Mentor
- 23,212
- 7,702
Twich said:I really don't know anything of Quantum Mechanics. I could not understand why the electron only be found in the volume that form by a standing wave form. The standing wave is the result that the electron behave in atom not the causes! Could you suggest an easy (to understand) book or URL ? Thanks a lot
My favorite book on QM is: https://www.amazon.com/dp/1840468505/?tag=pfamazon01-20
It gives the history of the development of QM and the basics of the underlying principles in a very very easy to read and understand form.
I imagine that if there only one electron and one proton in space. They will run to hit the other. If their structure is not changed by the hit and there is no energy loss then the momentum will make them bouncing forever. But I don't know why there is no loss and damages occurred. What is the structure of it or may it need a lot of energy to change their structure.
Put simply, the electron and proton will never travel fast enough just from their mutual attraction to do anything to each other. An electron is considered to be an elementary particle, and not made up of anything smaller, so it is not possible to "damage" it. A proton is made up of quarks, but to do anything to these quarks would take a LOT of energy that only extremely high speeds can deliver. Much higher than simple attract can cause. We use particle colliders to accelerate particles to huge speeds near the speed of light to get them to a high enough energy to actually change/destroy them.
Furthermore when electron and proton move there are magnetic field occurred. Then the electron and proton start to spin because of the magnetic field. So when the electron hit proton it will bouncing to the orbit that it could be stable there. But sometime it will be force to attack proton and bouncing again. Because of spinning made it not symetrical, so it will not move in straight line but orbit around the proton like the cloud. ^^
Sorry, this isn't true at all. One of the big things that stumped physicists in the early 1900's was that if classical physics was correct, the electron should emit radiation and fall into the nucleus within a billionth of a second. This does not happen. This issue was resolved with the development of QM.
Twich said:Since atom always emit EM-radiation, So the electron must lose the energy when collision occurred with enough energy. Thinking about this I come to the conclusion that the atom also need right energy to repair itself. It could only repair itself with correct amount of energy.
Nope, an atom is not damaged in any way whatsoever by it's electrons. Nor does it always emit radiation. Radiation is only emitted from a lone atom when electrons change orbits or something happens in the nucleus, like particle decay.
