Photon-Foil FTL Drive theory
The discussion revolves around a theoretical faster-than-light (FTL) drive system based on the concept of "photon foils," as proposed by a participant developing ideas for a sci-fi novel. The scope includes speculative physics, theoretical models of astrophysics, and narrative techniques in science fiction writing.
  • One participant proposes that most current theoretical understandings of astrophysics are flawed or overly complicated, suggesting a simpler model of the universe.
  • The same participant theorizes that photons represent a fourth order dimensional substance that connects matter and energy, positing that this could explain limitations on mass acceleration.
  • There is a suggestion that "photonic resistance" acts as a force opposing acceleration to superluminal speeds.
  • The concept of photon foils is introduced as a means to reduce resistance and potentially allow for FTL travel by manipulating photon behavior.
  • Participants express skepticism about the need for extensive technical explanations in the narrative, advocating for brevity and plot relevance instead.
  • Multiple participants agree on the sentiment that excessive detail in the explanation of the FTL drive may detract from the story's engagement.
Participants generally disagree on the balance between technical detail and narrative engagement, with some advocating for less technical exposition and others supporting the exploration of the theoretical model.
The discussion includes assumptions about the nature of photons and the simplification of complex theories, which may not be universally accepted or validated within the scientific community.
DIYEngine235
This is a theoretical FTL drive system that I'm developing for a sci-fi novel. This may be a little convoluted so brace yourselves.
First, I'm assuming that most of the current theoretical understanding of astrophysics is either wrong or incomplete, and possibly over complicated, not unlike aero-physics was prior to 1902 with lots of theories but little to no proof, so I'm fully acknowledging that from the start. I'm also basing this theory on the belief that the universe functions much more simply that what is assumed, on the grounds the Newton managed to simplify all the complex theories of motion into three simple laws. And finally, that there is a bit of scalability/replicability between different mediums of science, such as when Ben Franklin likened electricity moving through a wire to water moving through a pipe or current. Following me so far?
Now, here is where things get more theoretical. I'm postulating that a photon is a fourth order dimensional substance that bridges the gap between matter and energy. (H.G. Wells fans may recognize this a bit.) Following the idea that a point is a null (0) order, a line with one dimension is a first order, a square with two dimensions is a second order, and a cube is of the third order, I theorize that the fourth order must be a photon. I further add that because there is a relationship between the mass of an object and a limit to the velocity of that based on the speed of light, that there is a force acting on that object to oppose further acceleration. With me so far? That force could, therefore, be described as photonic resistance. As in, photons are providing a resistance force that prevents mass from accelerating to superluminal speeds or FTL.
That is, photons bridge the gap between matter and energy at a higher order, having properties of both, but also lacking properties of both, while also interacting with both.
Still following?
Therefore, in order to achieve FTL speeds, you must either remove the photonic resistance and/or use it to accelerate a mass body. I was inspired to this theory by hydrofoil watercraft. The hydrofoil works by removing the majority of the resistance of the water from the body of the boat/ship. Under the fourth order photon theory, this is possible... sort of. This is a sci-fi novel after all.
Here's the gist. Say a ship the size of a C-130 wanted to go from point A to point B, only the distance is about 100 lightyears with dozens of stars in between. The photon foils would allow this to happen by generating a field that would not only repel photons but also accelerate or move them to the rear. Physics being equal and opposite, this would accelerate the ship. As always, there are a few caveats of course.
In order to work, the photon-foil, like the hydrofoil, much achieve a minimum velocity in order to reduce the photonic resistance and before the foil-fields could be used to accelerate the ship to achieve FTL speeds. i.e. your basic main fusion drive of most classic sci-fi space novels. Once a minimum velocity is achieved, photonic resistance drops, and acceleration increased by the photon field projected by the foils forcing protons towards the rear of the ship or pulling the ship to the photons. The jury is still out on which is more accurate. Either way, the ship accelerates.
The photon foils themselves would resemble foils on water or aircraft, though vessels that won't enter atmospheres would have permanent mounts while vessels that would enter atmospheres would have retractable foils. The foils would have to be positioned away from the hull body to allow for a photon-controlling field to be generated.
In my theoretical model, a ship the size of C-130 could achieve speeds equivalent to 30 lightyears per day. I admit, I used Grok to come up with the model, but it seems to work, provided power is generated reliably.
My theoretical model also includes varying photon densities. Stars, of course, would have high density, but the areas between stars would as well, such as where the photons projected by two stars would meet/overlap. These paths would allow for greater efficiency in acceleration without being in a star system.
Rant alert!
I will warn the commenters right now, if anybody tells me that I need to make something glow that isn't a display screen or lightbulb, I will tell them where they can put that glow. That's a particular sci-fi trope I hate.
I get it, for movies and TV, you need to have something to catch the attention. Having a reactor core in the middle of an open space with next to no shielding or protection for the engineering crew, that flashes red when it's about to explode is much more exciting compared to encasing it in a separate, heavily shielded and safe, tube where it can't be seen so it can be easily and safely ejected from a ship before it destroys the ship and without killing the entire engineering crew.
As I said, I get it for a movie or budget sci-fi TV show, but in a novel, there's absolutely no reason why an alien rifle/weapon meant to be used stealthily would glow in the dark!!!
Rant over.
Anyways, I just wanted to get this out there and see if this idea has any real foundation or believable. I see all sorts of warp drives, wormholes or even teleportation FTLs out there, but I wanted something more unique for my novel.
I am always open to ways to improve my FTL physics model to make it more believable.
Why will the reader of your proposed novel be hungry enough to consume this word salad? I would not be. Less is more. Just supply a few croutons and then get on with your tale. Your dear reader needs to be engaged before being assaulted.
I applaud your attempt here. I am incapable of such flights of fancy.....so I am likely incompetent to give writing advice.
  • Agree
  • Haha
I agree w/ @hutchphd --- dump the goble-de-gook and just get on with the story.
  • Agree
  • Haha
Thirded.
As a reader, I know the FTL drive is going to technobabble; I don't need a chapter to describe something I know is fluff.
Give me what is plot-relevant. If your spaceships "surf the photon sea", sure give me one paragraph to get the flavour. And make sure that paragraph does double-duty advancing the story.
  • Agree
Fourthed.
Fifthed. All it needs is the name unless you need to repair the flux capacitating Cohrain coil as part of the story.
  • Agree
Still following?
Rant alert!
Rant over.
I actually quite like it (it's pretty interesting), but most will just want you to condense it. 3-5 sentences, all these ideas at once.
I find it more interesting to start with real concepts and extrapolate a bit to get FTL such as finding an efficient way to create the negative energy necessary to run an Alcubierre warp drive.
Umpteenthed. All of the above.
EDIT: Especially #4 @DaveC426913 ’s advancing the plot double-whammy.
  • Poll Poll
  • · Replies 118 ·
13K
  • · Replies 22 ·
  • · Replies 20 ·
11K
