Permutations and Combinations: Distributing Balls Among People
The discussion revolves around calculating the number of ways to distribute 5 differently colored balls among 3 people, ensuring each person receives at least one ball. The initial calculations presented by the user resulted in an incorrect total of 540, stemming from a misunderstanding of how to account for the distribution orders. It was clarified that the order of distribution should not be counted as different, which led to confusion in the calculations. The correct approach involves selecting one person to receive 3 balls while the others get 1 each, and ensuring the distribution is accurately counted. Ultimately, the correct answer is confirmed to be 150 ways to distribute the balls.
erisedk
The total number of ways in which 5 balls of different colors can be distributed among 3 persons so that each person gets at least one ball is
Ans: 150
I don't understand what's wrong with my answer.
In case of each person getting one ball and the remaining two balls going to a single person, I have 5*4*3*3 ways. 5*4*3 for the first three balls and then the remaining two balls have three options, therefore the final *3
In case of the remaining two balls going to different people, I have 5*4*3*6 ways to do so, the final*6 because I have 3 spots and I have two pick two balls, and order matters as the balls are different.
Adding 5*4*3*3 + 5*4*3*6, I get 540.
What am I doing wrong?
50 is wrong, but 540 is not right either. You also count the order the persons get the balls as different. If the colors are ABCDE and the persons are 1, 2, 3, you count "A to 1, B to 2, C to 3 and then D and E to 1" as different from "D to 1, B to 2, C to 3 and then A and E to 1".
Better start picking the person to get 3 balls, and then look at the other two persons. The other part has the same issue.
Another way to look the 1-1-3 distribution is is to count the number of ways you can give two of the three people one ball each. The third person ends up with the rest.
erisedk, just in case that's not clear, mfb is saying you mistakenly counted those orders as different, not that you should count them as different.
Oh, ok.
I get it now.
  • · Replies 16 ·
