How Do You Calculate the Charge of a Point Charge Near a Charged Plane?
  • Thread starter Thread starter Nimmy
    Midterm Physics
The discussion focuses on calculating the charge of a point charge 'q' hanging from a string at an angle due to gravity and electrical attraction from a nearby infinite conducting plane. The user correctly breaks down the forces acting on the charge, using equations for force components in both x and y directions. They derive the tension in the string and the electrical force but struggle with calculating the charge 'q' using the formula F = qE. Clarifications are provided regarding the electric field generated by the conducting plane, emphasizing that the electric field inside the conductor is zero and that the correct formula for the electric field is E = σ / (2ε₀). Ultimately, the user arrives at different values for 'q' based on their calculations, indicating confusion about the application of the electric field formula.
Nimmy
A point charge 'q' hangs motionless from a mass less string at an angle, due to the forces of gravity and electrical attraction with a nearby infinite conducting plane of charge.
Conducting wire sigma = -3.0 E -8 String is next to the conducting wire with a angle
a. If the mass of 'q' is 4.00 E -6 kg, and it hangs at angle of 25.0 degrees with the vertical, find the charge 'q'.
Using the equations, that I learned from mechanics. I broke up the force components in x and y direction.
∑ Fx = Fe - T sin 25º = 0
∑ Fy = T cos 25º - mg = 0
T = mg/cos 25º
T = (4.00 E-6 kg) (9.80 m/s^2)/cos (25º) = 3.55 x 10^-5 N (I wrote N on my test and he crossed that out)
Electrical Force = T sin 25º = (3.55 x 10^-5N) sin 25º = 1.50 x 10^-5 N
Now I am lost on how to solve for q. Can you pinpoint where I am making errors and also direct me on how to solve for q? Because on my test I got half of the points.
How would you sketch an electric field diagram of 'q' and 'sigma' ? Also, where would the net electric field be exactly zero?
Ok for part a...is the process right
so since I already found what Electrical force is. I can just use F = qE ...which means q= F/E ...So I plug in F which I found already and E = Sigma/2 Eplison knott. Since we got the sigma value. But when I solved it I got q = -8.85 x 10^-9 C. Is that right?
T = mg/cos 25º
Draw a diagram and I would think you would discover that the ratio of the Forces - Gravity down to Electrostatic to the E-Field will be given by
Felectro / Fgravity = Tan25
F = qE
should deliver the right answer if you have the proper F.
LowlyPion said:
F = qE
So the E is E = sigma/2 Epslion knott?
Conducting plane or conducting wire?
I don't understand this statement:
If it is a conducting plane your formula would be correct.
LowlyPion said:
I don't understand this statement:If it is a conducting plane your formula would be correct.
Yup a conducting plane of charge. I was trying to explain the diagram. Thanks though! :)
I have one question is the net electric field zero at the center of the conducting plane?
OK. That should be good to go then.
And the conducting wire is from what? Did you mean to write plane? Because if you have a wire you need to know r from the wire, which I don't see in the problem as given.
Yes there is no conducting wire...it's a conducting plane of charge. Plus there was no radius given. But can you answer where the net electric field is zero in this problem? B/C I though it was at the center. But I got ding -10 points on the exam.
The E field is 0 inside the conductor.
As to the E-field, I think I misspoke. I think it should be σ / εo
see:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gausur.html#c3
see:
so it just should be 1/2 of the value that I got before right? Oh is the E field zero inside the conductor because the E field go in and out of the conductor cancel out at the center?
Wouldn't it be twice?
Didn't you say σ /2 εo ?
That would be for a capacitor I think.
In a conductor the charge is at the surface. Inside the conductor any Gaussian surface you draw that does not contain the surface must result in a 0 field, because there would be no charge within the closed surface.
Well, because I got 1.50 E -5 N for the Electrical Force. sigma = -3.0 E -8 C/m^2)
Now if it was 2 εo
q= F/E = (1.50 E -5 N)/(-3.0 E -8 C/m^2 /2(8.85 E -11 N/m) = -8.85 E -9 C
Now if The E Field = σ / εo
So ...q =F/E = (1.50 E -5 N)/ (-3.0 E -8 C/m^2 /(8.85 E -11 N/m) = -4.43 E -9 C
Thats why I said half the value.
  • · Replies 21 ·
