Physics momentum and acceleration
12 replies · 4K views · last reply
troy132
You throw a 0.42-kg target upward at 15 m/s. When it is at a heigh of 10 m above the launch position and moving downward, it is struck by a 0.338-kg arrow going 27 m/s upward. Assume the interaction is instantaneous.
a)What is the velocity of the target and arrow immediately after the collision?
b)What is the speed of the combination right before it strikes the ground?
Not a homework problem. This is practice questions for an upcoming midterm and I am not sure how to go about this. An answer with an explanation would be great but if all you can provide is an answer I would be grateful.
I am not sure where to begin. Conservation of momentum maybe? but even with that I am not sure how to bring gravity into it.
Even for practice questions, the rules of PF state that the poster is responsible for providing his own solutions. Once you do that, if you get stuck or want to know if you've done things correctly, other members can then offer comments and suggestions.
So, you've thrown the target upward at a certain initial velocity. It's now falling back to earth. What's the velocity of the target when it's 10 meters off the ground?
For part A I need to find the velocity immediately after the instantaneous collision
Yes, but first you need to determine the velocity of the target, as it is falling back to earth, when it reaches 10 m above the ground.
You can't calculate the combined momentum of the target and the arrow if you don't know the velocity of the target. :sorry: :wink:
Ok how in the world do I do that? What I think I need to do is find the max height it reaches, from there I am not too sure.
Have you studied anything about objects being thrown up in the sky? Projectile motion? Gravity?
Yes I have. Gravity is constant 9.81m/s downwards, the part I am struggling with is finding velocity on its way down. Am I on the right track by determining its maximum height?
That's a start.
Ok i have calculated the max height to be 11.47 meters. Now i find the velocity its traveling when it falls the distance of 1.47 m?
Yep. You want the velocity of the target when it is 10 meters off the ground.
Ok I've found velocity to be 5.366m/s by vf^2=vi^2 + 2ad and then found time using v=d/t and solving as 0.27 seconds. I am not too sure what to do from this point. Does time help with anything or is it an unnecessary value
Update: Just worked around a bit and i think i got the answer. Do you get 9.1m/s in your calculations?
I'm not following what you did here. You can't use v = d/t here because velocity is not constant.
What's the velocity of the target when it reaches the highest point above the ground?
The target falls a distance of 1.47 m from this point. Does it seem reasonable that it would reach a velocity of 5.37 m/s in this short distance?
