What Temperature Does Each Element Become Plasma?
  • Context: High School
  • Thread starter Thread starter Godspanther
    Plasma Table
This discussion focuses on the temperatures at which elements transition into plasma, the fourth state of matter. Plasma formation occurs through the ionization of gases, where electrons are removed from atoms. The temperature at which an element becomes a singly ionized plasma can be calculated using the formula T = E / K_b, where E represents the ionization energy and K_b is the Boltzmann constant. A recommended resource for ionization energies is the University of Guelph's chemistry database, which provides binding energies for various elements.
  • Understanding of plasma physics and ionization processes
  • Familiarity with the Boltzmann constant and its application in thermodynamics
  • Knowledge of ionization energy and its significance in chemistry
  • Basic mathematical skills for applying the formula T = E / K_b
  • Research ionization energies of elements using the University of Guelph's chemistry database
  • Explore the concept of thermal equilibrium in plasmas
  • Learn about the different levels of ionization and their effects on plasma properties
  • Investigate the application of plasma in various scientific fields, including astrophysics and fusion energy
This discussion is beneficial for physicists, chemists, and students studying plasma physics or thermodynamics, as well as anyone interested in the properties and behaviors of elements in their plasma state.
Godspanther
Where can I find a list/chart of the temperatures at which elements reach the 4th state of matter known as plasma?
So I believe that it will not be as simple as finding a table with elements and temperatures but it is possible that you could make sure a table with some assumptions.
First off, do you know what a plasma is? In short a gas becomes a plasma when electron(s) are removed from the nucleus. The process of removing an electron from an atom is called ionization. Consider removing the electrons off of an atom one by one. After you remove the first electron, I would say the atom has been singly ionized. After two electrons are pulled off it would be doubly ionized and so on until all of the electrons are removed which I would call fully ionized.
Now when you as for the temperatures at which elements become plasmas, I would rephase it as, at what temperature would a singly ionized plasma of element X be in thermal equilibrium? Now a further complication is that in thermal equilibrium the plasma might be made up of ions with different levels of ionization but let's not get into that.
So we need to know at what energy are the elements singly ionized. Then the temperature that corresponds to that first ionization energy is roughly what you are looking for.
T = E / K_b
where T is temperature, E is energy, and K_b is the Boltzmann constant.
I think the following site provides the ionization (binding) energies for many elements (the energy in eV at the bottom of a given column is what is needed for singly ionized atom).
http://www.chembio.uoguelph.ca/educmat/atomdata/bindener/elecbind.htm
The following Wolfram Alpha link is an example for Hydrogen
  • · Replies 26 ·
