Plane engines, defective products, and hypergeometric distribution problems
19 replies · 7K views
Homework Helper
URGENT help needed with statistics, probability
A plane functions iff at least 2 of its 3 engines function.
P(each engine functions)=p, the engines operate independently of each other. Find the
probability that the plane functions.
A=engine 1, B=engine 2, C=engine 3.
P(plane functions)= P(AuB)+P(AuC)+P(BuC)
P(AnBnC)=p3
P(AnB)=P(AnC)=P(BnC)=p2
P(AuBuC)=P(A)+P(B)+P(C)-P(AnB)-P(AnC)-P(BnC)-P(AnBnC)=3p-3p2-p3
http://img168.imageshack.us/img168/2991/venn.jpg
But the regions they want are P(AuB)+P(AuC)+P(BuC) which is just 3(p-p2-2p3)
2% of products in a factory are defective. Products are sold in packages of 100. What
proportion of cartons contain at least 'x' defective products? x=1,2,3,...,100. (use
binomial distribution)
Binomial distribution: P(X=x) = nCx px(1-p)n-x , where p is the probability of success.
P(defective)=0.02
P(not defective)=0.98
I need to get X~Bin(100,0.98)
P(X=x)= 100Cx0.98x0.02100-x
So my answer is just P(X=x)/100 ? (replacing P(X=x) with the above)
A shipment of 8 items contain 3 that are defective. A person makes a random selection of 2
of these items, find the probability distribution for the number of defectives X. Find the
cumulative functions of X as well.
So P(X=x) is defined as follows:
0 for x<1
3/8 for 1<x<2
5/56 for 2<x<3 ( 2 defective is 3/8 * 2/7)
6/336 for x>3 (3 defective is 3/8 * 2/7 *1/6)
And to get the cdf I just integrate the functions (in the regions) between 'x' and -infinity?
[itex]P(A \cup B)[/itex] is the probability that at least one of engines A and B is functioning, but you want the probability that both are functioning at the same time. Same problem with the other pairs.
Also, you should have
P(AuBuC)=P(A)+P(B)+P(C)-P(AnB)-P(AnC)-P(BnC) + P(AnBnC)
not a negative sign on the last term.
I typed the formula wrong :blushing:
Then I would get P(AnB)+P(AnC)+P(BnC)=3p2, if that is the case, I don't understand why they told me to use that formula.
Now you're triple-counting the intersection of A, B, and C, so you need to subtract the extra from your result. You can just add up the probabilities you have in your Venn diagram from the relevant regions to see what the answer should be.
It would just be the intersections alone, so it'd be 3(p2-p3)+p3
Yes, that's right. I see what they wanted you to do now. The plane functions if (A and B) or (A and C) or (B and C). Do you see how that's the union of 3 sets, so that that formula would apply?
Wouldn't that give a different answer to the post above?
P(AuBuC)=3p-3p2+p3, I'd have a 'p' term here.
rock.freak667 said:
2) 2% of products in a factory are defective. Products are sold in packages of 100. What proportion of cartons contain at least 'x' defective products? x=1,2,3,...,100. (use binomial distribution)
Binomial distribution: P(X=x) = nCx px(1-p)n-x, where p is the probability of success.
P(defective)=0.02
I need to get X~Bin(100,0.98).
P(X=x) = 100Cx0.98x0.02100-x
All good until the last line.
If P(X=x)=0.10, that means 10% of the cartons have x defects. There's no need to divide by 100. The probability is already the proportion.
Also, the problem isn't asking for P(X=x). That would be the probability that a carton has exactly x defective parts. The problem asks for the probability that a carton has at least x defective parts.
No, because the three sets aren't A, B, and C.
Both engines A and B working corresponds to [itex]A \cap B[/itex], and so on. (A and B) or (A and C) or (B and C) corresponds to the union of those intersections.
So then if I find P(X=x-1), I'd get exactly 'x-1' defective, and then if I put 1-P(X=x-1), I should get 'x or more defective', which would be at least x, right?
No, that would give you the probability of 0, 1, ..., x-2 defects or x, x+1, x+2, ... 100 defects. You only want the second part, not the 0 through x-2 part.
Oh now I get it.
This part has me confused :confused:
1-P(X=x) is the probability of not having exactly x defects. That means you could have more or less than x defects, which isn't the same as having at least x defects.
The problem wants me to get P(X≥x), I have P(X=x). I need to get 1-P(X<x). How would I get P(X<x)?
You would sum the probabilities P(0)+P(1)+P(2)+...+P(x-1).
I know it would be a binomial expansion, but of what? The normal bin distribution is (p+q)n where q=1-p
It'll be part of a binomial expansion. As far as I know, there's no closed form expression for it.
[tex]P(X \geq x) = 1 - \sum_{x=0} ^{x-1} ^{100}C_x 0.98^x 0.02^{100-x}[/tex]
there is no way to simplify that term?
Not that I know of.
vela said:
Not that I know of.
Then I have to leave my answer like that then.
any help for the 3rd one?
EDIT: I got out the 3rd one.
