What is the Effect of Boiling Vinegar on its pH and Cleaning Properties?
  • Thread starter Thread starter Barfolumu
    Ph
The discussion centers on the effects of boiling vinegar, specifically its 5% acetic acid solution, on pH and cleaning efficacy. Users calculated the pH of vinegar to be approximately 2.42 and debated whether boiling it would enhance its cleaning properties. The conversation also touched on alternative cleaning methods, such as using dishwasher detergent and the environmental benefits of vinegar as a cleaning agent. Participants expressed concerns about the strong odor of boiling vinegar and its effectiveness compared to commercial cleaners.
  • Understanding of acetic acid properties and pH calculations
  • Knowledge of cleaning agents and their effectiveness
  • Familiarity with the boiling points of common substances
  • Basic chemistry concepts related to acid-base reactions
  • Research the chemical properties of acetic acid and its applications in cleaning
  • Explore the effects of boiling vinegar on its pH and cleaning capabilities
  • Investigate alternative eco-friendly cleaning agents and their effectiveness
  • Learn about the reactions between baking soda and vinegar for cleaning purposes
Individuals interested in eco-friendly cleaning solutions, homeowners seeking effective cleaning methods, and those studying the chemical properties of household substances.
Barfolumu
This was just a curiosity thing, but...
I assumed "5% acidity" to mean 5 percent of the soln was acetic acid, by volume (though, doing the calculations for "By mass", I got roughly the same pH). Also, I couldn't find the density of acetic acid in my textbook, so I assumed it was close enough for my calcs to water to use water's density. The pH I figured was ~ 2. Anyone know if this is correct?
Also, I'm using vinegar to clean my apartment before I leave... and some of my oven stains aren't coming off using it right out of the bottle. I saw that the boiling point for acetic acid was about 20 degrees C higher than water, so I'm wondering if boiling vinegar in a sauce pan w/o something to catch the vapor will increase the pH enough to make it a stronger cleaning agent. Anyone else ever try this?
Chemistry news on Phys.org
Regardles of wether it is w/w or v/v density is around 1.006, so assumption that it is that of water is OK. Calculated pH should be around 2.42.
How about bleach - would that corrode the oven surface? Why aren't you using store brand oven cleaners?
Price :D. Plus, all you have to do to vinegar is dilute it, and it's environmentally friendly.
EDIT: Price meaning, my 3 liters of vinegar cost about 3 bucks, and it's really good as an all-purpose cleaning solvent -- so you don't have to buy a lot of different kinds of cleaners. It works for mopping, kitchen counters, grease, and bathroom cleaning. With a little dish-soap, and maybe some window cleaner (haven't tried it for windows), you're pretty much covered.
You won't ever say that again if you hang around a boiling pot of vinegar! Can you imagine what your apartment will smell like after you wipe every surface whithin with this vile-smelling stuff?
I've found that dishwasher detergent (solid or goopy gel) makes a good oven cleaner. Got any of that around?
It wasn't bad right out of the bottle -- just opened the windows, and it blew out. I've never tried to concentrate the stuff... which is why I thought I'd post here and see some kind of response first.
I do my dishes by hand, so just have standard dish soap :-/. Thanks for the suggestion, though.
Good lord, I hear that. My Staedtler highlighters smell like acetic acid. I'm about this close to throwing them out and getting new ones. Makes me lose motivation to study when I get a whiff of these.
I wonder if throwing some baking soda on the vinegar would neutralize the smell. But I suppose that'd cause some bubbling on your countertops.
11K
15K
  • · Replies 19 ·
9K
40K
