Photographing Coloured Flame KCl
  • Thread starter Thread starter ArtEO
    Kcl Photography
The discussion revolves around the challenges of photographing colored flames produced by burning potassium chloride (KCl) soaked paper. Participants explore various methods and materials to achieve the desired violet flame effect, while also addressing safety concerns and the chemistry involved.
  • Experimental/applied
  • One participant shares their experience as a photographer attempting to replicate a violet flame effect seen in a video, expressing frustration with their results.
  • Another participant suggests that sodium contamination in KCl could be affecting the flame color and recommends sourcing sodium-free KCl and using distilled water.
  • Concerns are raised about the safety of using alcohol for burning, with suggestions to consider gas as a safer alternative.
  • It is proposed that methanol may be a better solvent for dissolving salts compared to ethanol, and that additives in paper could also influence flame color.
  • A participant expresses interest in achieving the 'slow burn' effect and considers experimenting with methanol and KCl as suggested.
  • Details about the purity and composition of the KCl being used are shared, along with questions about the presence of magnesium hydroxide as a flame retardant.
  • Some participants discuss the potential role of a color filter to mitigate sodium's yellow light in the flame.
  • Safety precautions regarding smoke irritants and protective measures are emphasized, particularly when experimenting with chemicals.
Participants do not reach a consensus on the best method to achieve the desired flame effect. Multiple competing views and suggestions are presented, indicating ongoing exploration and uncertainty regarding the optimal approach.
Participants note various limitations, such as the potential presence of sodium in KCl, the influence of paper additives, and the need for careful selection of solvents and materials. There is also mention of safety concerns related to smoke produced during the burning process.
Photographers interested in capturing unique flame effects, chemistry enthusiasts exploring the properties of salts in combustion, and individuals seeking safe methods for experimental photography may find this discussion relevant.
ArtEO
Hello everyone,
I’m not a chemist at all, I studied physics which entailed a fair amount of chemistry in the learning but that was five lives ago. Nowadays I m a photographer, mostly editorial portraits but also fine arts. For my latest project I take pictures of a wide range of phenomena on very different scales, some calling for imagination, some being „cold“ descriptive.
I came across a YouTube video of someone burning a sheet of newspaper „soaked with KCl“ which then slowly burns in a stunning creeping violet flame.
I’d like very much to take closeups of this phenomenon but am very unsuccessful with my attempts so far.
I have a safe environment at hands, where I first tried to dilute KCl salt in water, soak the paper, dry it and burn it… got my regular orange flame.
I tried with alcohol (hand disinfectant) and salt again…. Same….
Please find the reference video here:
As I’m running out of ideas I wondered if someone could help me on that one. I tried to contact the person who posted the video but it’s dated 15 years ago. Thanks in advance
Chemistry news on Phys.org
Sodium is present everywhere, very difficult to avoid it. Could be what you use as KCl already contains enough to color the flame.
Two things to do: looks for a source of sodium free KCl (chemical suppliers, they always sell reagents with different purities, the purer the more expensive, I have no direct experience to tell what level of purity you need though) and use distilled water.
Check if the flame of that 'alcohol' in itself is colourless or orange. If it's orange then there are some additives in it and you need to change to 'clean' alcohol first to achieve some colourless flame.
To be honest, gas would be better since burning alcohol can be really dangerous.
Especially when it's colourless.
Then you can try your salt to see if it's clean enough in itself or not.
The paper can be tricky too, since some papers can contain additives, for example like Ca for whitening (yeah, it produces orange-ish flame :wink:)
Most salts are better soluble in methanol than in ethanol. So I would try this. Sodium from the paper will be a problem, too. Maybe the one who made the video used a neodymium glas filter or the like to get rid of the yellow sodium light?
Thanks for all the answers above ! Im actually ok having a bit of orange flame appearing in the visual mix but what is really at stake for me here is the ‘slow burn ‘ effect one can see at the end of the video. Based on your recommendation, should I give it a try at mixing the KCl salt in methanol, soaking the paper and let it dry, then burn it? (I mess add n I’ll try anyway but I’d just like to understand the process a bit on the way:) )
Maybe I can add the following description from the 500g box:
  • Formula: KCL
  • Purity: 99.1%
  • Particle size: Fine
  • Food-safe, 0.9% magnesium hydroxide polycarbonate as a Antiback remedy
  • Branded Product laborladen. de
ArtEO said:
Antiback remedy
Antibacterial?
Antibacterial?
Possibly…
Using clean (distilled?) water would be better. Try using different types of paper: maybe with wool content (security papers).
ArtEO said:
  • Formula: KCL
  • Purity: 99.1%
One ingredient caught my attention.
The magnesium hydroxide polycarbonate is a commonly used flame retardent, which is one of the things you are looking for. Maybe you could add an extra bit of that to your mixture.
That, along with the color filter suggested by @DrDu above, could be the "magic" needed.
https://www.linkedin.com/pulse/5-minutes-understand-magnesium-hydroxide-flame-retardant-leon-liu
[edit: Potassium chloride is used as a water softener salt, so you can purchase it at many hardware stores.
The smoke produced by many of these chemicals can be a serious irritant, especially for people with breathing problems. Wear a protective breathing mask while adding chemicals to the fire, and be mindful of which way the smoke is going.
(from: https://www.wikihow.com/Make-Colored-Fire)
/edit]
Cheers,
Tom
p.s. please keep us updated on your progress, and post your images here.
  • · Replies 19 ·
11K
