Permutation and combination in maths
The discussion centers on calculating the number of 7-digit numbers that can be formed using 5 distinct digits, ensuring at least two different digits are present. Initial calculations suggested using 5^6, but participants clarified that the correct approach involves using 5^7 to account for all possible combinations and then subtracting the cases where only one digit is used. The confusion arose around the treatment of repetitions and the interpretation of the problem's requirements. Ultimately, the consensus indicates that the total valid combinations are 5^7 - 5, resulting in 78,120 valid 7-digit numbers. The conversation highlights the importance of understanding permutations and combinations in solving such mathematical problems.
Jurij
Hi. I've got problem with this task.
We have 5 digit. How many 7-digit numbers can we create that has at least 2 different digit?
Jurij
whats the problem?
I don't know how to solve the task.
Could anybody help me?
I think that the answer is 5^6=15625 but i don't know how to prove it. Could you help me?
I think this problem is related to permutation and combination in maths.
There could be some confusion about what the question actually asks. If you stated the question exactly as given that might help.
As I understand it, you are ask to create a seven-digit number where each digit comes from a set of five choices, and there must be at least two different digits represented within the seven. If that is the right interpretation of the question, there are a number of ways of going about this.
The secret in combinatorics is to look for the short cuts to the answer. There are usually different equivalent ways of enumerating things. In this case, the quick way to the answer is to count up the options you're not allowed to have.
Think of it this way. Every possible combination of digits is allowed (each of seven digits with 5 choices) except for a certain set. If you can figure what is the set that isn't allowed, you can just subtract it from the total.
I won't give away the next step but ask yourself what combinations aren't allowed and then work out how many of them there are.
I hope this is the correct answer to your question :
(5 ) (5) * 5 ! - 5 =
(25) ( 120) - 5 = 2995 ways
Why is it correct answer? Could you explain it? I think it is too small.
Yes it is P&C problem;
well first off given only 5 distinct digits(i assume that's what you meant and let's call it alphabet to distinguish from 7digits)
[0]how many 7 digit numbers can you make with 5 digits(- - - - - - -) =
that is the total you can have. REMEMBER TO GET RID OF REPETITIONS
find an easy way to do this..hint if (a is the first digit then a must also be the last.
[1][Now what is the exclusion(well you want at least 2 different alphabets): you don't want any 7digit that has exactly only 1 alphabet present...
thus your exclusion set is #of 7digits of only 1 alphabet present...THUS YOU GOTTA FIGURE HOW MANY THERE ARE
Your solution will be #=TOTAL-Exlusion set.
lastly becareful how many times your exclusion set appears in the set of repetitions.
I think I made small mistake , you have to choose five choices of each digit of each of the seven digits you suppose to fill then you have
5^7
excluding five choices (a,a,a,a,a) or (b,b,b,b,b) ...five of them
then the answer = 5^7-5=78120 ways
I am sorry again I made mistake.I hope this time it is right
If you mean you have to make a 5-number sequence when you have 7 different numbers to choose from for each position, you need to do (number of possibilities per position)^(number of positions). Subtract the illegal choices from that number, and you're done.
mithal i dont' think that's the right answer because you forgot to subtract repetitive #s from the 5^7.
I think it is right because these five choices are the only non - permissable in the condition of the problem ( at least two allowed different digits ) suppose else (a,a,a,a,b) is included a,b are two different digits .
thats not what i meant... what i meant was the set of all valid 7digits prior to the restriction (subtraction of 5) is not 5^7.
It is 5 ^7 .Every time you have to make five choices for each digit of the seven digits .repetion is allowed .So in this way you cover all possibilities and then subtract the five cases that not allowed in the condition of the problem as I mentioned before .
No, repetitions are not allowed. repetitions are not distinct
for examples in 3digit words 121 and 121 are a repetition but in 5^3 they are counted separatedly so 2x rather than 1x.
I didn't mean repeation in the sense you are talking about . I mean if you choose 3 for the first digit then you can use 3 again for the second digit or the third or etc. or any other number . That mean once you choose that number for that digit you can repeat it again subsequently for other digits.You can visualize this if you draw a tree and consider different cases .
I also would like to point out to a small mistake I made with the notations
I assumed the five digits are (a , b , c ,d ,e ) and
I meant ( a , a ,a ,a ,a ,a ,a ) and not like in the solution
( a , a ,a ,a ,a ) since it is seven digit number not five and the same for the others . But this has no effects on the logic of the answer . All stay the same .
i understood what repetition you were talking about. However i was not refereing to the alphabet(5digits) but rather the word(7digit word)
THe repetition i was thinking of was an undirectional ordering question where
abc is the same cba. I realized i was wrong. and i apologize.
The question was referring to directional words.
