What Is the Distance of Closest Approach in a Particle Collision?
  • Thread starter Thread starter Tido611
The distance of closest approach in a particle collision involving a proton and an alpha particle can be determined using conservation of energy and momentum principles. Initially, both particles are fired towards each other with a speed of 0.141c. The total energy of the system is the sum of their kinetic energies, which equals the potential energy at the point of closest approach. The correct approach involves analyzing the system from the center of mass frame to accurately account for the motion of both particles.
  • Understanding of conservation of energy and momentum in particle physics
  • Familiarity with kinetic and potential energy equations
  • Knowledge of relativistic speeds and their implications
  • Basic concepts of particle interactions and forces
  • Study the conservation of momentum in particle collisions
  • Learn about the center of mass frame in physics
  • Explore the equations for kinetic and potential energy in particle systems
  • Investigate relativistic effects on particle collisions at high speeds
Physics students, particle physicists, and anyone interested in understanding particle collisions and energy conservation principles.
Tido611
A proton and an alpha particle (q = +2.00e, m = 4.00u ) are fired directly toward each other from far away, each with an initial speed of 0.141c. What is their distance of closest approach, as measured between their centers? (Hint: There are two conserved quantities. Make use of both.)
I would figure that you could use conservation of energy in the sense that the energy of the system initially is the kinetic energies of the two particles combined (Enet1 = Kp + Ka). At the point of closest approach, their speeds should be zero, and hence Enet2 = Uelec = Kq1q2/r. From here it should be straightforward:
Enet1 = Enet2
Kp + Ka = Kq1q2/r
Then solve for "r".
However, this is incorrect. Perhaps my assumption that the alpha particle (4 times the mass, 2 times the charge) stops completely is wrong. At this point, I really have no idea.
It might work better if you set it up in a frame where the center of mass is stationary.
Then use the conservation of energy and momentum.
  • · Replies 24 ·
