Visualising Torsion Tensor: Is There a Picture?
The discussion centers on the visualization of the torsion tensor in differential geometry, particularly its role in parallel transport on manifolds. It highlights that while the Riemann curvature tensor accounts for angular changes, the torsion tensor represents translational defects. The conversation references Hehl's paper on torsion and its implications for connections, emphasizing that torsion can exist even in flat spaces through non-trivial connections. The participants explore the distinction between metric compatibility and torsion-free connections, ultimately suggesting that understanding these concepts requires both algebraic and visual representations.
  • Understanding of Riemannian geometry and its properties.
  • Familiarity with the concepts of curvature and torsion tensors.
  • Knowledge of parallel transport and covariant derivatives.
  • Basic grasp of differential geometry and manifold theory.
  • Study the implications of the Einstein-Cartan theory on torsion in manifolds.
  • Explore visual representations of torsion and curvature in 2D manifolds.
  • Read Hehl's paper "Elie Cartan's torsion in geometry and in field theory" for deeper insights.
  • Investigate metric-compatible connections and their effects on geometric properties.
Mathematicians, physicists, and students of differential geometry seeking to deepen their understanding of torsion and its visual representation in manifold theory.
chartery
As I understand it, parallel transport of a vector around a closed loop on a manifold can lead (in the tangent space) to 1) an angular change, given by the Riemann curvature tensor or, 2) a translational defect given by the Torsion tensor.
I can see how the looping on the curvature of a 2D sphere leads to such a changed angle. Is there any equivalent representation of the features of a 2D manifold that would help me visualise pictorially how torsion leads to a translational defect?
Also, is there an easy way to understand how an intrinsic translational defect can be thought of as a generalisation of an extrinsic rotation in flat space?
The best I can do
is to point you to possibly interesting reading:
a very long set of discussions at
https://mathoverflow.net/questions/20493/what-is-torsion-in-differential-geometry-intuitively
One answer points to a paper by Hehl
"Elie Cartan's torsion in geometry and in field theory, an essay"
https://arxiv.org/abs/0711.1535
which draws on pg. 3
Isn't the (non)existence of torsion a property of the connection, rather than the manifold? There exists a unique metric-compatible connection that leads to zero torsion. So you can't do anything like the illustration of curved manifolds by embedding a 2-sphere because you can always pick a connection that leads to zero torsion.
But presumably you can also pick a connection that leads to non-zero torsion even in quite trivial cases. Thus (I think!) you could have torsion on a flat 2d plane by picking a non-trivial connection. As far as I understand it, the connection would (via the covariant derivative and hence parallel transport) affect what it means to "travel in a straight line". So you could pick a connection such that the un-accelerated path of a particle on the plane was a parabola (or something) while the shortest distance between two points remained what Euclid would call a straight line.
You are right, there's a unique metric compatible torsion-free connection on a Riemannian manifold, and it's given by the usual Christoffel symbols wrt. a coordinate basis, and by definition a Riemannian manifold is the one, for which the affine connection is defined as this unique torsion-free connection.
However, there are also metric-compatbile connections that are not torsion-free. Then you get a more general type of manifold, an Einstein-Cartan manifold. If you want to define fields with spin, in general you need these more general manifolds. For a review, see
https://doi.org/10.1103/RevModPhys.48.393
Yes, metric compatibility and torsion free-ness are separate choices. I didn't state that clearly.
Thanks all. I guess I should have been clearer about not presuming the manifold was Riemannian. I had seen the mathoverflow link, but find algebra only helps once I have some visual handle on a concept, however simplistic.
On rereading Hehl's paper (https://arxiv.org/abs/0711.1535), the following seems to me to fit the bill:
Figure 2: Schematic view on a two-dimensional Cosserat continuum: Undeformed
initial state.
Figure 11: Deformation of a cubic crystal by edge dislocations of type α121:
The relative orientations of the lattice plains in 2-direction change. A vector
in x2-direction will rotate, if parallelly displaced along the x1-direction. As
a consequence a contortion κ112 emerges and the closure failure occur of the
“infinitesimal” parallelogram.Although I'm not smart/knowledgeable enough to decide which was the more appropriate:
Figure 4: Homogeneous contortion
Figure 6: Conventional rotation ∂[1u2] of the “particles” of a Cosserat continuum
caused by an inhomogeneous strain.
  • · Replies 29 ·
  • · Replies 16 ·
