How Do Permanent Magnets Generate Energy in a Dynamo System?
This discussion centers on the principles of energy generation using permanent magnets in a dynamo system. It establishes that while magnets can repel each other due to electromagnetic interactions, they do not generate energy on their own. The concept of using negatively charged permanent magnets on a fan to power a dynamo is debunked, as magnetic forces are conservative and do not perform net work. The conversation emphasizes that energy cannot be created or destroyed, and any perceived energy generation from such a setup is fundamentally flawed.
  • Understanding of electromagnetic interactions and forces
  • Familiarity with the concept of conservative forces
  • Basic knowledge of dynamo systems and energy conversion
  • Awareness of magnetic properties and behaviors of permanent magnets
  • Research the principles of electromagnetic force and energy conservation
  • Study the mechanics of dynamo systems and their efficiency
  • Explore the effects of temperature on permanent magnet performance
  • Investigate real-world applications of magnetic repulsion in energy systems
Physics enthusiasts, electrical engineers, and anyone interested in renewable energy systems and the principles of magnetism.
DudeWut
First off, I am new here, so please don't tear me apart too hard if I miss or misinterpret something, I'll cotton on eventually :D
As I understand it, when a permanent magnet repels an oppositely charged object, such as another oppositely charged permanent magnet, no energy is technically being used for the magnets to repel each other, as it is the same principle as putting an apple on a table. The stiffness of the table is counteracting the force of gravity's force on the apple, and that is why the table doesn't just collapse. The stiffness is from the electromagnetic interactions of the atoms making up the table, so in the end it is the EM force counteracting the gravitational force. The magnets repelling each other is caused by electromagnetic interactions.
In this case, if I were to mount negatively charged permanent magnets onto the blades of a fan, and rotate them using the repulsion of a positively charged permanent magnet, then use said fan to power a dynamo that generated electricity, where would the electrical energy be coming from? Energy cannot be created (or destroyed for that matter) so where is it coming from?
Yes, the magnets may eventually lose their magnetism due to surrounding heat and such destabilizing them, but don't magnets still work at absolute zero? In a vacuum environment at absolute zero with no outside forces that can destabilize the magnets at that moment (the friction of the fan turning would generate heat, which would radiate to the magnet and perhaps destabilize it over time) the magnets would still repel, yes? At absolute zero, in a vacuum, there isn't much energy going around that the magnet can readily store and convert to repel it's opposite. As far as I am aware there is no energy change in a magnet anyway. Where is it coming from!?
DudeWut said:
...if I were to mount negatively charged permanent magnets onto the blades of a fan, and rotate them using the repulsion of a positively charged permanent magnet
That doesn't work and videos on YouTube that appear to show the fan rotating are _all_ fake.
Magnetic force is a conservative force. Read the first paragraph of this..
https://en.m.wikipedia.org/wiki/Conservative_force
If the fan were to rotate that would be the equivalent of a particle (magnet) returning to its starting position once per revolution (eg traveling around a closed loop) so no net work is done. No work means nothing to overcome friction so it cannot rotate.
PS Welcome to the forum.
Note that:
A positively charged object ATTRACTS a negatively charged object.
A positively charged object REPELS a positively charged object.
A negatively charged object REPELS a negatively charged object.
similarly for magnetism:
North and south poles attract each other.
A north pole repels a north pole, and a south pole repels a south pole.
Ever try to pull two magnets stuck together apart?
You have to do work to do that.
The work can be recuperated by moving the magnets back together again.
10K
  • · Replies 27 ·
12K
9K
