Physics Forums photography thread and image sharing
- Thread starter _Mayday_
- Start date
- Tags
- Photography Thread
1,418 replies · 269K views
turbo
- 57
You are WAY too crafty, Borek! I gave my wife my old Olympus C-3040, but she only uses it for kids' birthday parties, etc. We have been greatly expanding the flower gardens, so maybe some macro flower/insect shots will tip the scales.Borek said:That's when wife sharing hobby comes in handy![]()
- 7,845
- 4,206
You share your wife? Zounds! :)
Homework Helper
- 6,999
- 299
Sorry if this isn't the right place, but I guess the PF photographers will see it here:
I want to make digital images from about 1000 sheets of A3 size paper (= USA 11x17). This is a "one off" task, so I don't want to buy an expensive A3 size scanner. The paper originals are clean high contrast black-and-white images (actually music scores, hand-written in ink). They are separate single sheets, not bound in a book.
I have a digital camera that is good enough to handlle this. The question is, is it possible to buy (rather than make) a fairly cheap camera stand for this? The easiest way would probably be to have the paper flat on a table and the camera pointing vertically down, so a normal camera tripod won't work. I'm thinking of something like an L shaped arm that would clamp onto the edge of a table, with a mount for the camera pointing downwards. Do such things exist ready made?
My camera has a 10:1 optical (not digital) zoom, so the stand wouldn't necessarily need to be height adjustable.
I'm not bothered about color balance etc so long as the images are "readable", so lighting is not an issue.
Mentor
- 29,216
- 4,648
Can't you put the sheets on the table tilted 45 deg? Resting on a stool or something? Then simple tripod will work. To keep sheets in place you can glue slat of wood to the table, water soluble glues should be later not difficult to remove.
Alternatively you can put the tripod horizontally ON the table - just use some heavy books on the legs.
In my experience makeshift solutions for such tasks are the best
turbo
- 57
You could clamp the camera onto the edge of a coffee table and photograph the pages with the sheets lying on the floor. If you have a relatively bright, sunny room to do this in, it could go pretty quickly. Once you have the camera set to match the aspect of the first sheet, make some "Ls" out of tape to mark the corners of that sheet so you don't have to align every sheet one-by-one.
Mentor
- 29,216
- 4,648
turbo-1 said:make some "Ls" out of tape to mark the corners of that sheet so you don't have to align every sheet one-by-one.
Even better - instead of tape use something sticking out (like two books for a corner, just on one side), so that you don't have to align each sheet to the marks, just push it till it stops touching the edge.
turbo
- 57
Good idea. That would work very well, and would eliminate the need for visual alignment with the tapes. 1000 sheets could go very quickly that way.Borek said:Even better - instead of tape use something sticking out (like two books for a corner, just on one side), so that you don't have to align each sheet to the marks, just push it till it stops touching the edge.
Mentor
- 29,216
- 4,648
In 1998 I moved from bpp.vr.pl to bpp.com.pl. Problem was, I had several thousands copies of booklet to put into CD boxes with one of my programs, and the booklet was printed with the old domain name. What I did was I ordered a self inking rubber stamp "we inform you our new website is at bpp.com.pl" (in Polish). Then I took a piece of plywood, glued two slats to it - so putting the booklet always on the same position was not a problem, and the stamp was pushed against the same slats - which meant all the booklets were stamped in exactly the same position in exactly the same corner. Few hours and all were modified.
I love such witty solutions
Homework Helper
- 6,999
- 299
That nudged my brain in the right direction. I've got an ironing board where the metal wires that make the stand for the iron are the right spacing to locate the camera lens down, without needing to actually clamp it.turbo-1 said:You could clamp the camera onto the edge of a coffee table and photograph the pages with the sheets lying on the floor. If you have a relatively bright, sunny room to do this in, it could go pretty quickly. Once you have the camera set to match the aspect of the first sheet, make some "Ls" out of tape to mark the corners of that sheet so you don't have to align every sheet one-by-one.
Next task: recharging all the available batteries. I'm not sure how many shots the camera will take on one set, but I'm pretty sure the answer is "less than 1000".
Mentor
- 29,216
- 4,648
AlephZero said:That nudged my brain in the right direction. I've got an ironing board where the metal wires that make the stand for the iron are the right spacing to locate the camera lens down, without needing to actually clamp it.
And legs don't come into the sight?
Note that if the camera just lies, you will probably move it slightly with each picture taken (just by pressing the button). That in turn means each sheet will have slightly different position on the picture, which is quite inconvenient and may mean a lot of work later (work that can't be easily automated). Go for something more rigid. Perhaps even just tying camera with a strong cord will work.
Homework Helper
- 6,999
- 299
The paper will be on a low table that overlaps the bottom end of the X-shaped legs.Borek said:And legs don't come into the sight?
It's easy to locate the camera in a fixed position pressed against the wire frame. An elastic band round the camera and the frame might be useful though.Note that if the camera just lies, you will probably move it slightly with each picture taken (just by pressing the button). That in turn means each sheet will have slightly different position on the picture, which is quite inconvenient and may mean a lot of work later (work that can't be easily automated). Go for something more rigid. Perhaps even just tying camera with a strong cord will work.
I'm not too bothered about accurate matching of the positions of each image. The real task is typesetting the music with computer software (which will probably take a few years, given the quantiity and complexity of it). The images aren't going to be published as a facsimile of the original, they are just for displaying on a monitor while doing the transcribing. That will be much less risky than continual handling of the originals (no coffee spills, etc!).
Even if the originals were photocopied to avoid the coffee, physically searching through hundreds of large sheets of paper to find two or three sheets to compare some details side by side, etc, would be much more hassle than working on a computer screen.
Sample page, done to check that the music notation software could handle the job, attached...
Andre
- 4,296
- 73
I got inspired by all that reproduction work and started to digitize my pix of before the digital era. I used a little wooden box and the 45 degrees angle. Allows to stack the pix quickly into the right position. Wow decades of memories.
Oldest daughter, 15 years ago:
Jonathan Scott
- 1,274
AlephZero said:I'm not too bothered about accurate matching of the positions of each image. The real task is typesetting the music with computer software (which will probably take a few years, given the quantiity and complexity of it). The images aren't going to be published as a facsimile of the original, they are just for displaying on a monitor while doing the transcribing. That will be much less risky than continual handling of the originals (no coffee spills, etc!).
There is software available (Neuratron PhotoScore) which will take scans or photos of music and convert it to computer music notation, typically requiring a bit of manual fix-up, but much less work than starting from scratch. I've successfully used the free version that comes with Sibelius, both with photos and with PDFs of old music, but not for anything as ambitious as your example.
You would definitely need a higher resolution than your sample for such software to be able to read the score very successfully.
- 7,845
- 4,206
The new multi-volume book set "Modernist Cuisine" has some *amazing* photos. There's a lot of 'cutaway' shots- a grill cut in half to show what goes on inside, for example- but lots of amazing photos throughout.
http://modernistcuisine.com/
http://modernistcuisine.com/docs/ModernistCuisine_About%20the%20book_spreads.pdf
physics girl phd
- 931
- 3
Andy Resnick said:The new multi-volume book set "Modernist Cuisine" has some *amazing* photos. There's a lot of 'cutaway' shots- a grill cut in half to show what goes on inside, for example- but lots of amazing photos throughout.
http://www.nytimes.com/2011/03/09/dining/09modernist.html" . If only it weren't so expensive... and didn't make me so hungry! What eye candy!
Homework Helper
- 6,999
- 299
I have Sibelius and PhotoScore.Jonathan Scott said:There is software available (Neuratron PhotoScore) which will take scans or photos of music and convert it to computer music notation, typically requiring a bit of manual fix-up, but much less work than starting from scratch. I've successfully used the free version that comes with Sibelius, both with photos and with PDFs of old music, but not for anything as ambitious as your example.
I don't think there is much chance of Photoscore doing anythng useful with this sort of handwriting. Actually this clip is pretty neat compared with some of it!
- 4,206
As I mentioned, I got some good news recently- my NIH proposal was approved for funding- so I decided to spend some of my (non-grant) startup money and get two 'big boy' lenses. They just came this morning, and so rather than do what I'm supposed to be doing, I wandered around campus playing with the new toys.
The first lens is a 15mm f/3.5 rectilinear lens- an ultrawide angle lens. This lens is really good for indoor shots as it distorts the volume of spaces- here's my palatial-sized office:
[PLAIN]http://img848.imageshack.us/img848/8488/dsc5698.jpg
And an indoor commons area:
[PLAIN]http://img600.imageshack.us/img600/8067/dsc5699v.jpg
I also took a shot inside of an elevator- it's not very good, but it shows the distortion effect fairly well. The elevator can hold at most 5 people, it's like 3' x 3'.
[PLAIN]http://img600.imageshack.us/img600/1513/dsc5702j.jpg
This image shows some of the challenges of this lens- the blue blobs at the bottom are flare from the overheard lights, and the vertical lines aren't quite vertical- the huge angle of view makes alignment super critical- both pitch and yaw angles, but also centering. But, I got this lens both because of the huge field of view/depth distorition and that it is a *rectilinear* lens- there is no distortion (in the lens aberration sense).
The other lens is a little intimidating, frankly- it's a 400mm f/2.8. I found an older manual focus version, so I could afford the freaking thing- the front element is about 6" in diameter, and the lens is *really* heavy. I also picked up a 2x teleconverter for it to also use it as a 800mm f/5.6- why not? It close-focuses to 10', so it's practically a macro :)
It's an outdoor lens, and since it's raining today I won't be able to use it. So, I have time to check that my tripod can handle the weight...
In other news, I've been carefully stripping down the crackberry's LCD display- there are some really weird lighting elements that I've been trying to understand, and when I do, I'll post those pics.
- 4,206
Finally- we have sun outside. I took my 'new' lenses out for a test drive- here's the 15mm, full frame and then 100% crop:
[PLAIN]http://img856.imageshack.us/img856/1071/dsc57451.jpg
[PLAIN]http://img196.imageshack.us/img196/1316/dsc5745.jpg
And here's the 400mm, full frame and 100% crop:
[PLAIN]http://img718.imageshack.us/img718/9855/dsc57461.jpg
[PLAIN]http://img856.imageshack.us/img856/1184/dsc5746.jpg
The nikon-sony adapter has some slight vignetting at long focal lengths (which I knew about, it's the cost of doing business...), but even so, the image is quite impressive- the thermal lensing is clearly visible.
Adding the 2x teleconverter increases the vignetting considerably, but even so:
[PLAIN]http://img251.imageshack.us/img251/9561/dsc57471.jpg
[PLAIN]http://img690.imageshack.us/img690/4407/dsc5747u.jpg
"lens shake" is extreme with this lens- except it's not the lens exactly- it's the camera flopping up and down. I used the 10-second timer delay to get (reasonably) crisp images. If the weather hold up, I'll try taking some images of the moon tonight.
- 4,206
Got a really nice shot of the moon last night:
[PLAIN]http://img233.imageshack.us/img233/4696/dsc58161.jpg
[PLAIN]http://img8.imageshack.us/img8/523/dsc58162.jpg
The settings were 800mm f/5.6, ISO100, 1/125s exposure.
The star photos were not acceptable. Seeing was mediocre at best, and even though I got excellent separation of Alcor and Mizar and may even have resolved Mizar as a quadruple, it's not clear due to vibration issues. At extreme blow-up, there is some purple fringing (spherochromatism), but I'm reserving judgment until my technique is 'up to spec'- getting tack-sharp images with this lens is not easy, even when the view is spectacular through the viewer.
After working with the lens for a while, the main residual problem seems to be due to 'mirror flap'- I'll try locking the mirror up first, waiting a few seconds, and then use a remote shutter to trigger- I ordered the remote last night. On the plus side, the lens has almost no flare- here's the sun, about 30 minutes prior to sunset:
[PLAIN]http://img684.imageshack.us/img684/3091/dsc5806g.jpg
The settings were 800mm f/22, ISO 100, 1/2500s exposure, HDR enabled and set to maximum.
I ordered a couple large sheets of polaroid- it would be nice if I could see sunspots.
- 4,206
Borek said:Have you tried higher ISO and shorter times?
I usually stick to ISO 200 and slower because the Sony Exmor is very susceptible to amplifier noise. The noise is noticeable at ISO 400, and annoying at ISO 1600. That's one of the reasons I prefer fast lenses- it's easier to throw photons away than it is to scavenge every last one.
That said, I could take an image at ISO 6400 and after re-scaling it to 650x480 you would never know how much noise there is; I can work in the ISO 400-1600 range and smooth the image later to get acceptable results at 100% crops.
Now that the weather is nicer, I can spend some time outside taking nighttime shots with the goal of improving (reducing) camera shake. I'm hopeful that using a remote shutter will fix the majority of the problem.
Andre
- 4,296
- 73
Yes the noise is indeed an issue, but using high ISO is just another trade off, if you like to shoot tele or macro handheld in a dynamic environment of moving subjects and you like low ISO's for the lack of noise, you run out of options even in fair light conditions. Then it would nice if say F16 and 1/1000 sec could be done, but you might need ISO3200 to accommodate that.
In that case, one would currently like the Nikon D3S best, closely followed by the quicker Canon 1D mkIV
But you could also buy a decent car for that money,
Mentor
- 29,216
- 4,648
Andy Resnick said:Now that the weather is nicer, I can spend some time outside taking nighttime shots with the goal of improving (reducing) camera shake. I'm hopeful that using a remote shutter will fix the majority of the problem.
It is either the shake or atmosphere, we have discussed it earlier. I was surprised several years ago by the sharpness of Moon images taken at very short times.
- 7,845
- 4,206
Andre said:But you could also buy a decent car for that money,
Too true.
- 7,845
- 4,206
Borek said:It is either the shake or atmosphere, we have discussed it earlier. I was surprised several years ago by the sharpness of Moon images taken at very short times.
Based on the star images, I suspect my main culprit is mirror flap- the stars consistently got distorted into short lines, even for 1/10 second shutter speed- and the lines were always the same length and orientation (of course, I didn't change the orientation of the camera to check this last night).
