandwidth measure? Bandwidth of what?
I'm guessing greater energy = better emitter = lower wavelength
Question is asked in regards to LEDs
Are you saying that longer wavelengths always equal more energy? So the energy given off by a nuclear explosion in gamma rays is less than the energy given off by a glowing coal in the infrared? Are you sure?
Again, what does the peak wavelength measure? Peak of what? What does the spectral bandwidth measure? Bandwidth of what? How are those things defined?
I know it's about LEDs. I'm asking you to think through the meaning of those parameters. "It's the bandwidth" and "it's about LEDs" are not an explanation. What is it that has a width? What are the axes of the associated graph?
16K
