What Is the Expected Wait Time for the Last Pedestrian at a Traffic Light?
The expected wait time for the last pedestrian at a traffic light, where arrivals follow a Poisson process with rate ##\lambda##, can be calculated using the Law of Total Expectation. The first pedestrian pushes the button at time ##t=0##, initiating a wait time of ##T## seconds. The expected wait time of the last pedestrian is derived from the distribution of arrivals and can be expressed as a function of the number of arrivals ##n## and the expected time until the first arrival. The final formula incorporates probabilities and expected values, leading to a structured approach for determining the wait time.
  • Understanding of Poisson processes and arrival rates
  • Familiarity with the Law of Total Expectation
  • Knowledge of order statistics and uniform distributions
  • Basic calculus for integrating probability density functions
  • Study the derivation of expected values in Poisson processes
  • Learn about order statistics in probability theory
  • Explore the application of the Law of Total Expectation in various scenarios
  • Review the provided MIT course notes on discrete stochastic processes
Students and researchers in probability theory, mathematicians focusing on stochastic processes, and anyone interested in modeling pedestrian behavior at traffic signals.
Mehmood_Yasir
Pedestrians approach to a signal for road crossing in a Poisson manner with arrival rate ##\lambda## per sec. The first pedestrian arriving the signal pushes the button to start time ##T##, and thus we assume his arrival time is ##t=0##, and he always see ##T## wait time. A GREEN light is flashed after ##T##, and all arrived pedestrians within ##T## must cross. Process repeats. What is the expected wait of the LAST pedestrian crossing the road?
##P_k=\frac { {(\lambda T)}^k e^{-\lambda T} } {k!}##
If ##t_l## is the arrival time of last pedestrian, the stay time is T minus ##t_l##. then this stay time is also exponentially distributed with same parameter ##\lambda##. For expectation value, the exponential pdf can be integrated over the interval from 0 to T. I am not sure if this statement is correct that T minus ##t_L## is also exponentially distributed, because ##t_L## is arrival time of last, the next exponential in original may have larger value than ##T##.
You already know the wait time pdf of the kth pedestrian ##f(t|k)## from a previous thread. If you know the probability p(k) that the kth pedestrian is the last pedestrian, then you can get the pdf of the last pedestrian's waiting time.
If this is "merely" for expected values, an easier approach may be to use conditioning (specifically Law of Total Expectation).
e.g. Suppose ##n = 0## arrivals happen in ##(0, t]## -- i.e. no arrivals once the button is pushed. The expected wait time of the last person, i.e. the button pusher, is ## t##.
Now for all other cases, ##n \gt 0##:
you can ignore the button pusher and look at this in terms of 'regular' Poisson mechanics. Conditioning on ##N(t) = n##, all arrivals are uniformly distributed in ##(0, t]##. There are some technical nits on ##n!## orderings but pick one without loss of generality -- because we're actually looking at order statistics here. The easy problem is then to find the CDF of time until first arrival given ##N(t) = n##
You should get (with ##U## referring to the i.i.d. uniform random variables that exist in this conditional world -- there are n of them)
##Pr\{\text{Arrival 1's time} \gt \tau \big \vert N(t) =n \} = 1 - F_{min}U = \big[1 - F_U(u)\big]^n##
(note this was the underpinning of a recent thread: https://www.physicsforums.com/threa...f-ind-r-v-that-follows-distribution-f.946651/ and working through the CDFs for minimum and maximum amongst N i.i.d. random variables -- order statistics-- is an exercise worth doing.)
you can integrate this complementary CDF to get the expected time between Light going off and first 'real' arrival. Thus you have ##E\big[ X_1 \big \vert N(t) =n\big]##, then using a symmetry argument, or the fact that this process is time reversible (why?), you have thus found ##E\big[ X_n \big \vert N(t) =n\big]##.
Putting it all together with Law of Total Expectation (and hopefully note spoiling the result), should give:
##E\big[\text{Last Ped's wait time}\big] = p_\lambda(n=0, t) \Big(t\Big) + \sum_{n=1}^{\infty}p_\lambda(n, t) \Big(E\big[ X_n \big \vert N(t) =n\big]\Big)##
When you're all done, you should see there's some nice structure in the factorials in the denominator that should allow a closed form for the series.
What I've said above is all discussed in a lot more detail here:
https://ocw.mit.edu/courses/electri...ring-2011/course-notes/MIT6_262S11_chap02.pdf
which is something I've mentioned to you a while back. I am not supposed to give this whole thing away, though, so I leave the reading and a lot more lifting, to you.
  • · Replies 32 ·
  • · Replies 30 ·
