What Is the Speed of a Sledgehammer's Center of Mass After Being Released?
  • Thread starter Thread starter Becca93
Becca93
Homework Statement [/b]
A sledgehammer with a mass of 2.30 kg is connected to a frictionless pivot at the tip of its handle. The distance from the pivot to the center of mass is r_cm=0.570 m, and the moment of inertia about the center of mass is I_cm = 0.0390 kgm2. If the hammer is released from rest at an angle of theta=40.0 degrees such that H=0.366 m, what is the speed of the center of mass when it passes through horizontal?
The diagram is attached.
My prof did a similar question during class with energy, and so that's the way I tried to solve it. With this incorrect, I honestly don't know how else to go about this problem.
E1 = E2
mgH = (1/2)Iw^2
2mgH/I = w^2
w = √(2mgH/I)
w = 20.568 rad/s
*Because the question asks for speed, I tried this as the answer and the units were rejected. So I tried to solve for velocity instead.
mgH = (1/2)I(v^2/r^2)
v^2 = 2mgHr^2/I
v = √(2mgHr^2/I)
v = 19.37 m/s
Again, incorrect.
Does anyone know how to help? I would genuinely appreciate it. I've got a final coming up and not knowing how to go about this problem, or even what specifically to solve for when asked for 'speed', is really making me panic.
Becca93 said:
E1 = E2
mgH = (1/2)Iw^2
2mgH/I = w^2
w = √(2mgH/I)
w = 20.568 rad/s
So far, so good. You found the angular speed. Now use it to answer the question: What's the speed of the center of mass? (They want the linear speed.)
v = wr
so, with the angular speed I have,
v = (20.568)(0.570)
v = 36.1 m/s
Which is incorrect.
Where am I going wrong?
Becca93 said:
v = wr
v = (20.568)(0.570)
v = 36.1 m/s
Which is incorrect.
Check your arithmetic.
Oh, okay.
But I end up with 11.7, which is still the incorrect answer.
They give the moment of inertia about the center of mass. What you need is the moment of inertia about the axis of rotation. (Use the parallel axis theorem.)
Sorry for not spotting that earlier! :redface:
Alright, so,
Ip = Icm +mr^2
Ip = 0.039 + (2.3 x 0.57^2)
Ip = 0.78627
Plugging that into the E1 = E2 business earlier, I get w = 4.157 rad/s
Then v = wr,
v = 2.37 m/s
And again it is incorrect.
I honestly have no idea how to move forward.
Becca93 said:
Alright, so,
Ip = Icm +mr^2
Ip = 0.78627
Good.
Redo this. I get a different value for ω.
Doc Al said:
Good.
I've finally got it! Thank you so very much!
Whew! You are most welcome.
