Perpendicular Forces, Acceleration and Mass Problem
Two perpendicular forces of 45.0 N upward and 60.0 N to the right act on a 35.0 kg object, requiring the calculation of the resultant acceleration. The correct approach involves using the Pythagorean theorem to find the resultant force, which should be 75 N, not 87.46 N. The acceleration is then calculated using the formula a = F/m, resulting in 2.14 m/s^2. However, there is a suggestion that the mass might be incorrectly stated, possibly being 25 kg instead of 35 kg. The discussion highlights the importance of verifying the problem details to ensure accurate calculations.
rwishka
Two perpendicular forces, one of 45.0 N directed upward and the second of 60.0 N directed to the right, act simultaneously on an object with a mass of 35.0 kg. What is the magnitude of the resultant acceleration of the object?
A. 8.68 m/s^2
B. 3.00 m/s^2
C. 5.25 m/s^2
D. 1.41 m/s^2
F = ma to a = F/m
a = F/35.0 kg
I simply don't understand what to do with the two forces? Should I draw a diagram? Please help me!
The acceleration on the particle will be due to the resultant force. How can you calculate the resultant of the two forces? Draw a diagram-- it may help you.
Would I use the Pythagorean Theorem?
I did (45.0)^2 + (60.0)^2 = c^2
c = 87.46 N
I plugged that into a = 87.46 N/35.0 kg, and got an incorrect answer.
What did I do wrong?
Your calculation for c is wrong. Try checking it again.
Sorry, c is 75 Newtons.
a = 75 N/35.0 kg
a = 2.14 m/s^2
Am I missing a step?
(Thanks for helping me so far)
Well, that's the answer I get. Either we're both overlooking something, or there's a typo in the question (I'd say that the latter was more likely!) Are you sure you wrote down the question and answers correctly (is there a possibility that the mass is 25kg?)
I checked and that is the problem. Hmm. Well, thank you for helping me! :)
