Pebble being dropped into a well
  • Thread starter Thread starter professordad
The problem involves a pebble dropped into a well, with the splash sound heard 3.0 seconds later. The speed of sound in air is 340 m/s. To solve for the time it takes for the pebble to hit the water (t1) and the time for the sound to reach the observer (t2), the equations t1 = √(d/4.9) and t2 = d/340 are used, leading to the total time equation t1 + t2 = 3 seconds. This establishes a relationship between the depth of the well (d) and the time variables.
  • Understanding of kinematic equations, specifically v = v_0 + at
  • Knowledge of gravitational acceleration (approximately 9.8 m/s²)
  • Familiarity with the speed of sound in air (340 m/s)
  • Ability to manipulate algebraic equations to solve for unknowns
  • Calculate the depth of the well using the derived equations.
  • Explore the implications of varying the speed of sound in different mediums.
  • Learn about free fall and its applications in physics problems.
  • Investigate the relationship between time, distance, and speed in motion problems.
Students studying physics, educators teaching kinematics, and anyone interested in solving real-world motion problems involving gravity and sound.
professordad
A pebble is dropped into a deep well, and 3.0 seconds later the sound of a splash is heard as the pebble reaches the bottom of the well. The speed of sound in air is about 340 m/s.
(a) How long does it take for the pebble to hit the water?
(b) How long does it take for the sound to reach the observer?
(c) What is the depth of the well?
From College Physics by Serway and Faughn
v = v_0 + at
x = v_0t + \frac{1}{2}at^2
v^2 = v_0^2 + 2ax
(a) So in this problem we know the acceleration (which is the gravitational constant) and we also know v_0 which is 0 because it starts out as 0 m/s. But in all three equations, there are 4 variables, and knowing 2 variables is not enough.
Then I tried plugging in and obtaining a system. So I got
-19.6x = v^2
v = -9.8t
But this doesn't help much, and if you add a 3rd equation its going to be the same thing (the three equations are related). So I don't know how to proceed :(
Also for (b) and (c) I think you need (a) to solve them.
BTW I'm out of school, so this problem doesn't count for a grade or anything :)
Forget the distance for the moment and try to find the time. You need the speed of sound for this.
v = v_0 + at
v^2 = v_0^2 + 2ax
-19.6x = v^2
v = -9.8t
How have you defined your variables?
I don't see any of your solution which includes the speed of sound.
Don't assume that you can get part (a) without also working on (b) and/or (c) .
Taking the depth to be d, the time it takes for the rock to hit the water is t_1= \sqrt{d/4.9} and the time for the sound to come back is t_2= d/340. So the total time is given by t_1+ t_2= \sqrt{d/4.9}+ d/340= 3.
@ SammyS: Oops yeah, I did forget to define variables. In this case v_0 is the starting velocity, t is the time which it takes for the pebble to hit the water, and x is the displacement. (in this case it's also the distance because the pebble doesn't go back) And v is the velocity when the pebble hits the water, though I guess that wasn't needed.
Thanks to everyone for the help! :D
  • · Replies 17 ·
