Finding the Value of M in a Physics Homework Problem
  • Thread starter Thread starter Julieh
    Physics
The discussion centers on a physics homework problem involving the calculation of heat transfer between ice, water, and steam. Participants clarify the equations for heat gained by the ice-and-water system (Q1) and heat lost by the steam (Q2), emphasizing the importance of correctly applying the specific heat and latent heat values. There is confusion regarding the negative mass result obtained, which is addressed by reviewing the calculations and ensuring proper understanding of the thermal equilibrium concept. The conversation highlights the need for accurate expressions and relationships between Q1 and Q2 to solve for the mass of steam (M) correctly. Ultimately, the correct approach will yield a positive mass value for M, reflecting the physical reality of the scenario.
Julieh
Suppose that 0.250 kg of ice and 0.300 kg of water in thermal equilibrium are heated to 60°C by being mixed with M kg of steam at 100°C. Use Lice melting = 3.30 x 105 J/kg, Lwater vaporizing= 2.30 x 106 J/kg, and cwater = 4.2 x 103 J/kg°C.
(a) Write an expression for Q1, the heat gained by the ice-and-water system. Be sure to include the heat involved in both melting the ice and raising the temperature of the melted ice and water
Write an expression for Q2, the heat lost by the steam. Include both the heat to condense the steam and to lower the temperature of the resulting liquid water. (3)
(c) Equate the sum of the expressions from (a) and (b) with zero, and find the value of M. How much water will be in the final mixture
heat gained=heat lost
q1=Mice*Lice+Cwater*Mice*change in temperature
q2=Msteam*Lvaporization+Cwater*Mwater*Change in themperature of water
when i sum up the equations together and equate them to 0 the answer that i got is -0.1 kg, and mass can not be negative
Hello Julie, ##\qquad## :welcome: ##\qquad## !
Hope you'll find the sub- and superscript buttons soon :smile: -- they look like x2 and x2 to the right of the camera icon
Please show your work (the equations that yield a negative mass) and we'll take it from there
Q1+Q2=0
and then Q1 is :[0.250kg*(3030*10^6)+(4.2*10^3)*0.250*60] and i added Q2:[(M*2300000)+(4200*0.300*40)]
and when Q1+Q2=O
it will be :82500+63000+M2300000+50400=0
M2300000=-195900
M=-195900/2300000
M=-0.85
M=-0.1KG
With these
buttons you can write sub- and superscripts. Please use them...
I would agree with the 0.250 kg * ( 3.30 x 105 J/kg ) to melt the ice.
I don't understand what (3030*10^6) stands for
(4.2*103)*0.250*60 is the heat to bring the water from 0##^\circ## to 60##^\circ##, but: what do you do with the ice that has melted ?
The
BvU said:
With these View attachment 240265 buttons you can write sub- and superscripts. Please use them...
(4.2*10^3)*0.250*60 is the heat to bring the water from 0##^\circ## to 60##^\circ##, but: what do you do with the ice that has melted ?
The melted ice turns into water which will be heated and change into steam which is in gas form
That's not what the scenario describes: it says melted ice + water are heated to 60##^\circ##
the way i understoond it , its like the ice and water are in equlibrium, meaning they have same or equal temperature and they are now being heated at 60 degree celcius to a steam
or what is in your opinion?
It's not an opinion: it's what the problem statement describes.
You begin with
and they
are heated to 60°C
in dadada way
No, nothing is changed into steam. Steam is added to the ice and water mix, melting the ice and condensing the steam, with the whole ending up as water at 60°C.
Ha haru ! Bedtime for me :sleep: , glad you're here !
now how is Q1 equation and Q2 equation look like?
i am still not getting it . but we can continue tommorow , have a blessed night
The only problem with Q1 and Q2 individually is the erroneous 3030x106 in Q1 that @BvU mentioned.
The other problem is what you did with these two expressions. Q1 is the heat gained by the ice and water mix, while Q2 is the heat lost by the steam. What will be the relationship between those two quantities?
  • · Replies 17 ·
