Peskin Schroeder Enigmatic Equation
The forum discussion centers on the interpretation of equation 4.56 from the Peskin and Schroeder textbook on Quantum Field Theory (QFT), which defines the vacuum energy density as \rho_{vacuum\: energy\: density} = \frac{i\sum_{all\: disconnected\: diagrams} amplitude}{(2\pi)^4\delta^{(4)}(0)}. Participants express confusion regarding the finiteness and calculability of this result, particularly questioning the use of disconnected diagrams versus connected ones. The discussion highlights the significance of the 2\pi^4\delta^{(4)}(0) term, which relates to quantum field amplitudes and normalization factors.
  • Understanding of Quantum Field Theory (QFT) principles
  • Familiarity with Peskin and Schroeder's QFT textbook
  • Knowledge of vacuum energy concepts and their implications
  • Basic grasp of path integrals and their mathematical representations
  • Study the derivation and implications of equation 4.55 in Peskin and Schroeder
  • Learn about the role of disconnected diagrams in QFT calculations
  • Research the significance of vacuum bubbles in quantum field theory
  • Examine the normalization techniques used in QFT, particularly delta function normalization
Students and researchers in theoretical physics, particularly those focusing on Quantum Field Theory, as well as anyone seeking to deepen their understanding of vacuum energy and its mathematical foundations.
IRobot
Hi,
I am learning QFT in the Peskin/Schroeder book and I found 4.56 on page 98 really weird, it is:
\rho_{vaccum\: energy\: density} = \frac{i\sum_{all\: disconnected\: diagramms}amplitude}{(2\pi)^4\delta^{(4)}(0)}
The authors do not comment really this result, but could someone tell me at least if this is finite, calculable, ...Thank you.
IRobot said:
Hi,
Thank you.
I recognize the 2\pi^4\delta^{4}(0)} term. This term comes from a quantum field amplitude equation, usually seen in this form : 2\pi^4\delta^{4}(p-p)}. It's maybe not surprising as the energy density of the vacuum is also measured similarly.
He is equating the exponents on 4.55, and using what he discusses in 4.49
IRobot said:
Hi,
Thank you.
I'm not sure I understand the result either. To me it would make more sense if all the diagrams are connected. Also I'm a bit unsure about factors of the imaginary number 'i', but those always get me.
Basically the path integral is e-iHt, and the amplitude is exp[i*connected diagrams without sources], so setting the argument of the exponentials equal and setting VT=(2pi)4 delta4(0) should give a result that look similar, except with connected diagrams and not disconnected ones.
Does he use connected diagrams or disconnected ones? I don't have a copy of Peskin and Schroeder and my library doesn't have it so I can't look it up.
Actually your plain old e(-iS) gives only diagrams without endpoints; i.e. if you were to associate particles with these diagrams, you would see nothing turning into something back into nothing. These are typically called vacuum bubbles, and their sum represents the vacuum(or ground state) energy E0(peskin uses 'disconnected diagrams' in place of vacuum bubbles). He is dividing by the delta function because from his delta function normalization(discussed in 4.49) the delta(0) factor represents the volume of space(up to 2 pis).
Does Peskin use e(-iS), or e(iS)?
I think I see what you mean. In the path integral you usually have:
e^{-iS+\int J\phi d^4x}
So now you are setting J=0.
Still, you can have J=0 diagrams that are the product of other J=0 diagrams. For example, you can have two bubbles side by side, unconnected to each other. I don't think you should count those diagrams in the formula for the vacuum energy density, but I'm not sure.
Also, what is the meaning of the vacuum energy density? Isn't an additive constant to the energy not only arbitrary, but also unmeasurable?
  • · Replies 41 ·
