Photons collected be telescope apertures
  • Thread starter Thread starter trina1990
    Photons Telescope
The discussion focuses on calculating the number of photons collected per second by a 500mm diameter telescope, given a stellar flux of 5x10^-19 W/m². The calculations reveal that the number of photons collected is approximately 4.4 photons per second, which contrasts with a reference value of 3x10^7 photons per second found in a textbook. The discrepancy arises from an error in measuring the area of the telescope's aperture, which should be calculated using the formula for the area of a circle, πr², rather than including a factor of 4.
  • Understanding of stellar flux and its units (W/m²)
  • Basic knowledge of photon energy calculations using E=hc/λ
  • Familiarity with telescope aperture area calculations (πr²)
  • Concept of apparent magnitude and its calculation (m = -2.5log(F_star / F_vega))
  • Research the calculation of photon flux from stellar sources
  • Study the principles of telescope optics and aperture area
  • Explore the concept of apparent magnitude in astronomy
  • Learn about the limitations of ground-based telescopes in observing faint stars
Astronomy enthusiasts, astrophysics students, and anyone interested in understanding telescope performance and photon collection from celestial bodies.
trina1990
the energy output of a star is such at the surface of the Earth it provides 5x10^-19 WM^-2 in the visible part of the spectrum...
how many photons are collected per second by a 500mm diameter telescope?
i don't know if there's any definite formula to drive the answer...but i tried this way..
stellar flux=5x10^-19WM^-2=5x10^-25 J/S/mm^2
E=hc/lambda joul/photon ( assuming lambda to be 550nm)
then flux/E=1.383x10^-6 photon /S/mm^2
then i found the telescope mirror are to be 4pi (500)^2=3.142x10^6 mm^2
now i derived the number of photons per second collected by the 500mm diameter to be 4.4!
can this be right?
is there any other way to solve this?
Aside from the fact that the area of a circle is \pi r^2 (without the factor of 4), I don't see any problems with your math.
I did some rough calculations, and found that a star with that flux has an apparent magnitude of something like +26. Again, I want to emphasize that this was a very rough calculation. I computed the flux of Vega using its stated luminosity and distance (using Wikipedia numbers), and then took m = -2.5log(F_star / F_vega) to estimate the magnitude. I know that Vega isn't used as the zero point for V band magnitudes anymore, but this was just a back of the envelope calculation to show that you're considering a very dim star. In fact Wikipedia says that magnitude 27 is at the limit of what 8-metre ground-based telescopes can see, so it seems plausible that such a star would be invisible in a 0.5-metre telescope (esp. if your detector is the human eye).
thanks a lot...
the book in which i found this problem showed answer of this problem to be 3x10^7 photons per second...
that's why i got so much stunned with my result...:confused:
but a similar problem with different coefficients shows a result very close to my calculation..
anyway i understood the err of my measuring the area of the aperture...
& with the information you provided from wikipedia, then it's most likely to support the answer...
thanks again
20K
