What is the energy of each photon produced in the decay of the pion?
  • Thread starter Thread starter cashmoney805
    Photons Pion
The discussion focuses on the decay of a neutral pion into two photons, with a rest mass energy of 135 MeV and a kinetic energy of 90 MeV. The calculations reveal that the speed of the pion is approximately 0.80c, and its momentum is calculated to be 9.6 x 10-20 kg m/s. The total energy before decay is established as 225 MeV, while the energy calculated post-decay using momentum conservation yields varying results, indicating a misunderstanding of energy conservation principles in relativistic contexts.
  • Understanding of relativistic energy equations, specifically E = mc2.
  • Familiarity with momentum conservation in particle physics.
  • Knowledge of kinetic energy calculations in relativistic scenarios.
  • Basic principles of particle decay and photon energy.
  • Study the principles of relativistic momentum and energy conservation in particle physics.
  • Learn about the decay processes of unstable particles, focusing on pions.
  • Explore the relationship between kinetic energy and relativistic mass.
  • Investigate photon energy calculations using E = pc for massless particles.
Physics students, particle physicists, and anyone interested in understanding the principles of particle decay and energy conservation in relativistic systems.
cashmoney805
The neutral pion is an unstable particle that decays very quickly after its creation into two photons (“particles” of light: v = c, mo = 0). The pion has a rest-mass energy of 135 MeV. Consider a pion that has a kinetic energy of 90 MeV
1) Determine the v of this pion
2) Determine the momentum of the pion
3) Determine the sum of the energies of the photons
1) moc2\gamma = KE + Rest E
2) mov\gamma = p
3) Ephotons= pc
I'm pretty sure I got 1 and 2. For 1 I added the KE + RE, converted to proper units, and finally got v = .80c
For 2 I got p = 9.6 x 10-20 kg m/s
Now I'm not so sure about #3. I think Ephotons = pc because momentum is conserved, and all of the pion's momentum gets turned into the photons' momentum. However, what about adding up the original rest mass energy + KE of the pion? If I do that I get a bigger energy then if I do pc. Thanks for all the help!
2) mov\gamma = p
3) Ephotons= pc
Just using pure energy conservation, how much energy is there before and after the decay?
According to my calculations, E before = (90 + 135) MeV = 225 MeV
After E = pc = 181.25 MeV
I calculated p a different way this time, p = sqrt(2mKE) where m is the relativistic mass. When I do this then multiply p by c to get E, I get E = 201 MeV. Oh boy...
edit: actually I'm not sure if that equation works for speeds close to c...
Hrm, you're letting the calculations get bogged down too much. The change in energy is zero, right? You know initial energy, so final energy must be.. the same.
I get what you're saying, but I don't understand why the equations don't work here. It seems to me that momentum isn't conserved.
and there is one more part to this problem which I thought I could get myself, but I can't. Here is a pic of the question/diagram
http://i44.tinypic.com/k12kja.gif
  • · Replies 34 ·
