Plasma Physics and Controlled fusion problems
The discussion revolves around problems from Chen's "Intro to Plasma Physics Controlled Fusion," focusing on various concepts in plasma physics and controlled fusion. Participants are exploring specific problems related to equations, mathematical interpretations, and physical principles within the subject area.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to clarify the relationship between the ideal gas equation and the Saha equation, questioning the equivalence of variables.
  • Participants inquire about the integration limits in cylindrical coordinates and the implications of quasineutrality in relation to the Poisson equation.
  • Questions arise regarding the mathematical acceptability of certain operations involving magnetic fields and the interpretation of drift trajectories in plasma physics.
  • There are discussions about the relationships between various plasma parameters and their physical significance, such as phase velocity and diamagnetic drift.
The conversation is ongoing, with participants seeking clarification on specific problems and concepts. Some guidance has been offered regarding the need to present problems and work for better assistance. There is an acknowledgment of the complexity of the topics being discussed.
Participants are referencing specific problems from a textbook, indicating that some information may be missing or unclear. There is a note that the original poster's questions pertain to solved problems, which may not be readily available in the provided link.
Abdurahman
Hello all physicists,
Actually, I am trying to solve Chen’s book problems which is titled Intro to Plasma Physics Controlled Fusion, 2ed. I encountered many steps that I would like to discuss with you which still not so clear in my mind. Please take a look into that problems either in your library or on >>http://books.google.com/books?id=To...S_7uJoqGzATm7vHCDQ&cd=1#v=onepage&q=&f=false"<<
The points that are for discussion(solved problems):
1-Problem 1-1: we use here the ideal gas equation…what about the Saha equation? It also links the temperature with the density? is n equivalent to n_n in ideal gas vs. Saha equation?
2-Problem 1-2: why we do not also integrate over (dz) since we are in cylindrical coordinates?
3-Problem 1-6: using Poisson equation: does that counterpart the meaning of quasineutrality?!
4-Problem 2-4: how can we have different Larmor radiuses(r_ 1and r_2) for the guiding center?
5-Problem 2-6: is that mathematically acceptable to take the radial component of E without that of B? and how can the radial component of E has a theta basis without radial basis?
6-Problem 2-9:why does the orbit follow this strange trajectory? in calculating the grad-B drift: do we always implement in plasma physics that grad-B is perpendicular to B(just as we assume between E and B for ExB drift) ?
7-Problem 3-4: is it mathematically allowable to cancel B from the cross product (with (n)) with that of the denominator?
8-Problem 3-5: where does this relation of delta(n) and (n’.L) come from?
9-Problem 3-7: why does the phase velocity follow the V_E velocity in direction? In (c): why the diamagnetic drift does not appear directly in the sum of lab frame velocities?
10-Problem 3-9: how can we end up with the change in B while we have just B in Ampere’s law and not grad-B ? the direction of J_D: should not it be in the opposite direction?
Thanks for help very much...
Abdurahman
is there any plasma physitist in this forum? :)
A lot of the problems don't seem to match your questions (judging by the link you provided). So post the problems, show your work and explain where you get stuck or what bothers you.
ok..i understand now..the google book doesnot contains the solved problems section...my questions are for solved problems in the book..
please check the book in ur library or try to find e-book for it..it is an amazing book and worth to hAVE A LOOK INTO..
ABDURAHMAN
  • · Replies 0 ·
