Photon anti-bunching as necessary for BS entanglement
  • Context: Graduate
  • Thread starter Thread starter sciencejournalist00
    Entanglement Photon
The discussion revolves around the conditions necessary for photon anti-bunching to facilitate entanglement at a beam splitter. Participants explore the nature of light sources, particularly focusing on squeezed light versus classical light, and the requirements for creating entangled photon pairs. The conversation includes theoretical considerations, experimental setups, and the implications of using different types of light sources.
  • Some participants assert that anti-bunched photons, represented by squeezed light, are essential for increasing the probability of entanglement at a beam splitter, while others discuss the role of classical light in this context.
  • There is a proposal that using two single identical atoms can produce entangled pairs, as they generate single-photon states, which are non-classical and squeezed in photon number.
  • Concerns are raised about the practicality of creating indistinguishable photons from laser sources, with some participants suggesting that complex setups are necessary to achieve this.
  • References are requested by multiple participants to support claims regarding the nature of laser light as a mixture of classical and squeezed light, and the conditions for entanglement.
  • Some participants emphasize the importance of filtering out bunched photons using non-linear crystals to achieve entanglement, while others question the sufficiency of the proposed setups.
  • Discussions include the statistical properties of photons, with references to Bose-Einstein statistics and the implications for photon spacing and arrival times.
  • There is a caution against oversimplifying the concepts of photon behavior, particularly regarding the interpretation of individual photons and their states.
Participants express differing views on the necessity and sufficiency of various light sources and setups for achieving entanglement. There is no consensus on the claims made regarding the role of squeezed light versus classical light, nor on the practicality of the proposed methods for generating entangled photons.
Participants highlight the complexity of the physics involved in creating entangled photons and the limitations of simplified mental models. There are unresolved questions about the definitions and assumptions underlying the discussion, particularly regarding the nature of light sources and the conditions for entanglement.
sciencejournalist00
The green dots represent photons in an anti-bunched state, squeezed light.
The red dots represent photons in a semi-bunched state, laser light
The blue dots represent photons in a bunched state, thermal light
The complex setups used in entanglement experiments only squeeze light in amplitude, phase, photon number and filter out squeezed light from classical light before the beam splitter can perform entanglement.
But if you are lucky, you just need two sources of squeezed light, which are usually non-linear crystals but single-photon sources will do too. Maybe in the future they will discover more ways to produce anti-bunched photons.
You also need the photons from the two input beams to be indistinguishable in polarization, frequency, arrival time. Unless you want to use an artificial device that removes these properties composed of two special detectors (not any detector!) that can erase which-path information and a phase shifter.
Do not try to contradict me this time because I have taken nothing out of context, I just found a published thesis which says the conditions for the input light to be entangled by a beam splitter
Given that laser light is a mixture of classical light and squeezed light, a beam splitter could create entanglement with a very small probability, but to increase the probability of entanglement by a large factor, you have to use purely squeezed light
The use of two single identical atoms and a beam splitter is enough to produce entangled pairs because atoms produce single-photon states, which are non-classical light squeezed in photon number.
However, if you use many photons at the same time, you must filter out the bunched photons, which is done by a non-linear crystal.
In practice, to create single photons that are indistinguishable from a laser source you need a setup with many elements to squeeze that laser light and filter out a single polarization, frequency. That is the role that the additional elements play.
In theory or fantasy, you can imagine two ideal light sources which emit identical photons, one at a time, but this kind of source DOES NOT EXIST
Perhaps you have a reference so we could see that context. And perhaps... you have a question about it?
Also, I'd like a reference for this bit, as that contradicts what I always thought.
Really? I don't recall seeing a setup like that previously. I would expect a lot more to get a source of entangled pairs. Can you provide a reference on that too?
https://en.wikipedia.org/wiki/Photon_antibunching
Photons are more equally spaced (more delayed in their arrival time) in squeezed light than in a laser beam, and more equally spaced in laser beam than in thermal radiation
It's about the Bose-Einstein statistics, which makes photons bunch together in pairs. These bunched pairs are filtered by nonlinear crystals
Do I have to repeat that the additional elements just squeeze light and filter it from classical light? Photons cannot be entangled unless the beams that contain them are made indistinguishable, and that is the reason filters and polarizers are used.
Single photon states are Fock states
https://en.wikipedia.org/wiki/Fock_state#Source_of_single_photon_state
Fock states are non-classical, therefore can be used as input to beam splitter
https://en.wikipedia.org/wiki/Nonclassical_light
Setup
http://www.nature.com/nphys/journal/v3/n8/abs/nphys644.html
PDF version http://iontrap.umd.edu/wp-content/u...ton-pairs-from-2-remote-trapped-ions-2007.pdf
Photons are more equally spaced in squeezed light than in a laser beam, and more equally spaced in laser beam than in thermal radiation
Be very, very careful when creating mental pictures like that. You can't strictly speaking talk about individual photons unless you have a Fock state. There is nothing preventing you from talking about average number of photons, but you can't really talk about "spacing" between photons in this case.
It's not me but Wikipedia. Plus photon spacing means delay between their arrival times, not distance measured in meters
Wikipedia is not always correct.
Its pretty obvious, like the process of creating polarised light in a polariser, the detail of what going on in creating entangled photons, requires some rather complex solid state physics. You will not do it via some simple mental picture.
As I said, some rather complex physics.
Thanks
Bill
As I have said repeatedly, you need a lot more to get entanglement. Your referenced experiment is no different. To select the entangled pairs from the entire universe, you need to have a classical signal go from one to the other. That is common for set ups such as this. It is only the pairs with very close arrival times are entangled. No way to know that until you compare information from both sides. I. E. post selection.
  • · Replies 16 ·
  • · Replies 41 ·
