Perfect Square (Quadratic function)
The discussion revolves around the conditions under which a quadratic function of the form ax² + bx + c can be classified as a perfect square. Participants are exploring the implications of the discriminant and the coefficients involved.
  • Participants discuss the relationship between the discriminant being zero and the coefficients being perfect squares. There is also a consideration of whether integer coefficients are necessary for a quadratic to be a perfect square.
The discussion is ongoing, with participants providing insights and questioning the definitions of perfect squares. Some guidance has been offered regarding the conditions needed, but no consensus has been reached on the necessity of integer coefficients.
There is ambiguity in the textbook regarding the requirement for integer coefficients, which some participants plan to clarify with their teacher. The implications of the discriminant and the sign of the leading coefficient are also under consideration.
Ak94
What is the condition, for a quadratic function of the form
ax2 + bx + c = y
to be a perfect square? (x, y are real here)
There's a question of this type in a book I'm working with, and I'd just like to have some general conditions for any quadratic...
Since y = ax2 + bx + c = a(x-[tex]\alpha[/tex])(x-[tex]\beta[/tex])
where [tex]\alpha[/tex] and [tex]\beta[/tex] are the values of x for which y = 0,
y is a perfect square when Discriminant of quadratic = 0 (this ensures that [tex]\alpha[/tex] = [tex]\beta[/tex]) and when a is a perect square..
Are these the required conditions for any quadratic function (of the given form) to be a perfect square? Any condition I may have missed?
ax2 + bx + c = y
How about if y = 2x2 + 4x + 2 = 2(x + 1)(x + 1)? Is that a perfect square?
hm..
2x2+4x+2=[[tex]\sqrt{2}[/tex](x+1)]2
and since [tex]\sqrt{2}[/tex] isn't an integer, the expression isn't a perfect square...
so that does imply that when D = 0, and coefficient of x2 is a perfect square, we can conclude that the entire quadratic will be one.. ?
Ak94 said:
hm..
So I guess it depends on what your definition of "perfect square" is! And I've never seen one that required constants to be integers. Is that from your textbook?
Are you required to use integers as coefficients? I know some introductory algebra books specify that you factor only if you have integer coefficients, but you have not specified this. If so, your comment that
[tex] 2x^2 + 4x + 2 = \left( \sqrt 2 (x+1) \right)^2[/tex]
is not a perfect square is correct. If non-integer coefficients are allowed, it is a perfect
square.
it's kind of ambigously mentioned in the book, so I'll talk to my teacher about it.., thanks for pointing that out :)
So a perfect square number would have to be the square of an integer, but that is not needed for an expression.. ?
Also.. I guess D = 0 is still a necessary condition
Since this perfect square would be greater than or equal to 0, the parabola representing the function would have to open upwards, so it would be greater than 0
So, the necessary (and sufficient) conditions are D = 0, a > 0? (assuming that any real coefficient is allowed)
Is that right?
Not necessarily. I would call "[itex]a(x- b)^2[/itex]" a "perfect square" for any numbers a and b- a does not have to be positive.
I see.. so D = 0 is the only condition..
to everyone who helped out, thanks :)
  • · Replies 19 ·
