Phase constant explanation needed
The phase constant (phi) in simple harmonic motion (SHM) is crucial for determining the system's initial conditions, such as starting position and velocity. The equation for displacement is x(t) = A cos(ωt + φ), where φ can be calculated based on initial conditions. If the initial displacement is zero, φ can be found to be π/2, while if the system starts with maximum velocity at zero displacement, φ equals -π/2. The general approach to find both amplitude (A) and phase constant (φ) involves using initial conditions for displacement and velocity. Understanding the phase constant is essential for accurately describing the motion of SHM systems.
Beano1323
Can anyone explain to me what the phase constant (phi) is regarding the equation for displacement in simple harmonic motion and tell me if there is any equation to get it because I have looked at some answers to simple questions and in the answers they have just neglected the phase constant altogether so they must have let it equal to zero or something.
Urgent assistance needed as physics test is on Monday!
Why not provide the equation you are concerned about?
It's not so much the equation just the phase constant itself.
x(t)=Acos[wt+(phi)]
The phase constant allows for different starting positions or velocities, if your equation is
x(t) = A\cos (\omega t + \phi )
and you know that
x(0) = 0
Then you can solve for the phase angle
0 = A\cos (\omega (0) + \phi ) \Rightarrow \phi = \frac{\pi}{2}
The phase constant depends on the initial conditions. Those mean the initial displacement and velocity. If the displacement x=Acos(ωt+φ) was maximum at t=0, the phase constant has to be zero, φ=0, as the the cosine function has its maximum at zero argument, cos0=1.
If the SHM started with a push, at zero displacement but maximum velocity, the derivative of x(t), v=-Aωsin(ωt+φ) has to be maximum at t=0. That happens when sin(φ)=-1, that is φ=-pi/2. In his case, the displacement is x=Acos(ωt-π/2), and it is equivalent to x=Asin(ωt).
In general case, x(0)=x0 and v(0)=v0. You can determine both A and φ in
x(t)=Acos(ωt+φ), v(t)=-Aωsin(ωt+φ)
which correspond to these initial conditions:
At t=0
x0=Acosφ, v0=-Aωsinφ,----->
A=sqrt(x02+(v0/ω)^2) and
tanφ= -v0/(ωx0).
ehild
Thanks a million lads!
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
29K
  • · Replies 21 ·
9K
