Physics Forums photography thread and image sharing
- Thread starter _Mayday_
- Start date
- Tags
- Photography Thread
1,418 replies · 254K views
Andre
- 4,296
- 73
Borek said:Please let us know how it works. Seems cheap.
Sure, happy to.
Until now I managed with a single 8gb Extreme Sandisk 60MB/s (400x), nice and fast. Sure enough using standard RAW and the occasional movie, it fills up fast, but I always travel with my laptop and an additional external harddisk, so I emptied the card very frequently to process the pix and back them up on the external harddisk.
However, should the card fail somehow -and I lost several SD's in the past-, I'm stuck, so it's more for redundancy than for lack of storage to have a second card and then this 32Gb seems to be the most bang for the buck.
Mentor
- 29,211
- 4,638
I have two 8GB cards (as explained earlier - Kingston Elite Pro, nominally 133x but in reality faster). With a laptop and external HDD that's perfectly enough for pictures, but not enough for HD movies, and I plan to shot some. Unfortunately I won't be able to buy anything more before leaving Warsaw for vacations. I sold one of the 16GB cards, I plan to use other for pictures - while it is too slow for movies, as long as I don't shot more than a picture per 2 sec that shouldn't be a problem (especially taking into account buffer built into camera). For fast situations (sport/bird pictures) it won't work.
Mentor
- 29,211
- 4,638
Sorry, no strawberries.
(For newcomers: larkspur was a user at PF, active up to about two years ago. Her pictures were always great, one of them was a picture of strawberries in the rain - in a way similar to what I took today. Unfortunately, her pictures are no longer hosted at old urls.)
fuzzyfelt
- 4
No apologies necessary (IMO), it is wonderful without strawberries!
Andre
- 4,296
- 73
The card just arrived, it's in the camera. Burst in RAW+JPG roughly on par with the sandisk card, that is, after the first 6-8 shots the rate goes down to maybe 4 frames per second. Movie mode seems fine too.
Andre
- 4,296
- 73
Update
I downloaded the evaluation version of flash memory toolkit and did a read test with both cards (write test blocked). Both claim to be 400x with reading (up to) 60MB/s for scandisk and 90MB/s for the Transcend.
On my computer though, it was 16.7MB/s average for the old Sandisk and 18.8MB/s for the new Transcend. Not what you expect but it compares better
Edit:
Of course you can test write speed too just by writing. So I formatted both cards and then wrote a 1.05 GB big folder containing 45 pix to each.
A modern duracell 8MB USB memory stick required 3:19 minutes for that or 5.3 MB/s, the scandisk was ready in 1:38 minutes (10.7 MB/s) and surprisingly the Transcend 1:06 minutes (15.9 MB/s)
Verdict: it's a keeper, the scandisk is now permanent reserve.
Edit:
Mentor
- 29,211
- 4,638
Thanks for the update. I see them here as well, unfortunately, I won't be able to buy one before leaving (it won't arrive in time).
So far your tests confirmed speed, let's hope it will be also reliable. I am always afraid of things substantially cheaper than equivalents.
Andre
- 4,296
- 73
Borek said:Thanks for the update. I see them here as well, unfortunately, I won't be able to buy one before leaving (it won't arrive in time).
Yes I know the feeling, but it is just a feeling. Maybe, if you aren't a famous brand, you'd have to compete both with quality and low budget prices. I've seen a lot about that in the jeans branch.
So I am not pessimistic but I'll download the pix frequently.
Andre
- 4,296
- 73
Andre said:Thanks Turbo
Here is a small selection. I just happened to shoot them this evening, unaware of this thread. The dog loved to play model and I got her all over me after the dash, every time, when I was laying there on the ground.
We won!
http://www.dpreview.com/challenges/Entry.aspx?ID=477595
- 7,819
- 4,145
I had to get a 'new' image processing program (GIMP, while possibly the *worst* name ever, is available free at http://www.gimp.org/) in order to submit a paper to PLoS, and it does some things that ImageJ does not- one thing in particular is a 'perspective tool'.
Recall that, given a fixed 35mm image format, lenses with a focal length equal to 50 mm provide images with perspective matching human vision, while lenses with shorter focal lengths provide exaggerated perspective and lenses longer than 50mm reduce the perspective.
Here's an example: I used a 15mm lens to take a photo of Cleveland's tallest building, the Key Tower with 57 stories and almost 1000 feet tall:
[PLAIN]http://img836.imageshack.us/img836/9895/dsc70402.jpg
The short focal length let's me get the whole building in the frame, but because of the increased perspective distortion, the building appears to recede rapidly into the distance, much more that it appears when looking at the building by eye. Of course, you can't fit the whole building on your retina unless you stand much further away from the building than I did here, which is why I used a wide angle lens to begin with.
Using the perspective tool, I can mimic the effect of using a tilt-shift (or long focal length) lens- parallel lines remain parallel:
[PLAIN]http://img546.imageshack.us/img546/3540/dsc70401.jpg
This image is impossible to obtain 'naturally'- in order to flatten the perspective this much by using a telephoto, I would have to stand so far back that the view would be obstructed by other buildings. Although Canon makes a 17mm tilt-shift lens (http://www.luminous-landscape.com/reviews/lenses/canon-17ts.shtml), I'm not sure it could move enough to accommodate this building. A telecentric lens would need to have a front element 1000 feet in diameter to take this image.
An important reason I was able to perform this manipulation is that the lens has no distortion- straight lines remain straight. That's a major reason I got this particular wide angle lens (Nikkor 15mm f/3.5) instead of other wide angle lenses.
I like the result- the building looks normal and different at the same time. I'll be on the lookout for other opportunities to try this out- lighthouses could be very compelling subjects, for example. The Statue of Liberty would be *excellent* since it's so iconic, but I don't know when I'll be in the city next.
Andre
- 4,296
- 73
Nice Andy, indeed a great result making lenses worth a fortune obsolete.
I also use Gimp sometimes, with a HDR plug in.
Nowadays Canon's software Digital Photo Professional (DPP) can apply lens corrections for the lens errors dedicated per lens, the peripheral illumination, chromatic abbaration, distortion and color blur.
Also, standard lens 50mm for 35mm film format (FX) yes that is the common assumption. However the focal distance of the standard lens (normal lens) is defined as equal to the diagonal size of the film or sensor format and the image diagonal of full frame FX is 43.3 mm
- 7,819
- 4,145
Andre said:Nice Andy, indeed a great result making lenses worth a fortune obsolete.
Thanks- and I agree that there's nothing objectively correct about calling a 50mm lens 'normal'.. what's normal? :) I've read screeds on a few Nikon pages that go on about 55 mm lenses. The bottom line is how the printed/displayed image compares to how the naked eye views the object.
- 7,819
- 4,145
an alternate edit of the photo I submitted this week:
[PLAIN]http://img9.imageshack.us/img9/996/dsc86757.jpg
This image has been manipulated enough to disqualify it as a submission, but I like the 'discomforting' aspect of the image. I should set this as my desktop pic.. :)
khemist
- 248
- 0
Andy Resnick said:Thanks- and I agree that there's nothing objectively correct about calling a 50mm lens 'normal'.. what's normal? :) I've read screeds on a few Nikon pages that go on about 55 mm lenses. The bottom line is how the printed/displayed image compares to how the naked eye views the object.
50mm is normal because it is almost the same magnification as your own eye. However, if you are on a crop sensor you will not see 50mm with a 50mm lens, rather you will see ~80mm.
The more you pay = the sharper your photos are. Goes for tilt shift too...
- 7,819
- 4,145
Speaking of tilt-shift lenses, here's another corrected image:
[PLAIN]http://img3.imageshack.us/img3/9803/dsc5866a.jpg
This building has fascinated me for years- it's a bombed-out hulk that's been abandoned for at least as long as I've lived in Cleveland, sitting in the middle of a high-priority redevelopment zone. A glorious example of urban decay.
- 4,145
Driving by the building on my way home today, I realized I didn't fully correct the above image. While I did correct for perspective (lines that are parallel in depth are not imaged as parallel lines), I did not correct for the angle between the optical axis and the wall of the building- the aspect ratio of the building is incorrect. Here's the effect of correcting for that, so that the line of sight appears perpendicular to the building:
[PLAIN]http://img14.imageshack.us/img14/9803/dsc5866a.jpg
It's apparent something's wrong- parts of the building that are closer than the main wall (the central and right-side projections) have a different magnification. I'm not sure I can fix that...
- 4,145
I worked with the above image in GIMP to produce this:
[PLAIN]http://img34.imageshack.us/img34/2471/dsc58661telecentric.jpg
This image has been (crudely) manipulated to produce a telecentric image of the building: there is constant magnification with object distance. The foreground is now out of scale to the building (those telephone poles are not 80+ feet high...), and the wires don't line up like they should.
To produce an image like this without digital manipulation, you would need a telecentric lens about 300 feet in diameter, with a working distance of 200 feet: an f/0.6 lens the size of a football field. But then the foreground would be in proportion...
redpenguin
- 9
- 0
Long exposure.
sourlemon
- 52
- 1
^redpenguin, that's gorgeous! What did you take a picture of?
redpenguin
- 9
- 0
I actually turn all of the lights out in my house and just take a picture of my television. This particular movie was Red Cliff (which is an awesome John Woo movie if you haven't seen it). Sometimes I get lucky.. most others I don't. But I have noticed that there is a method to the madness.
Couple other examples (sorry for the size of some)..
Morgan Freeman:
Pretty Lady:
Time:
Is there a sixth sense?:
Morgan Freeman:
Pretty Lady:
Time:
sourlemon
- 52
- 1
Really? Wow, that's amazing. I have to try it out.
I didn't see Red Cliff. But I have to add it to my list. I have a soft spot for Tony Leung :)
I really like the first one you posted and the pretty lady. Never would have guessed that was taken by a camera. I would have said you did some image manipulation.
redpenguin
- 9
- 0
Yeah.. beats being bored at home doing nothing.
Red Cliff is epic! Prepare yourself for a 4 hour journey if you do get around to it. (Best version is in Mandarin with English subtitles)
sourlemon
- 52
- 1
Random pictures I took over the summer. There should be more since I'm going camping tomorrow :)
NileQueen
- 105
- 1
Nice!
- 7,819
- 4,145
sourlemon said:Random pictures I took over the summer.
Nice shots! Here's some of my summer vacation pics:
[PLAIN]http://img405.imageshack.us/img405/82/dsc9162d.jpg
[PLAIN]http://img717.imageshack.us/img717/2448/dsc9165i.jpg
[PLAIN]http://img825.imageshack.us/img825/8903/dsc9693.jpg
[PLAIN]http://img542.imageshack.us/img542/3144/backscatter2.jpg
[PLAIN]http://img827.imageshack.us/img827/251/dsc9870.jpg
[PLAIN]http://img7.imageshack.us/img7/5906/dsc9193y.jpg
Anybody else?
- 4,145
Bleargh! some of these look like $hit on my Mac. If you'll pardon the following, so I can compare them across my monitors, hopefully I'll get some insight about what is going on.
[PLAIN]http://img638.imageshack.us/img638/7787/dsc9870w.jpg
sourlemon
- 52
- 1
andy, the beach looks so blue! where did you go? Lovely picture. Cute baby.
- 7,819
- 4,145
sourlemon said:andy, the beach looks so blue! where did you go? Lovely picture. Cute baby.
We spent a glorious week in the North Carolina Outer Banks (Hattaras, specifically)- we were there last week, and have been following Irene with some concern. It's weird to think about what is going on there right now...
The girl is my youngest (4 y.o.)- she ain't no baby- she's mad that you said that, but you got redemption points for 'cute' :)
Andre
- 4,296
- 73
Nice work Andy,
Some of mine (not really holiday, but anyway)
Playing with bokeh:
And for the cuteness factor, the daughter of a niece:
(in available light with ISO 3200 - see EXIF)
Furthermore, currently the last 7 pictures in my album here are all from the last three weeks on my mission in France
Playing with bokeh:
