Plotting 3D Regions in Mathematica 7
  • Topic: Mathematica
  • Thread starter Thread starter n00dle0
    Mathematica Plotting
4 replies · 4K views
n00dle0
Hi!
I am plotting the following in Mathematica 7.
Code:
RegionPlot3D[(x^2 + y^2 + z^2 <= 1) && (x < 0 || y > 0 ||
    z < 0), {x, -1, 1}, {y, -1, 1}, {z, -1, 1},
 ColorFunction ->
  Function[{x, y, z}, ColorData["TemperatureMap"][x^2 + y^2 + z^2]],
 PlotPoints -> 50, Mesh -> False,
 Lighting -> {{"Directional",
    RGBColor[1, 1, 1], {{-1, 1, -1}, {0, 0, 0}}}},
 AxesLabel -> {X, Y, Z}, {ViewPoint -> {2, -0.5, 0.5}}]
I need the plot to look such that the color on the cut out surface of the sphere should be a gradient in a radial fashion. Assume that there is a point heat source at the center of the sphere and colors represent the temperature profile within the sphere. Any ideas?
Thanks in advance,
- N
DaleSpam said:
Add the option ColorFunctionScaling -> False
I don't know why, but it seems that the scaling is the problem.
Thanks a lot Dale. I had been struggling with it since a week. Now does anyone have idea as to why. Is this behavior a feature or a bug?
- N
- N
Well this seems to be the feature, as the help specifies,
Parameters to ColorFunction are normally scaled to be between 0 and 1:
__________________________(by default)_________________________
So, the parameters are scaled, not the results.
- N
- N
That explains it. So it takes x which ranges from -1 to 1 and rescales it to range from 0 to 1, similarly with y and z. Then when you calculate the norm you essentially get a scaled distance from the point (-1,-1,-1)
