How Does the Photoelectric Effect Determine Electron Speed?
The discussion focuses on calculating the speed of an electron ejected from a metal surface due to the photoelectric effect when illuminated by light of wavelength 410nm. The work function required to remove the electron is 3.0 x 10^-19 J, and the potential difference between the emitter and collector is 0.5V. The maximum kinetic energy (KEmax) of the electron is calculated as 1.848 x 10^-19 J, leading to a final speed of 419,313.94 m/s using the formula v = √(2KE/m). The calculations and formulas used are confirmed to be correct by other forum participants.
  • Understanding of the photoelectric effect and its principles
  • Familiarity with kinetic energy calculations in physics
  • Knowledge of electric potential and its impact on charged particles
  • Basic proficiency in algebra and square root calculations
  • Study the photoelectric effect in detail, including its applications and implications in modern physics
  • Learn about the relationship between wavelength, frequency, and energy of photons
  • Explore advanced kinetic energy concepts and their applications in particle physics
  • Investigate the effects of varying electric potentials on electron trajectories
Physics students, educators, and professionals interested in the photoelectric effect, electron dynamics, and energy calculations in quantum mechanics.
sadakaa
1. Light of a wavelength 410nm is incident on a metal target and an electron is eject from the surface. The work required to remove this electron from the metal is 3.0 x 10^-19 J. The elctron then travels straight to a collection plate. The different in electric potential between the collector and emitter (target) is .5V (the emitter is at higher potential).
What is the speed of the electron the instant before it strikes the collector
I found that using KEmax = hf - W0, KEmax = 1.848 x 10^-19 J
2. d KE = -|qe Vthreshold |= -|(-1.6x10^-19C)(.5V)|= -8.0 x 10^-20 J
3. v = ROOT (2KE/m) = 419313.94 m/s
i'm not sure if i should be using this formula, nor am I sure how I could apply the kinematics forumlas. Let me know
Welcome to the forums,
Assuming you have done the arithmetic correctly, your answer should be good. It looks to be the right order of magnitude to me :approve:
the mathematics are correct, I'm just not sure if I'm using the correct forumlas
You're working with the correct formula.
  • · Replies 25 ·
  • · Replies 16 ·
