Medical Peanut allergy -- What substance causes the reaction?
  • Thread starter Thread starter wolram
    Allergy Reaction
Peanut allergies are caused by the immune system's inappropriate response to proteins found in peanuts, which bind to antibodies and trigger an inflammatory reaction. While the exact cause of why some individuals develop these allergies remains unclear, genetic predisposition and environmental factors play significant roles. Symptoms can range from mild to severe, including anaphylaxis, and the severity often correlates with exposure levels. The discussion also touches on the misconception that there is no specific substance causing allergies, clarifying that proteins are typically the culprits. Overall, the complexity of allergic responses highlights the need for continued research into their triggers and mechanisms.
wolram
Dearly Missed
What is in pea nuts that causes such violent illness and even death?
Biology news on Phys.org
Allergies and other autoimmune disorders occur when the immune system negatively reacts to a something that normally would cause any harm (e.g. peanuts). You can't inherit a specific allergy, but people whose parent(s) had allergies are more likely to get them themselves. Unfortunately, no one knows for sure what exactly causes allergic reactions, aside from knowing that it is caused by, for lack of a better word, misbehaving immune systems. Anaphylaxis, itchiness, and other things associated with allergies, including peanuts, are just symptoms as the immune system fights back unnecessarily. The severity of the symptoms just varies with the exposure and seriousness of each person's allergy. Peanut allergies aren't any more serious than other allergens. It is payed more attention to probably just because it is airborne and many children have it--thus, schools and the entire student body have to be more cautious when dealing with food.
http://well.blogs.nytimes.com/2014/02/03/as-peanut-allergies-rise-trying-to-determine-a-cause/?_r=0
http://www.webmd.com/allergies/guide/chronic-allergies-causes?page=1
Likes wolram
Adding to the above (sorry, I can’t edit the top post anymore…idkw) there is no actual “substance” in things that causes allergies. There are very rare occurrences where people are diagnosed with aquagenic urticaria, which is literally an allergy to water. Some are allergic to pure elements like nickel. There are obviously no additional chemicals within these things, but people’s bodies still react negatively to them. Why? It’s a mystery for now (wait ‘till I research it in college and then I’ll give you the answer, wolram). But, oh, how dreadful allergies are...
While this might be true in some cases (of which I'm not particularly aware), food allergies are generally caused by some protein (or other component) in the food that binds to an antibody produced by the body's immune system (usually IgE) that triggers an inflammatory response. The most well-known pathway in this response involves histamine (which is why antihistamines such as Benadryl are used as allergy medicine), but the entire allergic response is extremely complex and involved.
aquagenic urticaria
This is not a true allergic response per se. Our bodies are ~60% water, so a true water allergy would probably be immediately fatal.
Just because it is rare doesn't necessarily mean that it is not "real". Though, you're right--I was generalizing and trying to make everything simple. Aquagenic urticaria is not a histamine-releasing reaction.
Likes 1oldman2
There are numerous examples...how else can people be allergic to things such as nickel or chromium?
I didn't say it wasn't real. I said it wasn't a true allergic response. Although, I'm not sure if its mechanism of action is known. In at least two cases, it was treated with an antihistamine. Regardless, the point I was trying to make in my first post is that allergies are specific immune responses caused by antibodies binding to allergens.
Chromium and nickel ions dissolve into the skin and are recognized by the immune system: https://en.wikipedia.org/wiki/Nickel_allergy
Likes ProfuselyQuarky
Yes, I'm aware of that. That was just my response to whether there were allergies not having to do with proteins.
Ok I'm confused. I was responding to your assertion that
I'm becoming confused, as well. Because although you were responding to my assertion that
Your complete sentence stated
suggesting that "food allergies being generally caused by some protein" was justification that the statement "no actual “substance” in things that causes allergies" was somewhat erroneous. However, in my statement, I was referring to all types of allergies and not just food allergies.
Sorry for the confusion. I should have worded my posts better.
Just to clarify, it's true that there's no single substance that causes allergies. And it's unclear why certain people are allergic to certain substances (from a genetic point of view). However, the allergic response itself is pretty well understood, and it occurs upon binding of an antibody to an allergen (which is almost always a protein). Non-protein allergies (like nickel allergies) generally involve the allergen (like Ni2+) binding a protein and causing it to misfold or change its conformation in some other way. Subsequently, the misfolded protein (called an epitope) is bound by the antibody, inducing an allergic response. (side note--I use the term "misfolded" very loosely here.)
I appreciate the clarification, TeethWhitener, since wolram was asking about the cause in the OP. Thank you.
Likes 1oldman2 and TeethWhitener
http://www.medscape.com/viewarticle/777380_3 Table 1 has a list of 11 water soluble glycoproteins and proteins that have been found to cause peanut allergic responses. These molecules are unaffected by normal cooking temperatures. So cooking does not *denature them. There may be others.
Proteins are not commonly named except in the context of a biological pathway. Some proteins with names like casein are made of several different molecules The researchers in the field named them Ara n where n is 1 - 11. Arachis is the genus name for peanuts - Arachis hypogaea.
Also note - the above is the immediate cause - the metabolic pathway for allergensis (absolute root cause) has apparently many possible causes: heredity and environment interactions. So like a lot of food related medical problems the prevention relies on avoiding something: in this case peanut products in food.
*denature: "destroy the characteristic properties of (a protein or other biological macromolecule) by heat, acidity, or other effects that disrupt its molecular conformation." - wikitionary Example: cooking egg white - goes from clear and water soluble to "rubbery and white".
Likes FactChecker, ProfuselyQuarky, wolram and 1 other person
Thank you
Any time :smile:
Some years ago I heard a theory that the original cause of peanut allergy was that peanut products are very frequently contaminated with very slight traces of aflatoxins, which are very nasty, and that this primes the immune system to react strongly to peanut-related proteins in general on subsequent exposure. I don't know whether this is still considered a viable explanation.
There will almost always be something around and in food that our immune system may not like. It is important is to minimize an over reaction from our immune system to these "things". Our immune system will over react if the signals from that "thing" your immune system does not like is amplified. Unfortunately, people in the developed countries are all exposed to metals (aluminum, mercury, etc) so we have those in our bodies and these metals will amplify that "thing". So then our immune systems will over react. Flush away these heavy metals from our bodies and we can minimize allergies and auto-immune diseases.
@st mess - Please provide a peer reviewed citation for your comment about exposure to metals and allergenesis. I would like to learn more if what you said holds water. Thanks.
I'd like to know more about that, too. His statement suggests that the allergies people have/acquire vary and are somewhat dependent on both geographic and demographic factors...I never heard about that before and would love to know.
I'm not at all sure the metal comment is a valid point.
I agree with you, I'm afraid... I'm not so sure how merely exposure to metals (or any other material) would cause the immune system to behave negatively towards it. In that case, wouldn't we all be doomed one way or another?
The reference to metals in the western world and the suggestion that you can "flush" them away sounds a bit too close to the whole toxin flushing fad for me.
I once told a girl that hemoglobin contained iron and she cried, "I need to detox!"
I neard a theory that Baby aspirin salicylates sensitize peanut allergies
