Physics of a Syringe: Surface Tension & Water Retention
  • Context: High School
  • Thread starter Thread starter Da Apprentice
    Physics Syringe
The discussion revolves around the physics of how water remains inside a syringe when it is drawn in, exploring concepts such as surface tension, air pressure, friction, and the nature of vacuums. Participants examine various factors that contribute to the retention of liquid in the syringe, including theoretical and practical implications.
  • Some participants suggest that surface tension plays a role in keeping the water inside the syringe.
  • Others argue that air pressure is the primary factor, stating that the pressure difference between the inside and outside of the syringe prevents the water from leaking out.
  • One participant mentions the importance of friction between the plunger and the syringe walls, noting that this friction can inhibit movement and contribute to the retention of the liquid.
  • Another viewpoint emphasizes that a syringe creates a vacuum effect, which some participants challenge by discussing the nature of vacuums and their properties.
  • A participant points out that the contents of the syringe are in direct contact with the plunger, suggesting that the interaction between them affects the retention of the liquid.
  • One participant shares an experimental observation regarding the behavior of different liquids, indicating that surface tension varies with different substances and affects how they behave in the syringe.
Participants express multiple competing views regarding the mechanisms that keep water inside the syringe. There is no consensus on the primary factors involved, as different explanations are presented and debated.
Some claims rely on assumptions about the behavior of liquids and the nature of vacuums, which may not be universally accepted. The discussion includes various perspectives on the interplay between surface tension, air pressure, and friction, but these aspects remain unresolved.
Da Apprentice
I was wondering, why is it that when water is "sucked up" by a syringe that this water stays inside the syringe and doesn't leak out?... Is this because of the surface tension of the water?
Hi Da Apprentice! :smile:
No, it's because of the air pressure pushing upwards …
total force upward = pressure times area, and that's more than enough to balance the weight, if the tube isn't too long. :wink:
Actually, I believe it is more complicated than that. Water tends to stick to the walls of it's container - this is why you see the edges in a glass of water climbing up the sides a bit. And because of surface tension, it doesn't like to form really 'small' volumes - this is why if you spill water, it tends to come out in drops and puddles rather than spreading totally evenly.
Put those together, and it would take a lot of extra energy to force the water down the thin needle.
Nobody has mentioned the friction between the syringe plunger and the syringe walls. Disposable syringes consist of a rubber tipped plunger within a plastic barrel, and the friction is quite considerable, preventing unwanted movement of the plunger. Precision syringes consisting of ground-glass plungers and barrels can often discharge the contents on their own as the resistance to movement is quite small.
I think the explanations here are flawed.
A syringe in effect is a vacuum. In the closed position put your finger over the tip and try to pull the handle on the syringe.(note even if you pull it up, when you let it go it comes back down).
And we know that air vacuum's(physics not the household applaince) don't exist except in space. space is a vacuum
The idea is that a medium,(water/air etc.) that you suck up won't spill back out because of the suction created by the vacuum in the syringe.
This is what tiny-tim was saying above, just in different words. The air pressure from outside the syringe is too great compared to the pressure inside the syringe for it too fall out.
Blaze_409 said:
… The idea is that a medium,(water/air etc.) that you suck up won't spill back out because of the suction created by the vacuum in the syringe.
Vacuums (like black holes :wink:) have no sucky-power.
Vacuums have lots of nothing
in this case, no pressure …
so no downward force on the column …
that's all! :smile:
that's all! :smile:
I don't understand the logic. A full syringe held vertically by the barrel will not (generally) discharge the contents. If the plunger is free to move, the plunger will fall due to gravity and the contents will be discharged. The reason the plunger stays is due to friction between the plunger and barrel.
Try it and see- fill the syringe with air and observe what happens. Fill a precision syringe with air and see what happens.
Yes, obviously the contents won't stay unless the plunger stays :smile:
friction holds the plunger, but the plunger doesn't hold the contents :wink:
(but on reflection, i think i was too quick to agree to the vacuum suggestion …
i think the contents usually are in direct contact with the plunger, but that the reaction force between them is reduced to area times atmospheric pressure minus weight)
IHMO, Andy has is right.
The friction of the plunger seal inhibits plunger movement in the primary AND reverse direction. The reverse direction "holding" force is greater than the atmospheric or internal pressure to expel syringe contents.
Case closed.
Next patient...
It's a combination of the surface tension AND the pressure difference. Try filling a syringe from the rear with no stopper and nothing covering the needle. Very little of the water will drip out from the needle. If you were to put something with less surface tension into the syringe, mineral oil for example, then you would have to clean up the mess you just made. I know this because I had to clean up just such a mess.
  • · Replies 26 ·
  • · Replies 26 ·
  • · Replies 32 ·
15K
  • · Replies 16 ·
