Double integral of v² arctan(Lu/(v√(u²+v²+L²))) over rectangle
10 replies · 3K views
Summary:: Could someone please evaluate this double integral over rectangular bounds? Answer only is just fine.
[Mentor Note -- thread moved from the technical math forums, so no Homework template is shown]
Hi,
I'm trying to find the answer to the following integral over the rectangle ##(x^-,x^+)\times(y^-,y^+)##:
[tex] \int_{y^-}^{y^+}\int_{x^-}^{x^+}v^2\arctan\frac{Lu}{v\sqrt{u^2+v^2+L^2}}\,\mathrm{d}v\,\mathrm{d}u.[/tex]
For the indefinite double integral, WA gives a complicated answer with logarithms of complex arguments. I know that ##\tan^{-1}z=\frac{i}{2}\log\frac{1-iz}{1+iz}##, but it is not clear how to get this from the WA expression:
[tex] \log\left\{-\frac{12(L\sqrt{L^2+u^2+v^2}+L^2+u^2-iuv)}{L^2u^3(v+iu)}\right\}[/tex]
Obviously, this should have a real answer since the integrand is real-valued over the domain of integration.
I don't have access to Mathematica at the moment and the internet integral evaluators I've tried all seem to fail here. I'm not interested in the step-by-step approach (##u##-/trigonometric substitution, integration by parts, partial fractions, etc.). I just want to know the answer to the double integral above.
Can somebody with access to a CAS or Mathematica please compute this double integral over the given rectangular bounds and share the answer? It would be much appreciated.
Thanks,
QM
##u(x^-,x^+)## or ##v(x^-,x^+)## ?
Where is Origin ? You do not care ?
Hi,
Thanks,
QM
What is the application? Is this for schoolwork?
Sorry that was a typo. Should be ##u(x^-,x^+)##.
It is a schoolwork-type problem, but not schoolwork. I was investigating electrostatic properties of an analytically soluble charge distribution when I encountered these integrals.
Okay, please post schoolwork-type questions in the schoolwork forums, and please show as much work on the question as you can. I will move your thread to the schoolwork forums for you now.
This thread will help to explain the PF rules about schoolwork-type questions:
https://www.physicsforums.com/threads/homework-coursework-questions.373889/
Hi,
Mathematica is giving a complex answer because without explicitly defining the domain of L, x, and y, Mathematica assumes they are complex. To restrict L, a, and b to Reals, use the code:
[CODE title="Mathematica"]ClearAll[theL, a, b];
Integrate[
v^2 ArcTan[(theL u)/(v Sqrt[u^2 + v^2 + theL^2])], {v, -b,
b}, {u, -a, a}, Assumptions -> Element[{theL, a, b}, Reals]][/CODE]
Your integral smells fishy to me. I assume we have
\frac{y}{x}=\tan(\phi)
\frac{L}{\sqrt{x^2+y^2 +L^2}}=\cos(\theta)
where ##\phi## is the azimuthal angle and ##\theta## is the angle of elevation measured from the vertical. Your integrand is
x^2\tan^{-1}(\tan(\phi)\cos(\theta))
with the dimensions of ##angle*(length)^2##. That's just weird for an electrostatics problem with rectangular symmetry. It looks like your mixing apples and oranges. Where did you get that? It should be a red flag for you that something went wrong in your derivation when WA gives a complex solution.
Dimensions of ##angle\cdot length^2## are correct. There are other factors of ##x_{\pm}^{-1},y_{\pm}^{-1},z_{\pm}^{-1},L^{-1}## and these lead to dimensions of ##[k]charge^2length^{-1}## when all is said and done. I just omitted those prefactors to focus on the integral I have not yet been able to evaluate. I am absolutely certain the integrand is correct, it's just an uncommon (and hard) problem requiring enough iterated integration that this integral eventually occurs.
I have worked out the indefinite integral:
[tex] \iint v^2\tan^{-1}\frac{Lu}{v\sqrt{L^2+u^2+v^2}}\,\mathrm{d}u\,\mathrm{d}v<br /> =2Lu(u^2+L^2)\sinh^{-1}\frac{v}{\sqrt{u^2+L^2}}-\tfrac{1}{2}L^4\tan^{-1}\frac{uv}{L\sqrt{u^2+v^2+L^2}}[/tex]
[tex] -\tfrac{1}{2}u^4\tan^{-1}\frac{Lv}{u\sqrt{u^2+v^2+L^2}}<br /> +\tfrac{1}{2}v^4\tan^{-1}\frac{Lu}{v\sqrt{u^2+v^2+L^2}}<br /> +\tfrac{5}{2}Luv\sqrt{u^2+v^2+L^2}<br /> +u^3v\sinh^{-1}\frac{L}{\sqrt{v^2+u^2}},[/tex]
Integration constants are omitted because they cancel when I input rectangular bounds.
Can someone please confirm this result?
If it were single integral the definite integral should be
[tex][RHS]_{x-}^{x+}[/tex]
I am not sure how we should calculate definite double integral from RHS. May I do it as
[tex][[RHS]_{x-}^{x+}]_{y-}^{y+}[/tex]?
For confirmation how about calculating and checking
[tex]\frac{\partial RHS}{\partial u\partial v}=Integrand[/tex]?
Integrand is odd function for both u and v. So we expect RHS is even function for both u and v like
[tex]\int dx \int dy \ \ xy= \frac{x^2y^2}{4}[/tex]
But your RHS is odd function for both u and v. Is my speculation wrong ?
