Perturbation: First order correction to particle-in-box eigenstates
4 replies · 5K views
McCoy13
First order correction to particle-in-box eigenstates for Dirac perturbation
Calculate the first three nonzero terms in the expansion of the correction to the ground state [itex]\psi^{1}_{1}[/itex] for a Dirac delta perturbation of strength alpha at a/2 (box from 0 to a).
[itex]\psi^{1}_{n} = \sum_{m\neqn} \frac{\left\langle\psi^{0}_{m}\right|H'\left|\psi^{0}_{n}\right\rangle}{E^{0}_{n}-E^{0}_{m}}\psi^{0}_{m}[/tex]<h2>The Attempt at a Solution</h2><br /> I started with m=2 and tried to computer the integral [tex]\left\langle\psi^{0}_{m}\right|H'\left|\psi^{0}_{n}\right\rangle[/tex] by parts.<br /> <br /> Calculations:<br /> [tex]\frac{2}{a}\alpha\int^{a}_{0}sin(\frac{2 \pi x}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx[/tex]<br /> integration by parts<br /> [tex]\frac{2}{a}\alpha([sin(\frac{2 \pi x}{a})sin(\frac{\pi}{2})]^{a}_{0}-\frac{2\pi}{a}\int^{a}_{0}cos(\frac{2 \pi x}{a})dx)[/tex]<br /> <br /> This clearly equals 0. Also, this equation indicates that the correction will be 0 for any m even.<br /> <br /> Trying m=3.<br /> [tex]\frac{2}{a}\alpha\int^{a}_{0}sin(\frac{\pi x 3}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx[/tex]<br /> integration by parts<br /> [tex]\frac{2}{a}\alpha([sin(\frac{\pi x 3}{a})sin(\frac{\pi}{2})]^{a}_{0}-\frac{3\pi}{a}\int^{a}_{0}cos(\frac{3 \pi x}{a})dx)[/tex]<br /> <br /> However, this also is 0, and will be for any m odd.<br /> <br /> This clearly cannot be the correct result.[/itex]
on Phys.org
[tex]f(x_{0})[/tex]
In this case that gives:
[tex]sin(\frac{\pi}{2}) = 1[/tex]
when taking
[tex]sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})[/tex]
to be the part that gets integrated in the integration by parts.
Oh. That's easy. Thanks.
Just to confirm my answer, I've now got:
for m = 3
[tex]\frac{\frac{2}{a}\alpha\int^{a}_{0}sin(\frac{3 \pi x}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx}{E^{(0)}_{1}-E^{(0)}_{3}}[/tex]
= [tex]\frac{\frac{2}{a}\alpha sin(\frac{3 \pi}{2})sin(\frac{\pi}{2})}{E^{(0)}_{1}-E^{(0)}_{3}}}[/tex]
= [tex]\frac{-2 \alpha}{a(E^{(0)}_{1}-E^{(0)}_{3})}[/tex]
= [tex]\frac{-2 \alpha}{a(\frac{\pi^{2} h^{2}}{2ma^{2}} - \frac{9 \pi^{2} h^{2}}{2ma^{2}})}[/tex]
= [tex]\frac{ma \alpha}{2 \pi h^{2}}[/tex]
Where h actually stands for h-bar and m stands for mass (rather than the index).
