Please help me question on the game theory, thanks
The utility function u(w) = ln(w) indicates that the individual is risk averse, as it is concave, demonstrating diminishing marginal utility. To calculate the expected utility of the gamble, one must consider the probabilities of losing and gaining wealth, leading to the expression u(w) = ln(0.6 * 3 + 0.4 * 1) = ln(2.4). The maximum willingness to pay to avoid the risk can be derived from the difference between expected utility and the utility of certain wealth. The discussion highlights the need for clarity in understanding terms and calculations related to game theory and utility functions. Overall, the focus is on demonstrating risk aversion and calculating expected utility in the context of the given gamble.
coldway
A person has a utility function defined over her wealth given by
u(w)=ln(w). Her initial wealth is $2 and she faces a risky prospect in which she will
lose $1 with probability 0.4 and gain $1 with probability 0.6.
(i) Show that this person is risk averse by demonstrating that her utility function is
concave.
(ii) What is her expected utility of this gamble?
(iii) Find her maximum willingness to pay to avoid taking this risk.
Hey there, welcome to PF!
I'm not uh-mayzing at game theory, but I'll see what I can rustle up here. What have you tried so far? Do you understand all of the terms?
This post should be in one of the math forums.
This involves the question of marginal utility, ln (w) is concave, meaning that derivatives along the x-axis positive direction is decreasing, which means that the marginal utility of winning is less than the marginal loss of output,so far i just up to here, i still looking for futhermore help and try to solve the question
for the part2, is the answer u(w)=ln(0.6*1-0.4*1)=ln0.2, but i am not sure about it
is frist part second derivtive??differential
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
