Car crash collision, roller coaster energy, and ball hitting a racket
22 replies · 5K views
danago
Hey. I've got a physics test coming up soon, and i had a few questions that I am wanting confirmed. All help is greatly appreciated.
_______________________________________________________​
1. IN a horrific car crash, a car skids 85m before striking the rear of a parked car. Just before the moment of impact, the car is moving with a velocity of 15 [itex]ms^{-1}[/itex]. The cars become locked together and skid for another 5.2m before coming to rest. The mass of the first car is 1350kg, and the mass of the second is 1520kg.
a) What is the velocity of the two cars just after impact?
b) What is the impulse on each car during the collision?
c) What is the average size of the frictional forces between the cars and the road that finally bring the cars to rest?
a) For part a, i just used the fact that momentum is conserved.
[tex] \begin{array}{l}<br /> \sum {p_i } = 1350(15) = 20250 \\ <br /> \sum {p_f } = (1350 + 1520)v = 2870v \\ <br /> \sum {p_i } = \sum {p_f } \\ <br /> \therefore 2870v = 20250 \\ <br /> \therefore v = 7.0557ms^{ - 1} \\ <br /> \end{array}[/tex]
Therefore, after impact, the velocity of the combined masses is ~7[itex]ms^{-1}[/itex].
b) Part b, i just found the change in momentum.
[tex] \begin{array}{c}<br /> I = \Delta p \\ <br /> = m\Delta v \\ <br /> = m(v - u) \\ <br /> = 1350({\rm{7}}{\rm{.0557 - 15}}) \\ <br /> = - 10724.8{\rm{ }}Ns \\ <br /> \end{array}[/tex]
Therefore, the impulse experienced by each car is 10724.8 Ns.
c) I had the most trouble with part c. For this question, i found the acceleration of the cars, from ~7[itex]ms^{-1}[/itex] to rest in 5.2m.
[tex] \begin{array}{l}<br /> v^2 = u^2 + 2as \\ <br /> \therefore 0 = 7.0557^2 + 2(5.2)a \\ <br /> \therefore a = - 4.79ms^{ - 2} \\ <br /> \end{array}[/tex]
Therefore, the masses were deccelerating at a rate of 4.79[itex]ms^{-2}[/itex]. For this decceleration to occur in a mass of 2870kg, i used Newtons formula to calculate the force required:
[tex] \begin{array}{c}<br /> \sum F = ma \\ <br /> = 2870( - 4.79) \\ <br /> = - 13738N \\ <br /> \end{array}[/tex]
Therefore, an average force of ~13738N is required to bring the two cars to rest within 5.2m of collision.
2. The following image depicts a roller coaster:
http://img148.imageshack.us/img148/6906/pfq0002copyst1.gif
a) Assuming that the speed of the cart at point A is 4[itex]ms^{-1}[/itex], find the speed of the cart at points B, C and D. Also assume that no energy is lost due to friction/drag.
b) It is found that at point C, the cart stops. What is the energy loss due to friction between points A and C?
I was a little confused with this one at first. I started by finding the total mechanical energy at point A:
[tex] \begin{array}{c}<br /> E_M = E_K + E_P \\ <br /> = 8m + 294m \\ <br /> \end{array}[/tex]
Assuming that this is a perfectly elastic energy transformation, the mechanical energy at point B should be the same as the kinetic energy, since potential energy is zero, because of a zero height relative to the ground. So:
[tex] \begin{array}{l}<br /> \frac{{mv^2 }}{2} = 8m + 294m \\ <br /> \therefore v^2 = 604 \\ <br /> \therefore v = \sqrt {604} = 24.6ms^{ - 1} \\ <br /> \end{array}[/tex]
At point C, since energy is still being conserved, and this is an elastic situation, the mechanical energy should equal the mechanical energy used in the previous calculation. So that:
[tex] \begin{array}{l}<br /> 245m + \frac{{mv^2 }}{2} = 8m + 294m \\ <br /> \therefore v = 10.7ms^{ - 1} \\ <br /> \end{array}[/tex]
And i used the same process for point D to get a velocity of 19.2[itex]ms^{-1}[/itex].
For question b, I am quite stuck. I am not sure where to start from. Any help please? Would the answer just be the kinetic energy the cart has at point C, which would be ~57m J? Also, how can i calculate the efficiency of the track from A to C?
3. A ball of mass 0.1kg strikes a raquet with velocity of 10[itex]ms^{-1}[/itex], and rebounds with a velocity of 9.5[itex]ms^{-1}[/itex]. Using the force/displacement graph, find the maximum displacement of the strings.
http://img225.imageshack.us/img225/3824/scancopybz1.gif
This question I am completely stuck. Everything I've tried leads nowhere. My physics teacher couldn't even do it.
Thanks very much for the help. For the questions I've answered, id just like some confirmation as to weather I've done them correctly.
Thanks again,
Dan.
Ok. Sorry about accidently posing before finishing my post. Its all done now though :)
May help
For part 3 - the slope of the force-displacement curve gives you the stiffness coefficient.
Stiffness coefficient? Thats something that I've never come across or heard of. Where can i find more information on this?
Well presented. I don't have tim to check them all immediately but I've checked the first. All the methods are correct and the numbers seem fine nice work.
#3. Many assumptions need to be made in order to get to an answer for this one. I think the basic idea is that the raquet acts like a spring storing the kinetic energy of the ball temporarily and then returning it back to the ball (like an object being dropped onto a spring, but in this case only kinetic energy needs to be considered). It seems there is some energy lost in this interaction, but I would assume that the strings would deflect according to the initial kinetic energy of the ball. Which means that one need to find the displacement at which the area under the graph (the work done by the strings) is the same as the initial kinetic energy of the ball.
wheres point A on the rollercoaster?
Oops accidently cut it off. Its the point 30m from the ground :)
And thanks for the replies everyone. I am still not quite sure about question 3 though
The work done in part 3 is [tex]\frac12 K x^2[/tex] where K's the stiffness coefficient.
Can this be equated to anything?
ok. So the stiffness coefficient is 200. Do i then just find the maximum value of x in:
[tex] W = 100x^2[/tex]
Nvm. Just realized the quadratic has no maximum.
Stiffness is the propensity to resist displacement when subject to a force. The greater the stiffness, the higher the spring constant, i.e. the more force is takes for a given displacement. This is the meaning of Hooke's law.
http://en.wikipedia.org/wiki/Hooke's_law - relates force and displacement
http://en.wikipedia.org/wiki/Young's_modulus - relates stress and strain (which are related to stress and strain)
The spring constant is an indication of the spring's stiffness. A large value for indicates that the spring is stiff. A low value for means the spring is soft.
http://phoenix.phys.clemson.edu/labs/124/shm/index.html
Thanks for that astro.
Along the lines of what J77 is alluding, what is the origin of the energy in the spring (tennis racket springs) when it deflects and what is the velocity of the ball at maximum spring deflection?
The energy to displace the strings would be the kinetic energy from the ball, and at maximum displacement, the balls velocity is zero?
At maximum displacement, the spring has stopped moving (deflecting) - then it starts moving in the opposite direction. That's more or less the definition of an extremum.
Im still not really seeing how to solve the problem :(
Looking back at post #6 (andrevdh) and post #9 (J77), one could do an equivalence between the spring energy 1/2 kx2 and the initial kinetic energy of the ball 1/2 m v2. Now, as andrevdh implied, requires the assumption that the raquet plane does not deflect itself, i.e. all the deflection goes into the springs.
The above relationship simplies to kx2 = m v2, which is where J77 was leading you.
Now the other part is the fact that the ball rebounds with a velocity of 9.5 m/s, so there is a loss of energy somewhere, which could be internal friction due to inelastic collision (deformation of the ball). One could assume half the energy loss during the extension of the spring and the other half during restoration, so then the effective kinetic energy going into the strings may be based on the mean velocity (speed) of 9.75 m/s.
Conservation of energy applies to elastic collision, and not inelastic collision.
I was thinking of equating the work done by the 'spring' with the change in kinetic energy of the ball...
Would this not work?
For #2 part b. you know the speed it should be going if there is no friction, so due to the friction all that speed has diminished, therefore the energy loss is as you thought. Efficiency is normally defined as the real performance/ideal performance. I suggest using energy in such a manner
efficiency= energy lost/initial energy
seems most logical to me. I could be wrong because I've never had to apply it to this situation though so if somebody could check me.
The change in kinetic energy would be dissipated or transformed somewhere.
Initially the ball has kinetic energy based on v= +10 m/s. At maximum deflection (extension), the ball comes to rest, v = 0. Then the spring begins to restore or return to its equilibrium, but when the ball leaves the spring, it has lesser velocity, -9.5 m/s (speed = 9.5 m/s in opposite direction), where the - simply indicates that the velocity is in the opposite direction.
As andrevdh, there are some assumptions that have to be made. For example, is the ball rigid or non-rigid. The ball may undergo elastic or inelastic deformation, which means it could dissipate some of the energy during the interaction with the racquet. Or the racquet itself could recoil.
One must assume how the energy (difference in kinetic energies) is dissipated. A reasonable assumption is that half is dissipated during the initial deflection and half dissipated during the restoration.
This is another reason why it is very helpful to work out a problem as danago has done.
OK - I see where you're coming from but should one make such assumptions when asked for the maximum displacement or when doing physics tests?
When dealing with a spring, such as in simple harmonic motion, the maximum stored energy in a spring coincides with maximum displacement from equilibrium. Also, the maximum stored energy in the spring coincides with zero velocity of the ball (the ball changes direction, so at some point its speed (velocity) must be zero, which means its KE must be zero) and that is when the maximum stored energy in the spring is realized.
Also, one must note that the ball rebounds with a different (lower) velocity, and one must understand (or know) or assume what happens with respect to that lost energy.
In the real situation, if one observes a baseball hit by a bat, or a tennis ball hit by a racquet, one will see that the ball deforms. Most of the deformation is elastic, and the ball returns to its pre-deformed shape. However, some of the mechanical energy of deformation is dissipated in the form of heat and acoustic energy. There is also internal friction within the bat and racquet, which may also dissipate some of the energy.
