Physics final prep, question about force under water at depth h
The discussion focuses on calculating the frictional force between a plug and the wall of a horizontal pipe submerged in water at a depth of 6.0 meters. The correct approach to determine the force involves using gauge pressure, represented by the equation F = ρgh * πr², where ρ is the density of water, g is the acceleration due to gravity, and r is the radius of the pipe. The confusion arises from the inclusion of atmospheric pressure in the initial calculations, which is unnecessary since it cancels out when considering the net pressure acting on the plug.
  • Understanding of fluid mechanics principles, specifically pressure calculations.
  • Knowledge of gauge pressure versus absolute pressure.
  • Familiarity with the equations of motion for fluids, including F = pA.
  • Basic geometry for calculating the area of a circular pipe.
  • Study the concept of gauge pressure in fluid dynamics.
  • Learn about the implications of atmospheric pressure in fluid systems.
  • Explore the derivation of pressure equations in fluid mechanics.
  • Investigate real-world applications of pressure calculations in engineering.
Students preparing for physics exams, particularly those focusing on fluid mechanics, as well as educators seeking to clarify concepts related to pressure in fluids.
09jlk
The question states: The fresh water behind a reservoir dam has depth D=15 meters. A horizontal pipe 4.0cm in diameter passes through the dam at depth d=6.0m. A plug secures the pipe opening. (a) Find the magnitude of the frictional force between plug and pipe wall.
Initially when I did this problem I found the pressure at this point with p = p(atm) + ρgh, where h = 6.0 meters. I then used the Force equation F=pA and used the area of the circular pipe with radius .02 meters. So my friction force, which is in equilibrium, should be equal to the force pushing from the water, F= (p(atm) + ρgh) * πr^2.
However, when I look at the solutions manual, they have F = ρgh * πr^2. I'm not sure I understand why this is the case -- it seems to me that they are using the gauge pressure here to determine the force of the water. Why would we use the pressure as ρgh and not p(atm) + ρgh?
That's because there is atmopherisc pressure on the 'dry' side of the plug...'canceling' out the P_atm force part of the absolute water pressure...such that the net pressure on the plug is just the gauge pressure
Ahh, pressing on the other side of the plug. Thank you!
16K
  • · Replies 29 ·
