Physics Q&A Game: Exploring Faraday's Law with Marcus' Polar Route Question
The forum discussion centers around a physics question regarding the induced voltage difference between the wingtips of an airplane flying a polar route, as posed by user Marcus. The consensus is that, according to Faraday's Law, the induced voltage should be zero since neither the area (A) nor the magnetic field (B) is changing during flight. However, users Tyger and damgo clarify that a voltage can be induced when the plane takes off and that it can be measured on the ground with an electrometer. The discussion also touches on the Hall effect and the Lorentz force, emphasizing the complexities of measuring induced voltage in a moving conductor.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with the Hall Effect in physics
  • Knowledge of the Lorentz Force Law
  • Basic concepts of electrometry and voltage measurement techniques
  • Study the applications of Faraday's Law in real-world scenarios
  • Explore the Hall Effect and its implications in electrical engineering
  • Research the Lorentz Force Law and its role in electromagnetic theory
  • Learn about advanced electrometry techniques for measuring induced voltages
Physics students, electrical engineers, educators, and anyone interested in the principles of electromagnetic induction and their practical applications in aviation and other fields.
  • #31
Well, hell, Ivan, machine reliability clearly includes this.
In fact, cosmic ray strikes are the most common cause of single-bit errors in modern computer memories -- hence the common SECDED technology -- "single error correction, double error detection." I was thinking "cosmic rays" the entire time, but thought that "machine reliability" included it!
The advance of satellite technology, I thought, had made the cosmic ray argument well-known.
When you said a "physical reason," I thought you meant something about the problem being solved -- not something about the physical machine. :)
In any event, it is certainly an interesting thing!
Why don't you ask another question?
- Warren
  • #32
- Warren
Since Tyger included the specific reference to breakdowns, I tried to point to his answer but felt that he was otherwise off course.
Darn. That may be the only other interesting thing I have ever learned. O.K. How about this, I should say up front that I have an answer, but my confidence in this answer is not quite 100% [comes from a so-so professor]. So I will play this one by ear. At some appropriate point I will interject my two cents worth.
The total force due to friction between two materials is calculated as the normal force times the coefficient of friction between the materials. Why do racing cars use wide tires?
  • #33
This is what I was not sure about. Since I have heard little discussion about this topic outside of NASA, I feared this could be an extremely obscure argument, or that this proof may have been a cosmic error! I was waiting to get run up the flag pole after giving my answer!
  • #34
that easy!? greater surface area ensures that it is harder to reach the static coefficiant of friction.
am i right?
  • #35
am i right?
I don't think I understand your answer. Can you splain.
  • #36
pressure of the tire to the surface is force exerted per unit area. the normal force is not a point source force but one distributed evenly over the area of interaction. greater area means more friction // less slipping.
  • #37
The frictional force f is calculated as μN. Where N is the normal force [the weight of the car], and μ is the coefficient of friction. Sorry.:smile:
  • #38
are you talking about the static or kinetic coefficient of friction?
ffk = [mu]kN
ffs is less than or equal to [mu]sN
sorry i don't know how to do subscripts
  • #39
ffk = [mu]kN
Both apply but it doesn't matter. In either case here, we only need to total weight of the car, and the applicable coefficient of friction in order to calculate the frictional forces. :smile:
  • #40
so the answer is not greater traction? sorry i didnt explain my answer well. peace
  • #41
How does the performance of the vehicle benefit from wide tires? Clearly we do get some traction advantage but why; by what physical mechanism or process? A simple application of the fritional force theory seems to yield no advantage. Peace on you too.
  • #42
hmm is it something to do with torque?
  • #43
wider tires allow one to inflate the tires to a lower pressure
and still support the car
the weight of the car is equal to the footprint area of the tires
multiplied by the air overpressure
with wider tires, it is more practical to have a large footprint area and thus a lower pressure (for the same weight of car)
intuitively lower pressure will contribute to better adherence to the road (small irregularities won't cause vibration that bounces the tire out of contact)
  • #44
Can you elaborate on this direction of thought?
  • #45
What does this matter if the frictional force calculated is independent of surface area?
  • #46
hi Ivan, I don't really believe the normal force is constant
I think irregularities in the road cause the wheel to bounce up and down and at times nearly leave the road
If I were designing a racing vehicle I would want low pressure in the tires so I could have a tight suspension (with little or no play). And so you could pick up the tire a ways before it would actually lose contact with the road.
i would probably want a large footprint to even out little irregularities in the road and to retain contact even with a lot of up/down motion
this is guessing, you asked me to elaborate.
  • #47
Well, I think I'll call this good enough. I was really looking for any of the following the references:
1).The coefficient of friction is higher for a soft tire:
Buried in this argument are any number of ideas that ultimately lead to the final value of the coefficient of friction. For example, the tire deforms and can then push against vertical surfaces. But this is all that happens at the microscopic level. So really we end up with a number of different levels of "contact" characteristics between the surfaces. After rationalizing this a bit we realize that all arguments boils down to the measured coefficient of friction for a particular tire configuration; e.g. pressure, temperature, stickiness, surface relaxation times, etc. etc. etc. The more one thinks about this, the more variables seem to crop up.
2).There is more rubber to remove:
To insure maximum friction, we typically [historically] want to remove as much rubber from the tire as possible. Obviously, as "On Radioactive Waves" almost started to touch on, if we add rubber by making a thicker tire, we create greater angular inertia than with a wider tire. This then affects the acceleration performance of the car, in addition perhaps to making for an impractical tire design.
I am sure other variables exist that I have never even considered. In any event, good enough, here's to you marcus.
  • #48
In or around 1990 the BIPM, under the international authority of the General Conference on Weights and Measures (CGPM), established new Electrical Standards known as the 1990 volt and the 1990 ampere.
These are defined independently of the metal kilogram prototype in Paris and are in fact based solely on the atomic clock together with two quantum effects.
What are the two (low temperature) quantum mechanical effects used to define V90 and A90 ?
Or, equivalently if you prefer to look at it that way, the effects used to define V90 and Ω90 .
The definitions are based on ADOPTING exact values for two fundamental physical constants. What are they?
PS: it is sort of analogous to defining the meter by adopting an exact value for the speed of light---the official way since 1983.
You can't measure the speed of light in vacuo any more because it has a decreed exact value---in the 1990 electrical context there are two more constants which you can't measure.
'These are the electrical standards used in practice, though not yet finally made official.
The adopted values are among those listed at the NIST fundamental constants website in the "adopted values" section.
To sum up----the 1990 electrical standards have no logical connection to the metal kilogram and the Newton force based on it---or on the old force between infinite parallel wires definition of the ampere. How are they defined?
  • #49
The quantum magentic flux unit is used, and I believe that is defined with h-bar and e.
JMD
  • #50
JMD
Yes! but that is only one fundamental constant and only enough to define one unit-----the 1990 ampere.
be more complete and specific.
How, for example, is the 1990 volt defined? Using the atomic clock plus what quantum device?
good, but not yet complete
BTW if you do dimensional analysis of hbar/e2
you will find that (if you carefully do it in SI units only and
follow SI conventions) you will get a ratio of voltage to current.
But that sort of ratio is called a resistance.
check out the adopted constants at the NIST website
nist.gov, if I remember right---the world's premier "fundamental
constants" website
  • #51
They mostly likely use a squid or josephson junction. With the use of the quantum hall effect both a volt and amp and be "defined".
JMD
  • #52
JMD
http://physics.nist.gov/cuu/Constants/
these adopted values define the current (1990) electrical standards. I'm quoting from this section of the site
http://physics.nist.gov/cgi-bin/cuu/Category?view=html&Adopted+values.x=102&Adopted+values.y=11
conventional value of Josephson constant
Value 483 597.9 GHz V-1
Standard uncertainty (exact)
conventional value of von Klitzing constant
Value 25 812.807 Ω
Specifying exact values of these two is equivalent to specifying exact values of hbar and e.
Your turn JMD---you pose a question that you know the answer to
and whoever gets it right has the next turn.
  • #53
Lets try an easy one,
What is the diference in first and second order phase tranistions?
JMD
  • #54
Simply because wide tires wear less than narrow ones - thus they last longer.
  • #55
JMD
For starters here are two examples-----the melting of ice is a first order transition.
The change in magnetic state at a critical temperature is a second order transition.
there are different definitions around----one is that first order involves a substantial supply of heat or change in free energy content----and second order just happens without a big change in heat content either way.
In a second order transition the specific heat may change and various other properties (like magnetisation). The change may be less obvious.
An online dictionary I gave a slightly different take on it: first order is abrupt and involves a gross change in properties like from solid to liquid
Second order (this dictionary indicated) was continuous as the critical temperature was approached----rather than abrupt---and likely to involve more subtle properties of the material.
the dictionary practically equated first order with discontinuous transition and second order with continuous.
I think there must be several alternative ways of classifying phase transitions by first or second order, and perhaps higher orders than two.
******for reference here are the dictionary entries*****
Phase transition
A change of state such as occurs in the boiling or freezing of a liquid, or in the change between ferromagnetic and paramagnetic states of a magnetic solid. An abrupt change, characterised by a jump in an order parameter is known as first order; a change in which the order parameter evolves smoothly to or from zero is called continuous or second order.
Order parameter
A variable such as ... the magnetisation in an Ising model... used to describe the degree of order in a phase above (below) its critical point. In a continuous phase transition (second order phase transition), the order parameter goes continuously to zero as the critical point is approached from above (below).
  • #56
Almost what I'm getting at.
What happenes to various properties, during a phase change. ie volume, entropy, compressibility, heat capacity. All of which can be expressed from the expression of the free energy. There is a distinct behavior for first and second order tranistions.
JMD
  • #57
JMD
In Type I there is an abrupt, discontinuous change in these properties (vol, entropy, heat capacity)
In Type II the change is continuous.
www.mit.edu/~levitov/8.334/lec2.pdf[/URL]
Some MIT lecture notes on statistical mechanics, by Levitov.
Discussing the Landau model of phase transition and
Type I/Type II also called first order/second order transition.
Has a concise summary of the difference at the end of lecture 2, which I will try to copy for extra clarity. Nice question "nbo10".
BTW symmetry is an important feature of Type II. In type I (most common type) it can happen that there is no significant change in symmetry. But in type II (in magnetization for example) there can be an abrupt change in the amount of organization or symmetry.
The notes talk about this.
  • #58
want to copy in the end-of-lecture summary from those notes
www.mit.edu/~levitov/8.334/lec3.pdf[/URL]
Type I phase transitons are discontinuous, accompanied by jumps in physical quantities, such as density or entropy, latent heat, and volume change. The symmetry is typically not changed in such transitions.
Type II phase transitions are very different. In such transitions, physical quantities vary continuously, while symmetry changes abruptly. The phase transformation in a type II transition is described by spontaneous symmetry breaking.
  • #59
In first order phase tranistions, there is a discontiniuty in the first derivative in the free energy.
second order phase tranistions have a disconitiuty in the second derivative in the free energy.
In ice the volume changes as the sturcture changes, First order PT
The tranistion from normal metal to a superconducting state there is a jump in the specific heat, a second order PT
There is no gradual change in symtmetry, there is an abrupt change in going from one state to another.
JMD
  • #60
JMD
Well I can't say scored a complete hit---in terms of what you expected. Would you like to have a second turn?
(You have to receive and acknowledge a right answer for the turn to move on to another person.)
  • · Replies 78 ·
  • · Replies 154 ·
21K
