Please convince me (OLS matrix derivation)
  • Context: Graduate
  • Thread starter Thread starter longrob
    Derivation Matrix
The discussion centers around the derivation of the normal equations for Ordinary Least Squares (OLS) estimates, specifically focusing on the differentiation of the expression B'X'XB with respect to the vector B. Participants explore the mathematical foundations and implications of this differentiation within the context of linear regression.
  • One participant requests clarification on why the derivative of B'X'XB with respect to B is 2X'XB.
  • Another participant expresses unfamiliarity with the specific layout of the OLS derivation and requests further explanation.
  • A participant refers to a document to illustrate the concept of orthogonal projection in relation to OLS.
  • There is mention of the chain rule being relevant in the differentiation process, with a suggestion that the expression involves a product rule.
  • One participant proposes that the derivative of a quadratic form B'MB can be expressed as 2MB under certain conditions, indicating a potential approach to the problem.
  • A detailed setup of the OLS problem is provided, including the relationship between the response vector, design matrix, and error terms.
  • Another participant discusses the geometric interpretation of OLS and the concept of projection in a normed space.
  • One participant attempts to derive the derivative of a quadratic form and expresses frustration with formatting LaTeX equations correctly.
  • Another participant successfully formats their LaTeX and presents a detailed derivation, concluding that the derivative of the quadratic form leads to the expression 2X'Xβ.
Participants express varying levels of understanding regarding the differentiation process, with some proposing methods and others seeking clarification. There is no consensus on the derivation or the interpretation of the results, indicating that the discussion remains unresolved.
Participants note the complexity of differentiating matrix expressions and the potential need for additional mathematical tools or concepts, such as the chain rule and properties of symmetric matrices. Some assumptions about the properties of the matrices involved are not explicitly stated.
longrob
Hi all
In the derivation of the normal equations for Ordinary Least Squares estimates we have B (m x 1 column vector) and X (n x m matrix). Could someone please convince me that the derivative with respect to B of
B'X'XB
is
2X'XB
Thanks !
LR
I'm sorry, I'm not familiar with the OLS you're referring to. The one I'm familiar is
one used either to find the best approximation (using orthogonal projection), to an
inconsistent system, or to find the line of best fit to a set of data points, i.e., the
least-squares line; the line that minimizes the sum of square residuals, and I don't
recognize your layout, nor the meaning of the derivative B'. Would you expand on your
layout?
Hi and thanks for your reply.
Could you take a look here:
http://cran.r-project.org/doc/contrib/Faraway-PRA.pdf
On page 18/19 you see exactly what (I think) you are referring to in terms of the orthogonal projection. What I am referring to is on the bottom of page 19:
"Differentiating with respect to beta and setting to zero, we find that beta-hat satisfies"
It's this differentiation I am specifically talking about (of the 2nd term o the RHS)
Thanks again
LR
Excuse me:
I meant "the 3rd term in the expression above" not "the 2nd term on the RHS".
Sorry, longrob, I have not had a chance to look at it, and I'm going to be busy for a while.
Still, from what I saw, it seems like the chain rule should be involved, since d/dB[(B'X'XB)]=
d/dB[((XB)'XB)] , and this is a product together with a chain rule; we have g(B)=(XB)'
and f(B)=XB (where X is a contant re B ), so that g(B) is a composition of scaling and
transposition. I'll look into it if I have a chance.
I'm sorry, I have been a bit confused about this myself; the best I have been able
to come up with, has been this; maybe/hopefully you or someone else can finish this
and/or make it more precise:
In B'X'XB , X'X is a square nxn matrix, and, basically, B' is the same as B, only
expressed in a different format , so what you get is a quadratic form B'MB , or,
another approach is that d/dB(B'MB)= d/dB([BM]B]= MB+BM , and somehow
(despite the product not being commutative), this is equal to 2MB=2XX'B .
Sorry, I have not been able to figure it out better.
Hi Bacle, thanks for your messages. I'm glad I'm not the only one who is a bit confused by it.
For completeness and the benefit of others, I'll explain the setup so that it's not necessary to refer to the link I posted.
We have
y = XB + e
where y is a n x 1 column vector of responses
X is a n x (k+1) matrix with a leading column of 1s for the regression intercept and the remaining columns being nx1 vectors of the observed values of the explanatory variables.
B is a (k+1) x 1 column vector of regression coefficients.
e is a n x 1 column vector of errors
We wish to find the values for the elements of B which minimise the sum of the squares errors.
That is, we wish to minimise e'e
Now,
e'e = (y - XB)' (y - XB)
= (y'- B'X') (y - XB)
= y'y - y'XB - B'X'y + B'X'XB
Now, since y'XB and B'X'y are 1 x 1 , they are equal, so:
= y'y - 2y'XB + B'X'XB
Differentiating this with respect to B and setting to zero yields
X'XB = X'y
which are the so-calleed "normal equations" which upon rearrangement gives the least squares estimator for B (provided that X'X is invertible)
It is the last step above which I don't get - that the derivative of B'X'XB with respect to B is 2X'XB. Obviously B'X'XB is a quadratic form, so it does make some intuitive sense, but I need more than that...
Thanks for reading
LR
Longrob, I do know the more geometric, and linear-algebraic derivation, using
orthogonal projection, if you're interested. You're working in a normed space (V,||.||).
The idea is that you're given an inconsistent linear system Ax=b; while there is no
actual solution x , there is a second best, which is finding the vector x_
that best approximates the solution, i.e., to find x_ such that, for any x':
||Ax'-b||>||Ax_-b||
And this x_ is actually the projection of b into the row space Ax
(if b were in the row space, Ax=b would have a solution).
With this layout, I know how to show that the line y=Ax^+B^
is the closest line to the collection of points in the LS sense (it is a sort-of inverse
problem , in that we are looking for the subspace--the least squares line/subspace
-- instead of having the space given as Ax).
Anyway, let me know if you're interested in this type of derivation. I got a bit
confused with the justification for differentiating matrices as if they were standard
variables, BTW; do you know if this is some sort of Borel Functional Calculus or
something similar to that?.
Hi again
I need to stick with the pure linear algebraic derivation at the moment, but thanks anyway. I may come back to you later on that, as I am also interested in the geometric interpretation.
Anyway, I think I have solved it. Basically, it revolves around the "rule" that the derivative of b'Ab with respect to b is (A+A')b, or in the case at hand, where A is symmetric, 2Ab. This can be proved as follows.
A is an n x n symmetric matrix. b is a n x 1 column vector.
[itex]\mathbf{b'Ab}=\overset{n}{\underset{i=1}{\sum}}\overset{n}{\underset{j=1}{\sum}}b_{i}a_{ij}b_{j}[/itex]
[itex]=\overset{n}{\underset{i=1}{\sum}}b_{i}^{2}a_{ii}+\overset{n}{\underset{i\neq j}{\sum}}\overset{n}{\underset{j\neq i}{\sum}}b_{i}a_{ij}b_{j}[/itex]
[sigh]
I can't get LaTex to display properly, as you can see above. I created it in Lyx and have tested it here http://www.codecogs.com/latex/eqneditor.php that it displays correctly. I can't post the rest of the proof in Latex as it just displays the Latex code:
[itex]\frac{\partial(\mathbf{\mathbf{b}'}\mathbf{Ab})}{\partial b_{k}}&=2b_{k}a_{kk}+2\overset{n}{\underset{i\neq k}{\sum}}a_{ki}b_{i}[/itex]
What am I doing wrong with this Latex ?
The rest of the proof is to form the partial derivative with respect to a general b sub k and to notice that this is just 2 times the elements of the vector Ab, so the derivative with respect to the whole vector b is 2 times the vector Ab.
OK, here goes again. I think I fixed the LaTex problems:
let [itex]\mathbf{A=X^{\textrm{T}}X}[/itex] where [itex]\mathbf{A}[/itex] is a [itex]n\times n[/itex] square symmetric matrix with elements [itex]a_{ij}[/itex]. [itex]\mathbf{\mathbf{\boldsymbol{\beta}}}[/itex] is the [itex]n\times 1[/itex] column vector. Expanding out.
[itex]\begin{align}\mathbf{\boldsymbol{\beta}^{\textrm{T}}A\boldsymbol{\beta}}&=\overset{n}{\underset{i=1}{\sum}}\overset{n}{\underset {j=1}{\sum}}\beta_{i}a_{ij}\beta_{j}<br /> \end{align}[/itex]
[itex]\begin{align}=\overset{n}{\underset{i=1}{\sum}} \beta_{i}^{2}a_{ii}+\overset{n}{\underset{i\neq j}{\sum}}\overset{n}{\underset{j\neq i} {\sum}}\beta_{i}a_{ij}\beta_{j}\end{align}[/itex]
Then, form the partial derivative of [itex]\mathbf{\mathbf{\mathbf{\boldsymbol{\beta}}^ {\textrm{T}}}\mathbf{A\boldsymbol{\beta}}}[/itex] with respect to [itex]\beta_{k}[/itex], an arbitrary element of [itex]\mathbf{\mathbf{\boldsymbol{\beta}}}[/itex]
[itex]\begin{align}\frac{\partial(\mathbf{\mathbf{\beta}^{\textrm{T}}}\mathbf{A\boldsymbol{\beta}})} {\partial\beta_{k}}&=2\beta_{k}a_{kk}+2 \overset{n}{\underset{i\neq k}{\sum}}a_{ki}\beta_{i}\end{align}[/itex]
[itex]\begin{align}=2\overset{n}{\underset{i=1}{\sum}}a_{ki}\beta_{i}\end{align}[/itex]
But [itex]\overset{n}{\underset{i=1}{\sum}}a_{ki}\beta_{i}[/itex] is the [itex]k[/itex]th element of the vector [itex]\mathbf{A}\boldsymbol{\beta}[/itex] so it follows that
[itex]\begin{align}\frac{d( \mathbf{\mathbf{\beta}^{\textrm{T}}} \mathbf{A\boldsymbol{\beta}})} {d\mathbf{\boldsymbol{\beta}}}&=2 \mathbf{A\boldsymbol{\beta}}\end{align}[/itex]
Thus
[itex]\begin{align}\frac{d(\mathbf{\beta^{\textrm{T}} X^{\textrm{T}}X\boldsymbol{\beta}})} {d\mathbf{\boldsymbol{\beta}}}= 2\mathbf{ {\mathbf{ X^{\textrm{T}}X\boldsymbol{\beta}}}} \end{align}[/itex]
If anyone can check/correct I would be grateful.
  • · Replies 53 ·
